Re: Normalizing motor speeds using Arcade Drive in Labview
Also make sure that the speed controllers on each side are properly calibrated.
Great ideas, I will follow through on both.
Jared, How do you calibrate the speed controllers? |
Have you verified that mechanically, each side of the drivetrain has similar amounts of friction? Many times I've found that to be the problem. Simply turning the wheels by hand may uncover something.
Are you using victor or jaguar speed controllers? You'll get better results with a jaguar. If you look at the Jaguar and Victor transfer characteristics, you'll see two things about the Victor that hurt you. First, the center point is offset from where it should be (1.5 ms). This year's code works around this by offsetting the center point to a value that works for most victors, however there is a unit to unit variation. Calibrating them may help also. Instructions for calibrating either the Victor or Jaguar are in their respective manuals. Finally, the sharp increase at low PWM values hurts the victors here, because a small difference there makes a big difference in speed. There is an example for the TransformRef in the LabVIEW examples. I don't have LabVIEW in front of me, but I think it was fairly obvious. This year, for the first time, we had a robot that drove perfectly straight for 30 feet, using no feedback, thanks in large part to the Jaguars. |
Great feedback, thanks for that Joe. I will definitely check out the friction issues and also grab the manual for some Jaguar tuning. We are using Jaguars on both motors
There's a place to select either Jaguar or Victor when you open the drive reference. Make absolutely sure you're telling the code that you're using Jaguars. The Victor workaround mentioned by Joe Ross makes Jaguar-controlled motors spin one direction faster than the other if you set it wrong.
wha! That's almost exactly what we were seeing when we started working on the code... OK, first thing to check when I get back to the code
#7
First off, appreciate all the help.
The problem ended up being a loose electrical connection to the motor and a slight binding problem in the gear box. Once we fixed all that, everything is looking good. Funny how as the team's programming mentor, the first place I turn to is code. I should know better and will check my premises next time. |
#8
(Spoken like a true hardware guy) |
| [FTC]: Using two Hitechnic Motor Controllers in LabView | ZSLAYTER | FIRST Tech Challenge | 2 | 08-03-2009 10:36 |
| Are motor speeds proportional to PWM value? | ellisk | Motors | 9 | 07-02-2009 12:49 |
| Labview questions, using motor and pot as a servo | martin417 | NI LabVIEW | 7 | 05-02-2009 16:43 |
| Tracking Servo motor with drive motor in Labview | mbone206 | Technical Discussion | 5 | 28-01-2009 17:32 |
| Arcade Drive | Anfony | VEX | 4 | 08-11-2006 19:46 |
