Go to Post The Manual is the "requirements document" for your project. - dlavery [more]
View Poll Results: How do you choose values for tank drive?
Mathematically (Please define below) 5 29.41%
Path based 3 17.65%
Experimentation 8 47.06%
Other 3 17.65%
Multiple Choice Poll. Voters: 17. You may not vote on this poll
Unread 02-09-2009, 00:02
biojae's Avatar
biojae biojae is offline
Likes Omni drives :)
AKA: Justin Stocking
FTC #5011 (BOT SQUAD) && FTC#72(Garage bots)&& FRC#0399 (Eagle Robotics)
biojae is a jewel in the roughbiojae is a jewel in the roughbiojae is a jewel in the rough
Tank Steering
I have noticed that most of the robots here use a skid steering drive.
How do most teams decide which values to use in the autonomous mode for getting to a location on the field?
FTC Team 72 - No site
FRC Team 399 - http://www.team399.org
2010 Rockwell Collins Innovation in Control Award - (Use of the CAN bus, among other reasons) Phoenix, Arizona!
Unread 02-09-2009, 00:13
Chexposito's Avatar
Chexposito Chexposito is offline
AKA: Expo
FRC #1730
Chexposito is a glorious beacon of lightChexposito is a glorious beacon of lightChexposito is a glorious beacon of lightChexposito is a glorious beacon of lightChexposito is a glorious beacon of lightChexposito is a glorious beacon of light
Re: Tank Steering
we have switches on the robot to flip to indicate what positition it is at. our programers found it easier to do that
Unread 02-09-2009, 00:15
biojae's Avatar
Re: Tank Steering
so, then its just experimented values?
Unread 02-09-2009, 00:21
Chexposito's Avatar
AKA: Expo
FRC #1730
Re: Tank Steering
yes and no, we had a lot of encoders on our robot so we knew exactly how far it went, but the turning we did was experimental. (we had a crab drive)
here's a pic: http://www.teamdriven.us/media_page/...s/102_2390.jpg
Unread 02-09-2009, 00:28
biojae's Avatar
Re: Tank Steering
oh, crab has several advantages over tank for navigation.
I wish that kinematically modeling a skidsteer was easier for navigation.
If my team would use crab, I would already have made a navigation model, and have a route planning algorithm.
Navigation with skid steer is harder, and it seems no teams have done much with it
Unread 02-09-2009, 00:33
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Tank Steering
almost requires some type of position/orientation feedback, eh?
Skids are difficult to predict.
Unread 02-09-2009, 00:35
biojae's Avatar
Re: Tank Steering
A combination Gyro, encoder, + inertial mesurements?
Unread 02-09-2009, 00:41
AdamHeard's Avatar
Lead Mentor
Re: Tank Steering
Pretty solid results have been achieved with just encoders and a gyro. I think the entire 08 season was a testament to this.
Unread 02-09-2009, 00:48
biojae's Avatar
Re: Tank Steering
so just a simple formula like
X pos = X0 + (((Left encoder + Right encoder)* wheel radius) /2 ) * cos(Gyro Theta)
Y pos = Y0 + (((Left encoder + Right encoder)* wheel radius) /2 ) * sin(Gyro Theta)
Unread 02-09-2009, 00:58
Re: Tank Steering
This year, 971 integrated the ground speed sensors to get our position. We couldn't measure sideways sliding, though one more sensor and vex omni wheel would have dealt with that. Our programmer then wrote a PD loop to get the robot to follow a spline.
One of the most important lessons he learned during this process is that it helps a lot to have plots on your computer showing what you wanted, and what the bot did. He used the dashboard port, a piece of ruby code, and Gnuplot to get the data back and display it.
An easy way to go to a position on the field is to write a PD loop that controls the steering to get the angle right, and apply forwards power to get to the point. If you care if you stop there, you'll then need some sort of control for the throttle as well. A simple way to follow a path is to string these points together and move on to the next one when you get close to the first one. This all assumes you have encoders and/or gyros to measure where you are.
Unread 02-09-2009, 01:08
Re: Tank Steering
Our best results have been from gyros, ecoders, PD loops and PID.
Once StanGPS was released people learned A LOT about how to write a good autonomous.
Unread 02-09-2009, 01:49
biojae's Avatar
Re: Tank Steering
Could an accelerometer account for the deflection?
and how was the spline calculated?
That sounds like an application for a touchscreen dashboard
The steering seems to me the hardest part. What variables did the PD loop control ?
Unread 02-09-2009, 07:51
Re: Tank Steering
Crab steering should be no harder than any other steering and perhaps more easy. You need to know how far the wheels have driven (preferably more than one to increase accuracy), which direction the steering is turned and where you want the robot to be at various intervals. The big variables occur when you run into objects on the field like goals and other robots. With other steering methods you have to compensate for turning radius when moving in other than a straight line.
As far as travel, we have used wheel encoders, either scratch built optical or off the shelf rotational encoders. The data is then used in calculating the distance traveled by incorporating wheel circumference and rotations. Steering is a simple pot but you should have used that already for feedback control with manual steering. A gyro will help you to maintain preset way points and can help in collision correction. We used one to great effect during 2003 when climbing the ramp in auto.
Unread 02-09-2009, 09:08
AKA: Lars Kamen's Roadie
FRC #0051 (Wings of Fire)
Re: Tank Steering
That's a pretty bold claim, as well has a VERY inaccurate one. A lot of teams have been doing skid steer navigation since autonomous began in 2003.
Here's the best advice I can give you: do NOT put your encoders on your drive wheels - put them on non-driven "dummy" wheels that do nothing but measure distance. By using non-driven wheels, all of the skidding and associated wheel slippage do not influence the measured distance.
Unread 02-09-2009, 09:29
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
Re: Tank Steering
I'm pretty sure '08 bots who could run around the field multiple times used more than just gyros and encoders (...like human IR control...).
That said, in the quadrotor world there's only 1 way to go: Butterworth-filtered accelerometers and redundant gyros that failover. The filters help to reduce noise at the circuit level. The gyros are on a reset circuit that resets their power every N seconds to reduce slop (and there's another issue...can't remember the name...where over time their readings become more offset). While one is resetting, the other has valid data. I'm not the circuit genius behind this ... I'm the one who integrated the architecture together to make everything work together as 1 system
In the FRC world, we've used encoders and gyros with success (2007) and failure (2008). Encoders give a # of ticks per rotation, and that can translate into inches per tick. If you poll the gyro every N milliseconds, you can use some trig (using lookup tables on those systems) to calculate your position with pretty good accuracy. Accelerometers have generally been too noisy to be accurate for planar field positioning in our experience. This year we will probably use filters with them for angular arm positioning (shh, don't tell my team that ... ).
GitHub
need glp programing steering with a steering wheel Matchew Programming 2 10-02-2003 14:20
Under or Over? To tank or Not to tank that tis the question! archiver 2001 2 23-06-2002 22:53
Single Joystick Tank Steering archiver 2001 5 23-06-2002 22:49
tank or go-cart style steering? archiver 2001 17 23-06-2002 22:42
tank steering archiver 2000 10 23-06-2002 22:28
