Go to Post If I had a mul-let then I'd look like Andy Baker used to and that would be ba-ad, really ba-ad. - JaneYoung [more]
Unread 28-08-2009, 19:29
dpeterson3 dpeterson3 is offline
FRC #1178 (DURT)
dpeterson3 is a jewel in the roughdpeterson3 is a jewel in the roughdpeterson3 is a jewel in the roughdpeterson3 is a jewel in the rough
DIY drive belt
I just got a nice VCR (one with the time delay loops for professional recordings) for $2. I think it works except for one small problem. All the drive belts had disintegrated. Getting parts for the thing will be difficult and I can't order online anyway. I want to make some for it that might be a little better. What is the best way to make new ones. I know rubber bands don't work and I am not sure about thread.
Unread 28-08-2009, 22:31
vivek16's Avatar
vivek16 vivek16 is offline
Whoa! college pilot.
AKA: vivek
FRC #2264 (trojan robotics)
vivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond repute
Send a message via AIM to vivek16 Send a message via MSN to vivek16
Re: DIY drive belt
Maybe some pictures and size specifications would help?
-vivek
"we don't build robots, we build people"
Unread 28-08-2009, 23:13
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: DIY drive belt
Good luck! might find some O rings that will work at an auto parts store or plumbing supply, but it's not very likely.
Best bet is to find a belt kit for that VCR online and have someone order it for you
Unread 29-08-2009, 16:38
FRC #1178 (DURT)
Re: DIY drive belt
Only a few inches long. I would try to order some. This VCR is old enought I am not sure where to go for parts. I will not be able to get specs until tomorrow night. Grometts might work. I have used them in the past, but they are a little tight.
Unread 29-08-2009, 18:57
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
Re: DIY drive belt
Too bad you can't order online; O-rings or urethane round belting from McMaster would work perfectly here. Urethane round belting can be made to any length with just a knife and a lighter.
Art Dutra IV
世上无难事,只怕有心人.
Unread 30-08-2009, 14:29
gburlison gburlison is offline
gburlison is a name known to allgburlison is a name known to allgburlison is a name known to allgburlison is a name known to allgburlison is a name known to allgburlison is a name known to all
Re: DIY drive belt
http://www.smcelectronics.com/vcrrep.htm
Gordon Burlison - Mentor
662/Rocky Mountain Robotics
"Every silver lining's got a Touch of grey - Robert Hunter"
"No sense in being pessimistic, it wouldn't work anyway"
Unread 30-08-2009, 19:43
ChuckDickerson's Avatar
ChuckDickerson ChuckDickerson is offline
FRC #0456 (Siege Robotics)
Re: DIY drive belt
MCM has some VCR belts as well: http://www.mcmelectronics.com/search...VCR%20belts&T=
Unread 31-08-2009, 08:09
Re: DIY drive belt
D,
MCM is the place to go for parts but you better hurry. VCR's are using less and less of these parts and they get harder to find everyday. Only use an equivalent part. O-rings and other substitutes produce too much of a side load on the fragile bearings and plastic pulleys. Many of the belts are square to produce two flat sides to the pulleys. Before you replace the belt be sure to clean the pulley with some alcohol. If the belts have disintegrated, then the lubricant in some of the sintered bearings has likely dried out as well. Light synthetic oil will help there. Also look for the black grease on sliding parts and see if it is caked. MCM also sells a little jar of that stuff too.
Before you put any money into the repair, check the video heads. First look at them with a bright light. If there is a trailing black smear on the video head surface, then the video heads are worn to the point that they can't self clean. If the drum surface is clean, check for tip projection. Gently slide you finger sideways over the tip of the video heads (the little point inside the recess of the drum). You should feel a slight "bump" if there is sufficient tip. If the tip is barely perceptible, the machine is not worth adding anything to.
Can you give us the model and manufacturer?
Unread 01-09-2009, 08:56
FRC #1178 (DURT)
Re: DIY drive belt
The VCR is a JCPenny 5061 Two Head (an ancient beast). I was able to make a couple of the belts using surgical hose I cut into 8ths. It works for all but one belt. My parents suggested I use hair ties. I will try that as soon as I can get a few. They should hold up much better than rubber bands. I agree MCMaster would be better, but ordering online is a real pain for me.
Unread 01-09-2009, 10:03
Re: DIY drive belt
D,
MCM is not McMaster if that was your thought. It is a great electronic house and a place I do a lot of professional business. I would check around in your area and see if you don't have an electronic supply house that has a retail storefront. They should be able to help if nothing else works.
A quick search brought up http://www.gatewaycatalog.com/
Unread 01-09-2009, 20:38
DonRotolo's Avatar
Back to humble
FRC #0832
Re: DIY drive belt
Just got the MCM electronics catalog today: www.mcmelectronics.com. They Sell Belts
The problem with things like surgical tubing and such is that they stretch, causing wow and flutter in the signal, degrading its fidelity. Real urethane belts don't stretch.
SMC electronics looks to have a better selection, as posted by gburlison
Belt drive system Doctorwho Technical Discussion 12 17-07-2008 16:00
Belt Drive Pulleys Ice Berg Technical Discussion 8 03-06-2008 14:25
Belt drive esisso Motors 7 22-01-2008 23:19
Chain drive vs. cogged belt drive(timing belts) LordBritten Technical Discussion 24 20-12-2006 23:07
Drive belt Rachika Garcia Rules/Strategy 3 10-01-2006 21:19
