Go to Post FIRST is just a single step in a multi-step process. Rome wasn't built in a day, and neither are solutions to the world's problems. - Tim Baird [more]
Unread 23-08-2009, 03:32
janevblagoj janevblagoj is offline
janevblagoj is an unknown quantity at this point
Two clients on one computer!
HI,
Which changes I must to make in this program about (UDP Chat) which you may find on
http://delphi.about.com/library/weekly/aa101105a.htm
To work on one computer simulate 2 clients, concerning with start two times on this program
On same Computer I want to have two clients!! Is it possible?
With Regard
Janev
Unread 23-08-2009, 06:32
GaryVoshol's Avatar
Cogito ergo arbitro
Re: Two clients on one computer!
This ChiefDelphi site is not about Delphi programming.
(since 2004)
Unread 23-08-2009, 09:53
keehun's Avatar
keehun keehun is offline
Team Captain
AKA: Keehun Nam
FRC #2502 (EP Robotics)
keehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond repute
Send a message via AIM to keehun
Well, if you know how to program in Delphi, the concept should be:
  1. Initial contact... Exchange notices whether or not a client has alread attached to a certain UDP port.
  2. If so, then the server probes the next designated port. If it's unoccupied, bind the connection. If it's already taken by another instance of the client, then move on to the next designated port.
  3. When you make the exchange, the server should record which port it's been bound to. This way, the server can differentiate.
Good luck!
I personally think you should implement an IRC client.
For by grace you have been saved through faith, and that not of yourselves; it is the gift of God, not of works, lest anyone should boast. -- Ephesians 2:8-9
2010: Quarter Finalist (MN 10,000 Lakes)
2010: Website Award (MN 10,000 Lakes)
2009: Quarter Finalist (MN 10,000 Lakes)
2009: GM Industrial Award (MN 10,000 Lakes)
two solenoids on one spike? Chara09 Pneumatics 6 26-01-2008 20:38
One or Two Wheel Shooter Nitroxextreme Technical Discussion 6 14-01-2006 01:10
[ECDU]:one or two Michael Leicht FIRST-related Organizations 16 09-12-2004 07:23
Multiple version of Inventor on one computer sanddrag Inventor 4 30-11-2004 13:31
one control stick or two? 346operator Technical Discussion 24 12-08-2004 09:59
