Go to Post Adding an ounce or two of shields is way easier than filling out the mountains of paperwork for that one impatient person to stick their arm into the robot reaching for who knows what only to have their fingers meet up close and personal with a gearbox. - artdutra04 [more]
Unread 03-09-2009, 10:25
[BB] So, what about the Classmate?
http://frcdirector.blogspot.com/2009...classmate.html
Thoughts?
Unread 03-09-2009, 10:38
Re: [BB] So, what about the Classmate?
It's an interesting list of stuff that won't be in veteran teams' kits. I don't think some of it will hurt at all, like the joysticks, because there are plenty of USB joysticks out there. But the one that got me was the compressor. The control system was expected; we've been told about that for at least a year. But the compressor? I just hope that they give a link to a place that can supply them, just in case of one breaking. (Note: I don't know of a single compressor failing since they were introduced to FRC. That's a pretty good record of reliability...)
Unread 03-09-2009, 10:55
Chris is me's Avatar
AKA: Pinecone
So the document Bill linked to would say the new team 47-65 or whatever it ends up as would retain Hall of Fame status, but not necessarily championship elgibility as that's determined by number? Bit of a sidetrack though.
The parts they want us to reuse seem completely reasonable. It'd be nice if we could keep the 2009 driver station completely together, but the teams that preserve robots to demonstrate and drive around are the same teams that can afford to drop a few dollars here and there on replacement joysticks (or didn't use them at all). The KoP joysticks this year were excellent, though.
Classmate PC is a fine replacement for the Driver Station. Hopefully there will be less dead Ethernet ports and electrical shorts. Touchscreen autonomous options as well as other fun control stuff, the possibilities could be endless there.
I'm glad for the electronic Consent forms, in case I don't get to a 1714 meeting before Kickoff.
Unread 03-09-2009, 11:42
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
It only has 2 USB ports...
Not sure how this will affect teams who use 2 joysticks and/or a custom button board setup. Eventually teams will overcome this with custom circuitry. Eventually.
GitHub
Unread 03-09-2009, 11:53
They withheld the compressor from the KOP for veterans once before.
As I recall we only whined because we had to disable an older robot to reuse it's compressor, and that's already going to be happening for most teams as the control system comes off.
I've seen compressors damaged from overtightening the emergency pressure relief valve thus cracking the case, and others succumb to general abuse, but I haven't had one wear out. We have one that started working intermittently a couple of years ago, probably due to a bad thermal switch.
I doubt obtaining replacements will be an issue (Thomas Industries 405ADC38/12).
It is $314 though, so I can see the savings for FIRST HQ ($314 x 1677 = $526,578 w/o bulk discount or donation - equivalent to the registration fees for 105 teams):
http://www.drillspot.com/products/35..._Va cuum_Pump
http://cfpwarehouse.com/shopsite_sc/...mpressors.html (pictures wrong but price is better @ $266)
Refurbish an old one for $108: http://www.mastertoolrepair.com/405adc3812-p-4070.html
P.S. Somebody in Lockport, NY sold one on eBay for $108
Unread 03-09-2009, 12:03
Originally Posted by Bill's Blog
The Classmate will be the primary feature of the 2010 Driver Station (connected to some other items to be revealed later).
(emphasis added).
USB hubs are cheap and readily available. Don't forget that NI makes USB analog and DIO data acquisition devices. I wouldn't be so quick to assume that the burden would be on the teams.
Unread 03-09-2009, 12:14
I wonder how long it takes to boot the classmate?
Nothing like holding up a match while we wait for a reboot.
I can see batteries flagging at inopportune times without power at the driver stations.
If they don't supply power I think I'll look at carrying a few spare charged batteries for teams.
Unread 03-09-2009, 23:06
Molten's Avatar
Molten Molten is offline
AKA: Jason
FRC #1766 (Temper Metal)
So, anyone think this might translate to cheaper kits? It only seems fair.
"Curiosity. Not good for cats, great for scientists."- Numb3rs
"They can break your cookie, but... you'll always have your fortune."-T.W. Turtle, Cats Don't Dance
"Tell my tale to those who ask. Tell it truly - the ill deeds along with the good, and let me be judged accordingly. The rest... is silence."-Dinobot, Beast Wars
"Though the first step is the hardest and the last step ends the quest, the long steps in between are certainly the best."
–Gruffi Gummi, Disney's Adventures of the Gummi Bears
Unread 03-09-2009, 23:14
It wouldn't have to be the specific 09 compressor would it? I really hope not.
Unread 03-09-2009, 23:42
Arrow Re: [BB] So, what about the Classmate?
They are cheaper this year. Registration is only $5000 for veteran teams this year.
Unread 03-09-2009, 23:46
Molten's Avatar
AKA: Jason
Glad to hear it. I really should follow Bill's blog.
Unread 04-09-2009, 03:01
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
But we have to buy $1500 worth of stuff to get the same kit we had last year.
Isn't progress great?
2001-2004: Team 100
2006-Present: Team 254
Unread 04-09-2009, 12:10
Kims Robot's Avatar Unsung FIRST Hero
Kims Robot Kims Robot is offline
Onto a New Chapter...
AKA: Kim O'Toole Eckhardt
Kims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond repute
Send a message via AIM to Kims Robot
One would guess that either
1. FIRST was getting more of a discount on the parts than they are passing onto us (ie maybe they got compressors for free??)
or
2. FIRST is actually making out on this deal... paying less for the kit, but passing on a lesser savings to us (ie reaping the $500 towards their own use... Im seriously hoping they are using that to build up their grant program)
Either way... I'm not a fan of the withholding/reuse... I would rather see teams have the election option (ie my team would pay the $6K to get a new controller and all those parts, other teams could elect to save the $1K and not get them).
~kim~
Kimberly O'Toole Eckhardt <3
Principal Systems Engineer & Program Manager
History - Team 176, Team 229, Team 1511, FIRST Volunteer!!
My new FIRST Photography Hobby & Angry Eric's Fan Page
Excellence - is the result of caring more than others think is wise, risking more than others think is safe, dreaming more than others think is practical, and expecting more than others think is possible.
Unread 04-09-2009, 12:23
Molten's Avatar
AKA: Jason
I like this idea. I'd probably elect for the savings, but I'd like other teams to get to choose.
Also, my guess is with the current economy...some companies aren't willing to make such good deals for such a big quantity and the amount FIRST pays for the parts went up. So, they had to increase the cost of the kit to $6500. However they decided to allow a discount for teams that could afford to do without the part and Dean pitched in the money to make it fair for rookies.
Unread 04-09-2009, 12:38
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
or
Don't forget that it's $6,500, in reality. Costs increased, but by withholding pieces of hardware, FIRST is able to reduce what we're paying at the same time as they reduce what we receive. It's no great bargain.
--Madison--
...down at the Ozdust!
Classmate PC - Front Panel jmanela NI LabVIEW 28 23-08-2009 20:36
What about the awards? formerfirster General Forum 4 30-04-2002 02:13
help an oversleeper - what is the game about? ninratmny General Forum 5 05-01-2002 19:05
What about the new rules CMC Rumor Mill 16 27-10-2001 06:34
what about the drill motors? Ken Leung Motors 2 26-06-2001 02:11
