Go to Post The short answer is there is no shortcut. - JDNovak [more]
Go Back   Chief Delphi > Other > VEX
Unread 20-08-2009, 12:04
kmcclary's Avatar
kmcclary kmcclary is offline
Founder 830/1015;Mentor 66/470/1502
FRC #0470 (Alpha Omega Robotics)
Rookie Year: 1994
kmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond repute
VEX Shaft Collar Specs - Help!
I bought several of the Radio Shack V.5 kits, and noticed there were NO shaft collars in any of them! Running to the hardware store, I find they are both VERY expensive (several dollars each!), AND the standard sizes they stock don't QUITE fit the 1/8" square shafts.
SO... I need to fab some ASAP *today* on a lathe, for an event starting TOMORROW! (I have the raw bar stock for this now...)
Could someone please quickly measure a standard collar, and post the specs for it?
I NEED: ... ID, OD, Width, Setscrew size & type (thread, length)...
The setscrew isn't vital (the first 3 numbers are more important to me), but it would be NICE to only require the same basic Allen Wrench as the cap head screws and have them mix with others, so I'm ASSUMING it's either a 10-24 or 10-32 Allen Head setscrew.
Thanks!
- Keith
Keith McClary - Organizer/Mentor/Sponsor - Ann Arbor MI area FIRST teams
ACTI - Automation Computer Technologies, Inc. (Sponsoring FIRST teams since 2001!)
MI Robot Club (Trainer) / GO-Tech Maker's Club / RepRap-Michigan) / SEMI CNC Club
"Certifiably Insane": Started FIVE FRC teams & many robot clubs (so far)!
2002: 830 "Rat Pack" | 2003-5;14: 1015;1076 "Pi Hi Samurai" | 2005-6: 1549 "Washtenuts"/"Fire Traxx"
2005-(on): 1502 "Technical Difficulties" | 2006-(on): FIRST Volunteer!
2009-(on): 470 "Alpha Omega" | WAFL | Sponsor & "Floating Engineer" for MI Dist 13 (Washtenaw Cnty)
2011: 3638 "Tigertrons" | 2013-(on): 4395 "ViBots" | 2014-(on) 66 "Grizzlies"
"Home" Teams: 66, 470, 1076, 1502, 4395
Local FIRST alumni at or coming to Ann Arbor (UM/EMU/WCC/Cleary)?
...We Want YOU as a Mentor! Please email me for info!
Support CDF Reputation - If a posting helped, thank 'em with rep points!
"It must be FRC build season when your spouse and children become 'Action Items 8 & 9'..."
Unread 20-08-2009, 12:23
NickE's Avatar
NickE NickE is offline
_
Re: VEX Shaft Collar Specs - Help!
According to the CAD model here:
OD: 0.4331in
Width: .2600in
The setscrew appears to be an 8-32 of length .1300in
Assuming the model is accurate, these dimensions should be.
Unread 20-08-2009, 13:13
kmcclary's Avatar
Rookie Year: 1994
OD: 0.4331in
Width: .2600in
Wow.... Thanks for the quick reply!
BTW... Are you SURE about the setscrew? According to Wikipedia: http://en.wikipedia.org/wiki/Hex_key ,
a #8 setscrew NORMALLY uses a 9/64" allen wrench, whereas
a #10 setscrew NORMALLY uses the 5/32"
(which I *thought* was the VEX screw wrench, isn't it?)
I'd be REALLY surprised if you'd need two different wrenches.
(Maybe they obtained a non-standard 8-32 screw, to keep it compatible...)
Unfortunately, I don't have a compatible CAD available right now to view those docs.
OOC, Can you please take another quick peek at the CAD again, and see which WRENCH the setscrew uses? Is it 5/32", or another size?
(To measure an Allen Wrench's size, simply measure between opposite flats.)
Thanks again!
- Keith
Unread 20-08-2009, 13:26
NickE's Avatar
_
Thanks again!
- Keith
The cad shows it as 5/64. I know that the wrench for the setscrew is the same wrench as for the 6-32 motor mount screws, which is indeed smaller than the standard 8-32 vex screws.
Unread 20-08-2009, 15:41
The setscrew on a VEX lock collar DEFINITELY is 8-32, and the allen wrench size is 5/64". Trust me on this. I've purchased hundreds for our VEX teams.
Unread 20-08-2009, 18:00
bellpride's Avatar
bellpride bellpride is offline
ramblin' on
AKA: John Mueller
FRC #0254 (The Cheesy Poofs), VRC #254A, #254Z (The Cheesy Poofs)
bellpride is a jewel in the roughbellpride is a jewel in the roughbellpride is a jewel in the rough
As an extension, you shouldn't even worry about the set screw if you are short on time. Any normal 8-32 screw from the vex kit will work, and you won't have to worry about the 5/64" allen wrench either.
John Mueller
Founder and Ex-Captain - VRC254, 254A, 254Z
Alum - FRC254
Unread 20-08-2009, 18:52
James Tonthat James Tonthat is offline
FRC #0148 (Robowranglers)
James Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond repute
You might want to try a hobby store. They'll probably be called "wheel collars" found usually with the r/c airplane stuff. They use them to attach wheels onto planes which freespin.
Good luck!
James Tonthat
Mechanical Engineer, RackSolutions, a subsidiary of Innovation First International
Lead Engineer - Texas Torque - 2009-2014
Mentor - Robowranglers - 2015-
Unread 20-08-2009, 19:38
I also have bought them in small quantity from our local Ace Hardware. The cheapest place I've found is the VEX Website -- cheaper than McMaster-Carr.
Unread 21-08-2009, 13:57
Foster Foster is offline
Engineering Program Management
VRC #8081 (STEMRobotics)
Foster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond repute
Yes, making them and McM-C are both more expensive that buying them from VEX. Even with the one day overnight they will be cheaper to buy from them.
Foster - VEX Delaware - 17 teams -- Chief Roboteer STEMRobotics.org
2010 - Mentor of the Year - VEX Clean Sweep World Championship
2006-2016, a decade of doing VEX, time really flies while having fun
Downingtown Area Robotics Web site and VEXMen Team Site come see what we can do for you.
VEX Shaft Encoder Kit jeffmorris FIRST Tech Challenge 1 19-05-2006 12:23
VEX Optical Shaft encoders in FRC sanddrag FIRST Tech Challenge 8 04-10-2005 07:52
Shaft Collar i-Factory Part Posted Ed Sparks Inventor 0 12-01-2003 23:51
Shaft collar as a fastener? hinge87 OCCRA 1 21-10-2002 20:28
Window Motor Output Shaft Spur Gear Specs archiver 2000 1 23-06-2002 22:56
