Go to Post Funny, I came to robotics for the robot, but find I stay for the people. - Mr. Pockets [more]
Unread 22-08-2009, 17:50
jmanela's Avatar
jmanela jmanela is offline
+1 is BIGGER than -1
AKA: Joshua Manela
FRC #2586 (Fondy Fire)
jmanela is a splendid one to beholdjmanela is a splendid one to beholdjmanela is a splendid one to beholdjmanela is a splendid one to beholdjmanela is a splendid one to beholdjmanela is a splendid one to beholdjmanela is a splendid one to behold
First Car
I am getting my first car soon, and I am not sure what to get. I know it's gotta be cheap (prob less 5000) and i am just not sure, any suggestions?
||2009|| Entrepeneurship Award, QF - Traverse City | Rookie All Star, QF - Detroit | Highest Rookie Seed, Rookie All Star, QF - Michigan State Championship | Finalist - MARC ||2010|| Engineering Inspiration, Website Award, SF- Kettering | Judges Award, Website Award, SF - Detroit | Website Award, Winner, Michigan State Champ //Thank you 469 and 1918!! | Finalist - MARC ||2011|| Engineering Inspiration, Website - Kettering | Entrepreneurship, Website, Finalist - Waterford | Website - MSC
Unread 22-08-2009, 18:03
ATannahill ATannahill is offline
AKA: Alex Tannahill
Re: First Car
Make sure it runs, take it to a professional shop and have them check it out. Make sure to check out the gas mileage.
- Arizona North
Unread 22-08-2009, 18:39
Re: First Car
If its a car that you just want to keep around for a short while, I'd suggest an older model Nissan. But that's just me.
Whatever you get, make sure you Kelly Blue Book it so you know you're not getting ripped off and are able to negotiate a price. When buying the car, take any gearhead (or a parent) with you to make sure there's no problems.
Yahoo autos and Edmunds is usually the best place to check out.
*Mr. Forbes is much smarter than me*
Unread 22-08-2009, 18:48
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: First Car
Of these two suggestions, I'd opt for a professional shop. They will be much more likely to know what to look for on the specific model of car. For example...I'm a parent/gearhead (serious gearhead) and I don't have any idea what goes wrong with modern little cars, because I know nothing about them, by choice.
Unread 22-08-2009, 19:13
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: First Car
While old cars are neat and fun, if you rely on it for school or work, get something newer, with lower miles, that is reliable. Make sure to test drive it and try EVERYTHING on it. Floor the gas pedal, floor the brake pedal (while cruising at 20mph or so), steer all the way both ways, check reverse, engine startup shutdown multiple times, radio, AC, heat, windows, locks. Make sure the tires have tread left and are not cracking. If you can fit, get underneath it and take a look at everything down there, especially any rubber parts. Check the belts and hoses under the hood for cracks. The engine compartment should be dry and dusty, not all wet and oily anywhere. Use ANYTHING that is wrong as a bargaining point.If the owner doesn't know when the oil was last changed, better move on...
As for what kind of cars, you can always make a lot of friends by owning a pickup truck (I would recommend the Ford Ranger) . Seems everyone always has something they need moved. (especially robotics teams). For a reliable car, you should be able to pick up a late 90's or even early 2000's Honda Accord or Civic for your price range. Those do tend to be targeted more among thieves though. Bottom line is, get whatever looks good and feels comfortable to you and fits your price range. Just be sure to do your shopping homework and not pay too much for what you're getting.
Good luck! Cars are fun!
EDIT: Forgot to add, check all the fluids that you can see without any disassemble. They should be at their proper levels, smell and look normal, free of any metal particles, and not cross contaminated. And when you drive it, roll the windows down and listen carefully to see if the car makes any strange noises. Also, if it is a private party, ask them their reason for selling it. If they don't have one, the reason may be that something is broken on it or about to be broken.
Unread 22-08-2009, 22:26
Billfred's Avatar
Billfred Billfred is offline
Re: First Car
(Full disclosure: I work for a GM dealer.)
In the sub-$5,000 segment, you're probably best off minimizing your brand loyalty. Take sanddrag's advice and test it well. If you have a trusted mechanic, bring them along; if you're a take-it-to-the-dealer type, most will perform their used-car check for you at the standard rate (figure on $100, but call them first to confirm).
The market right now isn't going to be as rich as it was a few months ago due to the CARS program--regardless of one's views on the program, it means that nearly a half-million cars that were presumably worth less than $5,000* are now no longer on the roads. Even if you didn't want the cars that got scrapped, the folks who did are now going after the remaining cars. This might mean that your best deal is a few months off, but you'll know the local market better. Trust your gut.
Spoiler for On CARS trades being worth less than $5,000:
If a car was eligible for CARS but worth more than the voucher amount, the dealer and customer would process it as a normal trade-in instead. Some might've slipped through the cracks--GM, for example, offered 0% for 72 months for CARS customers, so the interest savings might've tipped the scales for some--but I know that most of our CARS trades were solidly worth less.
Unread 23-08-2009, 12:53
Jay H 237 Jay H 237 is offline
Down at the railroad
AKA: Jason Hartmann
FRC #0237 (Black Magic)
Jay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond repute
Send a message via AIM to Jay H 237
Re: First Car
Good points here and a few other things to consider,
Get the word out to relatives and friends, you never know if they were planning on selling or trading a vehicle in and may sell it to you instead. Generally they will be more apt to let you know if there's anything critically wrong with it. To be honest, in the under 5K price range with a 10 year old or more vehicle there is likely to be minor problems, you just don't want the major ones.
