Go to Post Too often we like to forget that it takes an insane amount of hard work to even have a chance to overcome raw talent. - Paul Copioli [more]
Go Back   Chief Delphi > Other > Chit-Chat > Games/Trivia
Unread 31-08-2009, 18:59
Pat Fairbank's Avatar
Pat Fairbank Pat Fairbank is offline
Circuit Breaker
Pat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond repute
Send a message via MSN to Pat Fairbank
Re: Brute Forcing Encryption
Here's the code I used for my solution. Note that since I'm not in any way a Python guru, there may be a more elegant and/or faster solution; I just didn't want to take the time to figure out how to do hashes in C/C++.
import hashlib
import time
hash = '5bd4c87976f48e6a53919d53e14025e9'
digits = [65, 65, 65, 65, 65, 65]
t0 = time.clock()
while 1:
  phrase = ''
  for i in range(0, 6):
    phrase += chr(digits[i])
  if hash == hashlib.md5(phrase).hexdigest():
    print phrase
    break
  for i in range(5, -1, -1):
    digits[i] += 1
    if digits[i] == 123:
      digits[i] = 65
      continue
    if digits[i] == 91:
      digits[i] = 97
    break
print time.clock() - t0
This was run on a 2 GHz Core 2 Duo; I ran two instances of the script at the same time so as to use both cores, with one starting at AAAAAA and the other at aAAAAA. I imagine that if you had access to something like MapReduce it would go a whole lot faster.
Patrick Fairbank
Team 254 | Mentor (2012-)
Team 1503 | Mentor (2007-2011)
Team 296 | Alumnus (2001-2004) | Mentor (2005-2006)
patfairbank.com
Forcing autonomous to run Tim Arnold Programming 2 05-04-2007 20:40
Encryption Cracking Talk. Joe Johnson Rules/Strategy 4 08-01-2006 17:17
Forcing a Cable Modem to get a new IP sanddrag IT / Communications 13 02-11-2005 06:10
pdf encryption buss Programming 2 06-01-2005 23:11
Brute Force... Andy Grady Rules/Strategy 1 12-02-2002 22:19
