Go to Post Keep arrogant, belittling and misspelled bragging off these boards. - Mike [more]
Unread 27-08-2009, 11:23
Rion Atkinson's Avatar
Rion Atkinson Rion Atkinson is offline
The CAD Guy
Rion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond repute
pic: 6WD Chassis
Unread 27-08-2009, 11:25
Jared Russell's Avatar
Taking a year (mostly) off
Re: pic: 6WD Chassis
1) Great job! Thanks for sharing.
2) You could probably eliminate some of those vertical supports and still have sufficient frame rigidity.
3) 59 lbs sounds a little heavy for what is pictured (are you including the battery in this weight?). What kind of material, e.g. wall thickness, is your structural tubing?
Unread 27-08-2009, 12:27
The vertical supports in the rear of the frame can be reduced/ be placed in larger increments depending on what goes on top. Also, based on the game, you'd always have the chance of removing the front cross rail and replacing it with an opening.
EricH suggested 1/8" wall tubing, but this was when Rion had a single tier frame (no vertical supports and no top half) so would 1/16" wall be sufficient in this two tier frame?(vertical supports with top half)
Unread 27-08-2009, 12:35
The CAD Guy
Thanks for the supports advice. I will definitely pull some out.
Ya.. i was thinking it was a little heavy... Yes the battery is included. The wood board... Inventor thinks that is Aluminum 6061, I can't find a wood option and it was originally going to be that.
The frame is made of 1" extruded aluminum(sides are 1/8").
Unread 27-08-2009, 13:29
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
You're going for the wide chassis footprint rather than the narrow.
You don't need 6 wheels to rocker a wide chassis - it turns fairly well with 4.
Unread 27-08-2009, 13:33
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
I would definitely keep 1/8" wall for the outside perimeter, and I would question the need for that upper deck. I like the battery box. You may consider flipping the battery around, and putting a mounting tab to hard mount the Anderson Powerpole connector to the box.
Having the middle wheel could be useful for games with ramps, such as 2006. 696 did a design similar to this, and it allowed them to use 3.5" wheels and have only 3/16" ground clearance, and still negotiate the ramp without high centering.
Unread 27-08-2009, 13:54
The CAD Guy
Actually. I will be designing a narrow as well. I figured I would "perfect", so to speak, the wide chassis first.
The upper deck is actually what I used to mount the AM SS....
Unread 27-08-2009, 16:36
BrendanB BrendanB is offline
AKA: Brendan Browne
FRC #1058 (PVC Pirates)
One suggestion, I wouldn't have the C'rio up against the front in case you get a hard it. It happens a lot. I don't think any team wants to have the most expensive piece of there robot be destroyed.
1058 PVC Pirates 2016 - xxxx
Unread 27-08-2009, 19:31
Dillon Carey's Avatar
Dillon Carey Dillon Carey is offline
6wd swerve, it has been done
AKA: TinyHippo
FRC #1625 (Winnovation)
Dillon Carey has a reputation beyond reputeDillon Carey has a reputation beyond reputeDillon Carey has a reputation beyond reputeDillon Carey has a reputation beyond reputeDillon Carey has a reputation beyond reputeDillon Carey has a reputation beyond reputeDillon Carey has a reputation beyond reputeDillon Carey has a reputation beyond reputeDillon Carey has a reputation beyond reputeDillon Carey has a reputation beyond reputeDillon Carey has a reputation beyond repute
What is the indent in the front for?
"More power 'till it breaks or you win."
- Keith Carey
Unread 27-08-2009, 19:44
The CAD Guy
Nothing really.. I could move it forward, but there is really no need.. Save weight! (Even if only around .5 lbs...)
Unread 27-08-2009, 20:58
Actually, many teams mounted their cRIO that way and even perpendicular to the ground. Even without zipties, I don't think any team had loose modules or a broken cRIO. It can take impacts pretty well.
Unread 27-08-2009, 22:17
AKA: TinyHippo
Ok, i was thinking you were trying to plan ahead for some sort of pick up system.
- Keith Carey
Unread 28-08-2009, 12:19
Taylor's Avatar
Taylor Taylor is offline
Professor of Thinkology, ThD
AKA: @taylorstem
FRC #3487 (EarthQuakers)
I assume the tabs along the sides are for bumper attachment. Given the limited hand space there, are you thinking cotter pins through bolts to hold them on?
Hi!
Unread 28-08-2009, 14:10
kramarczyk's Avatar
kramarczyk kramarczyk is offline
is getting his kicks.
AKA: Mark Kramarczyk
FRC #3096 (Highlanders)
kramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond repute
Yeah, the cRio has been known to take a beating.
http://decibel.ni.com/content/docs/DOC-6176
We used some quick release pins from McMaster-Carr (p/n 98320A140) on two robots this year. No bottom access required. We had zero perfomance issues and zero inspection issues (some of the inspectors actually liked them).
Mark
Brick walls are for other people. - Randy Pausch
Unread 28-08-2009, 16:49
AndyB's Avatar
AndyB AndyB is offline
Ambitiously Disappointing
AKA: Andy Burchardt
FRC #0171 (Cheese Curd Herd)
AndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond repute
Very interesting. I knew the cRio could take a hit, but that's unbelievable.
I would have no concerns about moving your cRio. Just make sure it's easy to access.
You'd be safe using 50 lb/ft^3 density for your wood panel. Aluminum is about 3 times that (I just looked up the densities for for particle board and 6061 aluminum for these numbers). http://www.engineeringtoolbox.com/wo...sity-d_40.html has a list of densities for various types of wood.
Team 171 :: Cheese Curd Herd :: College Mentor, 2008-Present
Team 269 :: CooneyTech Robotics :: Student, 2005-2007
pic: FRC1293 Prototype 6wd Chassis Thermal Extra Discussion 16 06-01-2009 23:12
pic: 6wd prototype chassis Collin Buchan Extra Discussion 7 03-01-2009 10:00
pic: 6wd prototype chassis Collin Buchan Extra Discussion 3 02-01-2009 14:14
pic: 6wd chassis - need feedback JHSmentor Extra Discussion 22 01-01-2009 14:20
pic: 6wd chassis spc295 Extra Discussion 21 10-11-2008 09:00
