Go to Post The more rookies the better, they always think of the things that we dont - pakrat [more]
Go Back   Chief Delphi > Competition > Championship Event
  #38   Spotlight this post!
Unread 08-09-2009, 08:38
Re: How many Robots at the nationals had an operational Camera Track Autonomous?
I never tried an additional IR filter. The lens from the mfgr has one built in. Do you have any before and after images, or values?
As for the polarizer, they are useful when the light is polarized, otherwise they are equivalent to a neutral density filter (a gray piece of glass). The atmosphere polarizes the sunlight to some degree, so polarizing outdoors is pretty effective for blocking glare more than other light. Indoor lighting is not polarized.
The wide angle lens helps with seeing more of the field without panning the camera. I saw some put lenses in front of the camera, others replaced the lens. If you replace it, beware to get an IR filter.
Anything else?
Greg McKaskle
how many people have had failing jaguars bluebird Motors 127 04-03-2010 23:28
How many teams had router problems? darkember Technical Discussion 8 31-01-2009 21:22
How many teams are using the Camera? Matt Goulart Electrical 3 30-01-2005 09:29
how many of u actually used the stacker if u had one? HolyMasamune General Forum 21 14-04-2003 13:12
How many robots on the bar in one match? archiver 2000 14 23-06-2002 22:39