You're in Michigan too so keep the winters in mind with what you choose. A 2wd pick up won't be the best thing and a 4wd will hit you on insurance bad at your age. I drive a fwd 1997 Camry that I keep good tires on and for the most part have been able to handle the CT winters.
2006 Maryland Delphi "Driving Tomorrow's Technology" award
2006 Connecticut General Motor's Industrial Design award
2005 Finalists-----------New Jersey (along with our alliances again, 56 & 303)
2005 WINNERS of the Radio Shack Innovation in Control Award (not once, but twice! )
2004 WINNERS ------ Johnson & Johnson Mid-Atlantic Regional (also thanks to our alliances 56 & 303)
2004 General Motors Industrial Design Award Winners
2004 Archimedes Quarterfinalists (also thanks to our alliances 121 & 386)
NEMO _________ NonEngineering Mentor Organization
"Make it idiot proof and someone will make a better idiot!" - author unknown
Unread 24-08-2009, 00:15
Molten's Avatar
Molten Molten is offline
AKA: Jason
FRC #1766 (Temper Metal)
Re: First Car
I'll second this one and add some minor problems can be good in buying a car. Mine still has no air conditioning, but the windows work and I got a much better deal then I would have gotten if the AC actually worked. The reason being most people need AC. If your willing to put up with something minor, it can lower the cost considerably. Just make sure it is something minor. Messed up cup holder? ok. Messed up mirror? Not ok.
I know this advice isn't something to use when picking a car. However, keep it in mind when discussing price. It might help you bargain it down, if it isn't already factored in.
"Curiosity. Not good for cats, great for scientists."- Numb3rs
"They can break your cookie, but... you'll always have your fortune."-T.W. Turtle, Cats Don't Dance
"Tell my tale to those who ask. Tell it truly - the ill deeds along with the good, and let me be judged accordingly. The rest... is silence."-Dinobot, Beast Wars
"Though the first step is the hardest and the last step ends the quest, the long steps in between are certainly the best."
–Gruffi Gummi, Disney's Adventures of the Gummi Bears
Unread 24-08-2009, 19:48
DonRotolo's Avatar
Back to humble
FRC #0832
Re: First Car
When seeking a car that will last a long time, the biggest issue is that of rust. Rust cannot be repaired - the metal must be replaced. This lowers the value of any such car dramatically, regardless of mechanical condition.
OK, so for your first car, you'll be unlikely to keep it for more than a few years - so a little rust is OK as long as safety isn't compromised. That'll cut the price. (It'll be easy to find rust in MI)
Just because you're looking for a "cheap" car, don't SETTLE. It is OK to look at 20 or more cars to find that one sweet bargain. Find someone who's got some car knowledge to "vet" them for basics - the posts above are good advice. Once you find a car that's great, THEN spend the $100 to have a professional mechanic go over the car carefully to tell you what's wrong with it.
(Every used car has something wrong with it. Nobody sells a car that's got no problems)
This offers a few benefits:
1. You learn if there is something expensively wrong with the car, and can back out of the deal.
2. You can learn what minor stuff is wrong with it, and use that in negotiating for a lower price. (Don't be afraid to negotiate a lower price. If you get even $100 off in 15 minutes, where else can you make $400 an hour? Negotiating is a matter of guts, don't be afraid to say exactly what you want and mean. Nobody's feelings will be hurt. It's business.)
3. Now you have a list of the little stuff you need to fix (or get fixed). Try repairing stuff yourself, it's a lot easier than you think. Buy or borrow a manual for the car.
When you do buy a car, go online and find the forums (like Chief Delphi) where folks who own these cars congregate. Every brand has them. Ask, and you'll get answers.
Lastly: This is a phobia of mine, so take it with a grain of salt. But, in a collision, Mass Wins. The properly belted occupants of heavier vehicles tend to fare better in collisions than those in lighter vehicles. I hope you never have a collision.
Unread 24-08-2009, 20:40
Re: First Car
As is usual on CD, you've been given good advice. I would have missed the rust bit, since that's rarely an issue on the west coast. I'm always amazed at the number of rusty cars in the midwest and east. Out here, cars don't get salt damage.
My favorite used car trick is to buy the oldest car I can find with the lowest mileage. The number of miles driven is a pretty fair estimator of how used up a car is, and the older a car is, the lower the price. I once found a six-year-old Subaru with only 22,000 miles on it. I felt like I was getting a new car for a third off.
For what it's worth, I think Edmonds pricing is closer than Kelley Bluebook online.
Unread 25-08-2009, 15:45
AndyB's Avatar
AndyB AndyB is offline
Ambitiously Disappointing
AKA: Andy Burchardt
FRC #0171 (Cheese Curd Herd)
AndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond repute
Re: First Car
I think any loyal viewer of Top Gear would have to suggest a Toyota Tacoma if you're going for pure reliability.
Part 1 (10:23): http://www.youtube.com/watch?v=Lrk6vsb77xk
Part 2 (3:03): http://www.youtube.com/watch?v=0Uc4Ksz3nHM&NR=1
Part 3 (4:22): http://www.youtube.com/watch?v=YfZDtC9kjVk
Team 171 :: Cheese Curd Herd :: College Mentor, 2008-Present
Team 269 :: CooneyTech Robotics :: Student, 2005-2007
pic: FIRST Car flag Vince lau Extra Discussion 16 20-10-2006 22:39
Forza Motorsport -- NASA/FIRST Car Madison Chit-Chat 5 15-05-2005 19:57
FIRST Car accessories JakeGallagher Chit-Chat 4 04-04-2004 11:53
FIRST Car decal? Mike8519 Chit-Chat 16 03-12-2003 09:22
pic: FIRST Car decal CD47-Bot Extra Discussion 32 02-12-2003 21:45
