Go to Post Just make a FIRST version of Quidditch. The only people who would be complaining are drivers from previous years who wanted to play it. - Koko Ed [more]
Unread 13-08-2009, 15:38
Cadyyan Cadyyan is offline
The Button Man
FRC #1716 (Redbird Robotics)
Cadyyan is an unknown quantity at this point
IFI Controller Compiler
My team has recently dug up our old IFI controllers and were hoping to use them. Unfortunately we don't have a C or C++ compiler for it and we have no desire to use EasyC again. Does anyone know of a free and fairly decent IFI compatible compiler we could use?
Thanks!
~Cadyyan~
Watch your face!
Unread 13-08-2009, 16:41
Joining the 900 Meme Team
FRC #0079
Re: IFI Controller Compiler
As far as I know it is only possible to program the Pic microprocessor using Microchip's compiler which is available on their website.
This being said, googling around may be your best bet.
Unread 13-08-2009, 21:21
EHaskins EHaskins is offline
AKA: Eric Haskins
no team (CARD #6 (SCOE))
EDIT
You must use the MCC18 complier c2.4. Later versions will NOT work.
The following instructions assume you have access to either and EasyC install, activated or trial.
If you can find a copy of the MCC18 v2.4 installer you can skip copying the folder from EasyC.
/EDIT
If you have a copy of EasyC installed you'll find the folder "c:\program files\Intelitek\EasyC\mcc18" (this may not be quite right, but its close). This folder contains the MCC18 complier and other required files. Copy that folder to "C:\mcc18".
Then install MPLAB IDE from http://www.microchip.com/stellent/id...&part=SW007002.
You can find the default source code and documentation at http://www.ifirobotics.com/rc.shtml#Programming. IFI loader, which is used to transfer the program to the robot can also be found on that page.
This information is all from memory. I haven't had to work with the IFI system for some time, so there may be small errors in this post.
Eric Haskins KC9JVH
Unread 13-08-2009, 23:17
daltore's Avatar
daltore daltore is offline
Electronics/programming/design
AKA: Aaron Osmer
FRC #3529 (ausTIN CANs)
daltore has a spectacular aura aboutdaltore has a spectacular aura aboutdaltore has a spectacular aura about
Send a message via AIM to daltore Send a message via MSN to daltore Send a message via Yahoo to daltore
You can download the C18 compiler version 2.4 here:
https://jvex-robotics.dev.java.net/f...c18_240_se.zip
Unread 13-08-2009, 23:31
RyanCahoon's Avatar
FRC #0766 (M-A Bears)
You can get both the Microchip C18 compiler and the MPLAB IDE off of http://tshs.tahoma.wednet.edu/sites/...ms_programming
FRC 766, 2015-, Mentor
Unread 14-08-2009, 00:21
AKA: Eric Haskins
I'd just like to point out that redistibuting copyrighted material, such as MPLAB or C18 installers, withot persmission of the copyright owner is illegal. Discussion of such activities is also forbidden by the forum rules (second bolded line).
Eric Haskins KC9JVH
Unread 14-08-2009, 00:26
Chris is me's Avatar
AKA: Pinecone
That's a grey area, as the team has a license to use said software, but not the actual files. One could argue they do have the right to redownload and use said software.
Unread 14-08-2009, 01:17
daltore's Avatar
AKA: Aaron Osmer
This is the student edition, 60-day trial offered by Microchip for free. After 60 days, it still works, but is "feature limited" (the features that are then limited are the ones you don't use for IFI controllers anyway). As far as I know, these are not files restricted by Microchip.
Unread 14-08-2009, 01:24
McGurky's Avatar
McGurky McGurky is offline
Geek
AKA: Kyle McGurk
McGurky is just really niceMcGurky is just really niceMcGurky is just really niceMcGurky is just really nice
Does anyone know what the vista/Linux compatibilities with this software are? or are we limited to just XP? I am assuming It is not Vista compatible but not sure about Linux. any help would be appreciated!
RTFM -Read The First Manual
You already are who you are, I may be able to show you a fancy trick or two, but the term "Better" is relative to the potential you already have.
Take a look at my website/Blog!
Unread 14-08-2009, 09:27
AKA: Eric Haskins
Redownload/reinstall/create private backups, yes. Redistribute publicly, no. It is not a grey area.
I've never had an issue running it on Vista. There were some tutorials for getting it running in WINE a few years ago, but I never tried.
Eric Haskins KC9JVH
Unread 14-08-2009, 09:59
The Button Man
Thanks for all the help you guys!
Watch your face!
Unread 14-08-2009, 15:36
daltore's Avatar
AKA: Aaron Osmer
I actually run C18 on Linux under WINE and there is no issue. I use an MPLAB clone called Piklab, and you just tell it the directory to find mcc18, and it sets it all up. If you want more help, let me know. It works both with WPILib (library used in EasyC) and the default code libraries.
Unread 14-08-2009, 22:30
McGurky's Avatar
Geek
AKA: Kyle McGurk
We got everything working today! I being a noob to the IFI control system spent a while reading documentation and manuals. We wrote, compiled and successfully (after plenty of debugging) ran a few simple programs to test functionality of a few mechanisms. Everything worked great
Thanks for all your help!!
Unread 21-08-2009, 13:39
rokenboker rokenboker is offline
FRC #1236
rokenboker is an unknown quantity at this point
here are the links for BOTH MPLAB (FULL) and C18 Compiler (FULL). and these are from the Microchip web site, so they are NOT illegal copies FYI.
MPLAB IDE (IFI version)
http://www.microchip.com/stellent/idcplg?IdcService=SS_GET_PAGE&nodeId=1406&dDocName =en019469&part=SW007002#P140_5618
C18 Compiler for MPLAB IDE
http://www.microchip.com/stellent/idcplg?IdcService=SS_GET_PAGE&nodeId=1406&dDocName =en536656
Unread 22-08-2009, 01:56
AKA: Eric Haskins
Note that unless you use Kevin Watson's C18 3.x compatable libraries (whish are not compatable with the IFI libs), the C18 compiler you linked to won't work.
Eric Haskins KC9JVH
IFI Controller Tether protocol BornaE Technical Discussion 7 05-05-2009 04:44
IFI Controller Channels - NEED HELP Kims Robot Off-Season Events 3 25-02-2008 19:59
Using IFI Controller witout Operator System 703pascal Programming 20 16-06-2007 22:10
How much code can an IFI controller handle? Larry Barello Programming 7 10-02-2002 19:06
