Re: pic: 1010 Drive system prototype
Thanks for the response, this system does use ball differentials where the two drive chains come together. The video and system can be viewed at http://www.team1322.org/ideas.htm . I would never use the 10 wheel design but I do like the discussion on this and how traction can be view by different people. I have heard many views on traction and multiple wheel designs. The addition of the extra wheels just popped into my mind and though I would see how it would look on paper and wanted to share. I find it interesting trying to come up with a omni direction robot that is simple to build and has an effective pushing force. Swerve drive is complex and Mecanum is simple but less traction. Maybe somebody will come up with a solution some day.
I guess everyone else has beaten the "too many wheel" horse beyond death,m though I do agree.
Not sure if you were aware or not, but those mechanums are also not set up properly. The wheels should not all be oriented the same direction, but in an "x" shape. |
Today 09:38 AM Yeah I'm aware I just don't feel like a redraw. If You watch our vidio the prototype is correct. http://www.team1322.org/ideas.htm Maybee we should get away from wheels and make running and jumping robots. |
384 & 1086 seemed to have massively powerful mecanums in 2007 & 2008, and what I've gathered from them is it's all about gearing and how you try to push 'bots around. If your bot is square to the bot you're trying to push, so long as your bot is geared properly there shouldn't be a problem in pushing the other bot. Traction (as defined by the ability to convert torque into forward movement, which takes the roller angle into account)) is still a matter of what the rubber rollers are made out of and not the angle of the rollers. Furthermore (and I just had this thought....), if your bot tries to push on the diagonal, (which should have the code only driving two motors at full speed), you only have 0.5 * 0.71 = 35% of the available total torque with the other two wheels acting as castors. This situation is probably where most people get their eye-witness accounts of 'mecanums can't push'. |
A middle set of driven wheels could be beneficial for tasks such as a ramp and stair climbing, but on a planar surface I question the advantage it gives. Quote:
In perpendicular (strafing) motion, it would (theoretically) have only 28.4% of the total torque, as the omni-wheels (which hold 60% of the bots weight) are only acting in the forward/reverse direction. Quote:
In this drive (once again assuming equal coefficients of friction and even weight distribution), 20% of the robots weight will be acting at 100% (driven mecanums), 40% will be operating at 71% (four driven omni-wheels operating at 45º), and 40% will be operating at 0% (undriven omnis and mecanums). That theoretically means you're effectively using 48.4% of your torque. Or just under what a standard mecanum would be using. Quote:
Remembering the previously posted sketches/pictures of the prototype, this drivetrain is rigged for keeping mecanum capability on ramps, as one end hinges. (Note: the hinge is right around the center axle). Doubles as suspension, too.
Now, here's the question: Are those axles running across the width of the robot? If so, is there any particular reason for them? I can see that one is rigged for rotational motion up and down, but not the other--was that just "I'm too lazy" or simply the way it's designed? |
#7
| pic: 1885's Drive Train Prototype | JesseK | Extra Discussion | 5 | 01-02-2009 02:11 |
| pic: Crab Drive Prototype Weekend Build | Alex698 | Extra Discussion | 9 | 13-01-2009 20:42 |
| pic: A closup view of our prototype worm-crab drive system. | AndyB | Extra Discussion | 6 | 20-01-2008 00:02 |
| pic: 213 - Drive prototype teaser | Tyler M. | Robot Showcase | 10 | 07-01-2007 20:56 |
| pic: Team 610 Off-Season Tank Drive Prototype | Jonathan Norris | Extra Discussion | 14 | 06-11-2006 01:59 |
