Go to Post HEY! a robot that occupies 4 dimensional space is against the rules! - KenWittlief [more]
Go Back   Chief Delphi > Technical > CAD
Unread 15-08-2009, 22:47
Rion Atkinson's Avatar
Rion Atkinson Rion Atkinson is offline
The CAD Guy
Rion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond repute
Help in Inventor 2010
Ok, here's the thing. I have been CADing some random chassis designs. And I accidentally closed down the sidebar on the left hand side of the screen.(see picture) I can't edit my parts very well without this.
I have been through the help and went to their website. I couldn't find anything on how to get it back, so I figured I would ask the Chief. Does anyone know how to get this back? Any help would be greatly appreciated.
[IMG]<a href="http://s954.photobucket.com/albums/ae22/formerlyfamous/?action=view&current=InventorProblem.jpg" target="_blank"><img src="http://i954.photobucket.com/albums/ae22/formerlyfamous/InventorProblem.jpg" border="0" alt="Photobucket"></a>[/IMG]
Unread 15-08-2009, 22:51
McGurky's Avatar
McGurky McGurky is offline
Geek
AKA: Kyle McGurk
FRC #1716 (Redbird Robotics)
McGurky is just really niceMcGurky is just really niceMcGurky is just really niceMcGurky is just really nice
Re: Help in Inventor 2010
Go to the view tab on the ribbon bar on the top. where it says User interface, make sure that "Browser" is checked. If not, check it. BTW your pic doesnt work... Hope this helps, if you have any more question just ask!!
http://s954.photobucket.com/albums/a...torProblem.jpg
RTFM -Read The First Manual
You already are who you are, I may be able to show you a fancy trick or two, but the term "Better" is relative to the potential you already have.
Take a look at my website/Blog!
Unread 15-08-2009, 22:57
The CAD Guy
Thank you so much! I was ready to pull my hair out...
Figures that the pic wouldn't work... Thanks for reposting it.
Unread 15-08-2009, 23:01
McGurky's Avatar
Geek
AKA: Kyle McGurk
That same thing happened to me back when I was learning inventor for the first time when the navigation of the program wasn't as easy... I think I almost through my computer at a wall I was so frustrated!!
Unread 15-08-2009, 23:05
The CAD Guy
Hahaha. Ya. It happened to me in 2009 as well.. I think I had to get the IED teacher to fix it....
Unread 16-08-2009, 00:32
Happy Birthday! Akash Rastogi Akash Rastogi is offline
Nice frame rail btw, you might not need two sets of standoffs per increment depending on the diameter of the standoffs. Looks nice though Also, a tip for a more stable base is to move your front wheels as far front as possible and back wheels to the back.
http://www.chiefdelphi.com/media/photos/32515
Unread 16-08-2009, 23:20
The CAD Guy
Ah. Ok. Thank you. I am currently just messing around with Inventor learning more about it. I'm running ideas by my curent team capitan as I do.
Thanks for the info! I'll be sure to take it into account in my design.
What would you say about the middle wheel? Keep it in the center?
Unread 17-08-2009, 08:24
McGurky's Avatar
Geek
AKA: Kyle McGurk
I found this on in your "Photobucket" The chassis looks pretty sweet, great work are you going to implement any kind of weight reduction on it?
Unread 17-08-2009, 22:58
The CAD Guy
Thanks.
No I haven;t gotten that far yet. In fact. That is a sightly older version. The wheel are further apart now.
Eventually I'll get into weight reduction.. But as it is this will be my second year so I don;t really know what the best material would be for the railing.. at the moment I'm just using 1" extruded aluminium.. I'm not sure if you can really swiss cheese that..
Unread 17-08-2009, 22:59
Originally Posted by Formerly Famous View Post
Thanks.
When using 1x1 at 1/16" wall there is no need to unless there is a desperately fat robot sitting in your shop at the end of six weeks
Unread 17-08-2009, 23:30
The CAD Guy
But will that hold up?
Unread 19-08-2009, 01:41
I wouldn't use 1/16" wall in the drive area; 1/8" wall is probably better. It's heavier, yes, but if you've seen old (pre-bumper) robots with 1/8" wall, you'll understand why I'm skeptical of 1/16" in the drive area.
You can swiss-cheese 1" tube; however, if you're going to do it in your drive area, you need to plan how you're going to do it. The drive area is the most critical (read: least failure-tolerant) area. Using a triangle pattern in say 1"x2" is not uncommon, if planned out. 1"x1" is a riskier proposition.
I'm with Akash, if it's 1/16", don't weight reduce at all. I've used that thickness on two robots, once out of contact zones (a shooter frame, using 3/4" and 1" tubes) and once supporting other robots (1", IIRC, and covered in corrugated plastic). It's strong, but not if you put holes in it.
Unread 19-08-2009, 02:11
Oops, guess I forgot to mention that I'd stick with thinning down tubing to 1/16th on mostly upper structures, not the drivetrain. Its what we did this year on our robot just incase there were any "high force impacts" as Lunacy had guaranteed us The structure above was all 1/16"
Unread 19-08-2009, 14:03
The CAD Guy
Ok. SO if the chassis I currently had was 1/8" then it should be sturdy enough?
(cause that's actually what Idesigned it as..)
Inventor 2009 vs. 2010 Nathan CAD 17 22-03-2010 18:24
AutoCad Inventor 2010 McGurky CAD 17 16-06-2009 18:14
need help assembling parts in inventor .. (was: help) jhallel Inventor 5 22-02-2007 01:46
help with the inventor[robot part missing] (ajuda no inventor[parte do robo faltando] team 2244 Inventor 6 12-02-2007 06:16
Inventor Help edomus Inventor 1 24-01-2004 11:38
