Go to Post Do I think the bar is too high? I think impossible dreams and lofty goals are a key part of FIRST; the "top" being extremely far away only pushes people farther. - Chris is me [more]
Unread 30-08-2009, 20:39
ajlapp ajlapp is online now
AKA: Anthony Lapp
None #0118 (Team RUSH and Robonauts)
ajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond repute
pic: Revolution Co-Axial Swerve Module - Team 221 LLC.
Unread 30-08-2009, 20:41
Jared Russell's Avatar
Taking a year (mostly) off
Re: pic: Revolution Co-Axial Swerve Module - Team 221 LLC.
I'm curious if you've had a chance to test these out. I'd be worried about side loads on the wheel modules (for example, when turning rapidly at full speed).
Unread 30-08-2009, 23:00
sdcantrell56's Avatar
AKA: Sean
FRC #2415 (Wired Cats)
I don't see any method for tensioning the chain either. WHat do you have planned for that?
Mentor 2415
Unread 30-08-2009, 23:26
AdamHeard's Avatar
Lead Mentor
With shorter chain runs and decent manufacturing tolerances you can do exact Center to center distances. Both 118's and our crab modules work this way I believe.
Unread 30-08-2009, 23:33
330 does this in 6WD skid steer... And then puts a tensioner in to make sure.
Unread 31-08-2009, 03:08
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
If you need a tensioner, then it doesn't actually work, right?
2001-2004: Team 100
2006-Present: Team 254
Unread 31-08-2009, 03:17
Actually, it does... The tensioner is usually an encoder's sprocket. The only way to tension the chain is to move the encoder...
Also, remember that the chain can stretch slightly if it's used in a high-stress area like the drive.
Unread 31-08-2009, 06:45
sgreco's Avatar
sgreco sgreco is offline
AKA: Steven Greco
FRC #2079
sgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond repute
I personally wouldn't be too concerned about the chain, my team went the entire year with a swerve drive and no chain tensioning in the modules and never oncer had a problem with it. My team used 25 chain, which appears to be what it is in the picture, the Robonauts use 35, but either way it shouldn't make a difference. My team's chain did stretch, but through 3 competitions, they never stretched enough to require that they were changed.
It looks really nice though. (Any estimate on cost?)
The only concern I would have whould be on how thin the modules gets at the bottom. I'm not too good at eyeballing, but I'm guessing the side plates are 1/4 inch.
Unread 31-08-2009, 08:59
AKA: Anthony Lapp
These units have not been tested, but I know from experience working and talking with frc118 that they have had module damage due to side loads. Some other designs have addressed this by using much larger cross-sections or creating the wheel saddle from billet....I'm not sure how I'll proceed with this design.
There is no chain tensioning feature designed in. A certain amount of sprocket wear is expected. There is plenty of sprocket wrap to deal with it in my opinion.
Robonauts used #25 chain this season for the final drive without a tensioner.
There is no price on these units. Initial estimates make these far to expensive to manufacture. Miter gears are quite expensive, as are the large turned components.
Anthony Lapp
FIRST Engineering Mentor
Owner/Operator 221 Robotic Systems
221 Robotics Systems - Quality Hardware, Made in the USA
RobotOpen
anthony@221robotics.com
Twitter us: @221RobotSystems
Team 1 --> 94 --> 68 --> 221 --> 857 --> 27 --> 118
Design Engineer/Fabricator and 17 year vet
Team Rush (FRC27) and Robonauts (FRC118)
Unread 31-08-2009, 15:21
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
What supports the side loads on the horizontal shaft caused by the bevel gear?
You normally don't want to side-load axial bearings, so I've been scared of using e-clips on the ends of the shaft and having them pushing against the inner race of the axial bearings at each end.
Unread 31-08-2009, 15:28
AKA: Anthony Lapp
The frc118 plan calls for thin walled bushings that hold the miter gear in location and push the thrust loads against the inner race of the bearing.
The prototype pictured has snap rings holding the miter gear in place. The same will be true for the drive sprocket, though they are currently not in place.
Anthony Lapp
RobotOpen
Cyber Blue and Team 221 LLC "Wild Swerve" Chris Fultz General Forum 27 08-02-2010 14:47
pic: Team 221 LLC. - Wild Swerve Module ajlapp Extra Discussion 77 06-11-2009 17:33
Team 221 LLC. Partnership Opportunity ajlapp General Forum 0 08-01-2009 08:30
Team 221 LLC. Universal Chassis In Stock ajlapp General Forum 23 02-01-2009 09:07
