Go to Post Remember, if FIRST is your top priority, you need to look at your priorities. - Billfred [more]
Unread 28-08-2009, 16:56
BrendanB BrendanB is offline
AKA: Brendan Browne
FRC #1058 (PVC Pirates)
Re: pic: 6WD Chassis
Originally Posted by kramarczyk View Post
Yeah, the cRio has been known to take a beating.
http://decibel.ni.com/content/docs/DOC-6176
[/IMG]
WOW!!!!
That really does take a beating. Guess I now know what is the strongest part of the robot.
1058 PVC Pirates 2016 - xxxx
Unread 28-08-2009, 17:10
Rion Atkinson's Avatar
Rion Atkinson Rion Atkinson is offline
The CAD Guy
Rion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond repute
Originally Posted by Dillon Carey View Post
Ok, i was thinking you were trying to plan ahead for some sort of pick up system.
That was the original plan, but there isn't really enough room... I could always make the chassis bigger than 35 x 25...
Originally Posted by Taylor View Post
I assume the tabs along the sides are for bumper attachment. Given the limited hand space there, are you thinking cotter pins through bolts to hold them on?
Pretty much yes.
Unread 28-08-2009, 17:19
The CAD Guy
Originally Posted by AndyB View Post
You'd be safe using 50 lb/ft^3 density for your wood panel. Aluminum is about 3 times that (I just looked up the densities for for particle board and 6061 aluminum for these numbers). http://www.engineeringtoolbox.com/wo...sity-d_40.html has a list of densities for various types of wood.
The only problem is wood is not an option to choose from.. And I don't if you can manually change the density in Inventor...
Unread 28-08-2009, 21:19
You can. I forget how, but you can. And if wood isn't an option, then I just lost respect for Inventor. You go into the properties, and pick your type of wood--pine or oak should do the trick. (It doesn't have "wood" as an option because every wood is a different type of wood, and has a different density.)
Unread 28-08-2009, 23:20
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Somehow we modeled ours in Inventor last winter...huh....
http://www.chiefdelphi.com/forums/sh...ad.php?t=71902
Unread 29-08-2009, 13:19
The CAD Guy
I went through all materials. Not a single type of wood. In the 2009 Inventor There was. They were listed as "Wood (Pine)" or "Wood(Oak)". But when they upgraded to 2010 they must have take it out...
It is possible to just change the texture (As I did). But odds are you made it in 2009.
Unread 29-08-2009, 14:15
Are there certain add-ins that you don't have enabled? I don't use Inventor but just a suggestion.
Unread 29-08-2009, 15:34
GUI GUI is offline
AKA: Gary
FRC #4183 (Bit Buckets)
GUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to behold
Send a message via Yahoo to GUI
I don't remember exactly where it is, but in the iProperties of a part you can change the density to a custom value.
Unread 29-08-2009, 16:39
The CAD Guy
No. All the other add-ins not enabled are just converters for other CAD programs..
I went through all the IProperties.. Couldn't find it...
I think its time to switch to solidworks..
Unread 29-08-2009, 17:08
MrForbes's Avatar
AKA: Jim
You definitely want to be using a wood friendly modeling program. Wood is where it's at.
Unread 29-08-2009, 17:13
The CAD Guy
Maybe I'll switch back to Inventor 2009 until I can get solidworks somehow....
Unread 29-08-2009, 19:25
R.C.'s Avatar
R.C. R.C. is offline
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
Just to Support Solidworks. One of the main benefits with Solidworks is that it is used more in the industry. In our area 12 out our 15 sponsoring (Engineering Companies) companies use Solidworks. Most of their partners use it also.
Also Solidworks has a wide range of add ins and the workflow is Fantastic. If you want a Copy of Solidworks, Marie Planchard would be the person to contact, Solidworks Rep for FIRST.
-RC
R.C.
MadTown Robotics Team 1323
pic: FRC1293 Prototype 6wd Chassis Thermal Extra Discussion 16 06-01-2009 23:12
pic: 6wd prototype chassis Collin Buchan Extra Discussion 7 03-01-2009 10:00
pic: 6wd prototype chassis Collin Buchan Extra Discussion 3 02-01-2009 14:14
pic: 6wd chassis - need feedback JHSmentor Extra Discussion 22 01-01-2009 14:20
pic: 6wd chassis spc295 Extra Discussion 21 10-11-2008 09:00
