pic: Blizzard proto base
Re: pic: Blizzard proto base
Looks nice! I wonder if you could replace the rest of that aluminum with some 12mm and 19mm birch? Worked for us for Lunacy....
That's a speedy drive train!
I like the use of wood for tthe wheels -- are they 1" wide? |
The wheels are 24mm wide. Baltic birch plywood only comes in metric so we take 2 sheets of 12mm spread wood glue on them and sandwich together under a couple of batteries. Then drill a hole and turn them round on a lath. Really easy and is usually done by second day of build.
I have a question I've wondering about for a while.
It seems like lately I've seen a lot of CAD models for drivetrains including wood as material for them, and I was just wondering what the advantages are to this as opposed to using aluminum or some other material? Is it cost or weight savings that is the main advantage? If someone could shed some light on the topic I'd appreciate it a lot. Thanks in advance |
I like the use of wood wheels in this rendering, that's something that we had been pondering for a while when we were in our drivetrain brainstorming frenzy last year. We never came up with a design that was fast and easy enough to build to make us choose custom wheels over more expensive store bought wheels, though. We are generally pretty lazy... One other note on the design: I would think that bumper mounting would be easier if the side rails were oriented to make the outside edge of the robot flat (instead of having those flanges). Of course, if the bumper rules follow the trends of past few years then predicting bumper mounting criteria is but the dream of a madman. |
#7
I guess wood vs aluminum wheels or body really depends on team resources and what were used to. Our team has a local metal supermarket so we use aluminum for the body and mill using a Bridgeport digital readout mill. At school our tech department has an open CNC which technically could be used on aluminum and when we tried one summer it worked but took for ever and we decided it was not worth the time or effort. Wooden wheels are super easy to make and we've never thrown a tread or cracked a wheel according to our mentor. We've always made the wheels on a lath but this year since I've learned to CNC I'm going to try and make it on that so to cut our manufacturing time in half.
The flange on the outside is to space the bumper from the bolt heads holding the wheel shafts and Bosch extrusion Last edited by kajeevan : 18-08-2009 at 09:16. |
#8
I'd be a bit worried about the front. I recall many teams having problems with bumper rules this year. And then there is the possibility of getting hit in a bad spot and bending one of the front forks.
One final question. How much clearance space do you have for the chain? I'd make the front parts a bit wider or at least put a couple of angle supports in there. A couple of triangles or braces go a long ways in preventing bends. |
#9
I will look into a bit more bracing in the mouth of the base. Also the chain has .25in clearance from the side of the wheel.
| pic: Blizzard X - Week 4 | Mr. Lim | Extra Discussion | 9 | 30-01-2009 14:36 |
| PIC: 1902 Exploding Bacon proto type base | Doug Leppard | Robot Showcase | 11 | 24-01-2009 12:17 |
| pic: Madtown 1323 Proto 2 | R.C. | Extra Discussion | 12 | 20-06-2008 20:27 |
| pic: Blizzard VIII | Steve W | Robot Showcase | 28 | 25-02-2007 00:50 |
| pic: Blizzard | Steve W | Robot Showcase | 22 | 08-03-2006 08:32 |
