Go to Post What a great organization! - HoltDan [more]
Unread 22-08-2009, 17:15
rokenboker rokenboker is offline
FRC #1236
rokenboker is an unknown quantity at this point
Question MPLAB error: Error [1027] unable to locate 'serial_ports.h'
hi, i downloaded the new MPLAB v8.33 and i am trying to get the program to locate all necessary documents. any ideas are welcome.
Unread 22-08-2009, 23:53
lynca's Avatar
lynca lynca is online now
Andrew Lynch
FRC #2587 (DiscoBots)
Re: MPLAB error: Error [1027] unable to locate 'serial_ports.h'
Which controller are you attempting to get working ?
1. VEX
2. FRC IFI Robot Controller (year specific helps) ?
What code template are you working with ?
1. Kevin Watson's code - http://www.kevin.org/frc/
2. VEX code base
3. WPI Library
History: 624 - Cryptonite --> 118 - Robonauts --> 2158 - AusTIN CANS --> 2587 DiscoBots
Bio: Andrew Lynch "How I Work" ---- LinkedIn , Facebook, Twitter
Unread 23-08-2009, 01:09
FRC #1236
the controller is the FRC IFI PIC18F8722.
Kevin Watson's Code: frc_camera_s_2.zip
Wii FRC bits: http://www.chiefdelphi.com/media/papers/2078
(this is to get the IFI bot controller to run off of a wiimote and nunchuk)
anything else i can provide you with?
Unread 23-08-2009, 09:32
Dave Scheck's Avatar
Dave Scheck Dave Scheck is online now
Dave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond repute
That basically means that something is doing a #include "serial_ports.h" (probably in the camera code), but the compiler can't find that file. If you see that file in your filesystem, the way to fix it is to add it to your include path (directory). There's a setting somewhere in the project settings (something like Project -> Build Options... -> Project).
Do a Windows find for serial_ports.h if you're not sure if you don't have the file or need the path.
If you don't have the file (I'm not sure if that comes with the camera code or not), try grabbing Kevin's serial port code (frc_serial_ports.zip)
http://kevin.org/frc/
Unread 23-08-2009, 11:26
FRC #1236
sorry, but that gave me more errors than before. any other ideas?
Unread 23-08-2009, 11:36
You'll need to be more specific. The errors are telling you exactly what's wrong, you just need to understand what they're telling you. Usually the first error will clean up a lot of the following errors (i.e. if you're missing a header file, any reference to variables in that header will throw errors).
My suggestion is to copy/paste the entire output here and put it in a code block so it's readable. At that point, someone can take a look and provide suggestions
Unread 30-08-2009, 19:05
FRC #1236
okay, now that first error is not appearing anymore, i now have this error
C:\MPLAB\frc_camera_s_2\user_routines.c:17:Error [1027] unable to locate '_sticks.h'
here's tho whole output message:
Debug build of project `C:\MPLAB\Wii FRC air cannon.mcp' started.
Language tool versions: MPASMWIN.exe v5.33, mplink.exe v4.33, mcc18.exe v3.33
Preprocessor symbol `__DEBUG' is defined.
Sun Aug 30 19:01:10 2009
Make: The target "C:\MPLAB\user_routines_fast.o" is up to date.
Make: The target "C:\MPLAB\camera.o" is up to date.
Make: The target "C:\MPLAB\ifi_startup.o" is up to date.
Make: The target "C:\MPLAB\ifi_utilities.o" is up to date.
Make: The target "C:\MPLAB\main.o" is up to date.
Make: The target "C:\MPLAB\serial_ports.o" is up to date.
Make: The target "C:\MPLAB\terminal.o" is up to date.
Make: The target "C:\MPLAB\tracking.o" is up to date.
Make: The target "C:\MPLAB\user_routines.o" is out of date.
Executing: "C:\MCC18\bin\mcc18.exe" -p=18F8722 "frc_camera_s_2\user_routines.c" -fo="user_routines.o" -D__DEBUG -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa-
Halting build on first failure as requested.
Debug build of project `C:\MPLAB\Wii FRC air cannon.mcp' failed.
Sun Aug 30 19:01:14 2009
BUILD FAILED
hope this helps us figure this out.
Unread 30-08-2009, 20:20
You are using a very new version of the C18 compiler, and a very old version of Kevin's camera code that wasn't designed to work with newer versions of the C18 compiler.
Kevin's code that supports C18 version 3.0 or higher does not have built in support the camera. If you really need camera support, I recommend starting with ifi_frc_sensor.zip and then start porting the camera code over. It may be a large task. If you just need the serial port support, it's built in to ifi_frc_sensor.zip, but you may still have to do some porting of the wii code, since I'm not sure how much the API changed over time.
In either case, you should be prepared to spend some time digging into the internals of how the code works. It may not be a quick change like it seems that you are expecting.
Alternately, if you could go back to using the version 2.4 of C18, and it might be easier.
Unread 01-09-2009, 20:45
FRC #1236
thanks, do you know where i can get the 2.4 version of C18 compiler? and, this did not help me with the "unable to locate 'sticks.h'" problem.
Unread 02-09-2009, 10:28
Originally Posted by rokenboker View Post
Do you know where i can get the 2.4 version of C18 compiler?
The older version was distributed with the KOP over the past 4 years (2005-2008)
The 2.2 version was in the KOP in 2004.
It came on both the MPLAB CDs and the EasyC CDs.
I found a student version online:
https://jvex-robotics.dev.java.net/s...&folderID=4775
You might want the whole tool chain (the Vex controller is compatible with the FRC IFI controllers as far as tools go):
https://jvex-robotics.dev.java.net/ToolChainSetup.html
Unread 03-09-2009, 16:29
FRC #1236
sorry, but that did not help either. thanks though.
Generic error in MPLAB domoarigato Programming 11 01-12-2008 14:21
Help! unable to locate 'p18cxxx.h' ducttapehaxor Programming 1 24-01-2006 16:13
Error: Unable to locate 'stdio.h' phrontist Programming 4 09-02-2005 19:59
MPLAB build error cabbagekid2 Programming 7 12-01-2005 13:36
MPlab error ryan_f Programming 9 24-05-2004 07:30
