Go to Post I like the gearboxes that can move my mechanical systems reliably. - Ginger Power [more]
Unread 24-08-2009, 01:46
Bootsie's Avatar
Bootsie Bootsie is offline
Ex-Captain and Mentor
FRC #0955 (Raiderbot)
Bootsie is on a distinguished road
pic: Swerve Drive Can SolidWorks Concept (cheap version)
Unread 24-08-2009, 01:47
NickE's Avatar
NickE NickE is offline
_
Re: pic: Swerve Drive Can SolidWorks Concept (cheap version)
How heavy is it?
You might consider placing some standoffs between the two walls of the tubing to prevent them from moving in relation to each other.
Unread 24-08-2009, 01:53
Bootsie's Avatar
According to SolidWorks, it weighs 1.3 lbs or so.
As for standoffs, there will be spacers between everything, at least on the wheel shaft.
I could also put some bolts through with spacers as well, as you suggest. A good point thanks.
Unread 24-08-2009, 01:54
R.C.'s Avatar
R.C. R.C. is online now
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
Looks Great, Nice Design. You may want to support the bottom of the Module with a lazy susan or with a circular piece of plastic.
Also, why not use Hex Shafts, you woudn't have to worry about keys
-RC
R.C.
MadTown Robotics Team 1323
Unread 24-08-2009, 01:56
Modules themselves look fine, but that weight can be reduced by facing that wheel on a lathe a bit more or with a COTS wheel from AndyMark. The wheel looks like a beefy part of that weight.
Unread 24-08-2009, 08:03
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
It would be more taxing on the team, but based on what I've heard I would recommend tapping the ends of the live axles and putting a bolt in them rather than using a c-clip.
Also, to prevent racking you could make this out of 3" box extrusion and make it a little longer at the bottom. That way you could have at least 1/4" wide strips running between the sides at the bottom. The aluminum already turns in at the bottom, so making it longer and cutting a hole (rather than a whole slot) for the wheel would easily allow you to do this.
GitHub
Unread 24-08-2009, 14:42
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
It looks like they're using snap rings not c-clips.
I would highly reccomend snap rings so long as you have the ability to make the groove the correct size. Nothing beats their ease of use.
2001-2004: Team 100
2006-Present: Team 254
pic: Swerve Module Concept (View 2) Dave McLaughlin Extra Discussion 5 17-06-2009 00:15
pic: Swerve Module Concept (View 1) Dave McLaughlin Extra Discussion 15 16-06-2009 22:36
pic: Unique drive concept Joe G. Extra Discussion 36 12-05-2007 20:27
pic: 1683 Concept 8 Wheel Drive sdcantrell56 Extra Discussion 16 16-04-2007 14:22
pic: Lego Swerve Drive CD47-Bot Robot Showcase 14 26-06-2003 16:19
