Go to Post If you base a team on how well you do on the field you have a much harder time winning. - Bob Steele [more]
Go Back   Chief Delphi > Competition > Championship Event
  #31   Spotlight this post!
Unread 06-05-2009, 09:58
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Re: How many Robots at the nationals had an operational Camera Track Autonomous?
I suspected most teams that were having success with the camera were using C++. We spent a lot of time working with the camera in labview. Sometime we could tune it so it worked perfectly. Then the slightest change in the lighting would wipe our progress out.
I'm hoping to have time to dissect the labview code and understand how they're doing it. It's pretty complex. I'm certain fundamentally the programming language shouldn't matter, so it's mainly all about comparing the implementations in both C++ and labview.
  #32   Spotlight this post!
Unread 30-06-2009, 15:11
youngWilliam14's Avatar
youngWilliam14 youngWilliam14 is offline
Team 461 Electrician and Operator
AKA: Will Crabtree
Team Role: Electrical
youngWilliam14 has much to be proud ofyoungWilliam14 has much to be proud ofyoungWilliam14 has much to be proud ofyoungWilliam14 has much to be proud ofyoungWilliam14 has much to be proud ofyoungWilliam14 has much to be proud ofyoungWilliam14 has much to be proud ofyoungWilliam14 has much to be proud of
Send a message via AIM to youngWilliam14
i'm not the team programmer, so i don't know anything about our code, but we did score 6 moonrocks in autonomous
Edit: it only happened once. we were consistently tracking opposing trailers in autonomous though
"C.N.C." lyrics/"Driving on Regolith" lyrics
Let's all go nuts! Robots! Robots!--Team 461 chant
  #33   Spotlight this post!
Unread 30-06-2009, 15:26
SushaK's Avatar
SushaK SushaK is offline
AKA: Susha The Russian
SushaK has a spectacular aura aboutSushaK has a spectacular aura about
Send a message via AIM to SushaK
461 had a successfully tracking robot and as mentioned above scored 6 moonrocks in autonomous during one of the matches. our programmers keep expanding their skills and are getting really great at getting the robot to do everything that we want it to accomplish... they even help other teams out!
Go 461!
BOILER UP!
  #34   Spotlight this post!
Unread 03-09-2009, 22:27
ShotgunNinja's Avatar
ShotgunNinja ShotgunNinja is offline
Programming Mentor, FRC 4247
AKA: Nicholas Iannone
FRC #4247 (CougarBOTS)
ShotgunNinja is a jewel in the roughShotgunNinja is a jewel in the roughShotgunNinja is a jewel in the roughShotgunNinja is a jewel in the rough
I think that it must have something to do with the visual nature of LabVIEW pushing people to use the visual side of the brain, which can get pretty cluttered when trying to conceptualize a camera control system. Not to mention how C++'s OOP paradigm lets you reimplement the camera controller into your own custom class the way that you conceptualize it best. It's like the difference between C and C++, except that in C the programs actually have a greater chance of not having bugs than C++.
P.S. LabVIEW doesn't qualify as a programming language!
Team #2970 Alum
Team #1652 Alum
2006: School Mascot for Team 1652
2007-2008: Programmer for Team 1652 (Robot Mafia)
2009: Programmer on Team 1652 (Robot Mafia), Programmer on Team 2970 (eSchool eBots)
2010-2016: Volunteer, Wisconsin Regional
2017: Programming Mentor, FRC 4247 (CougarBOTS, Obama SCTE, Milwaukee, WI)
  #35   Spotlight this post!
Unread 07-09-2009, 09:23
I think that it must have something to do with the visual nature of LabVIEW pushing people to use the visual side of the brain, which can get pretty cluttered...
Yeah, that must be it. By that argument, CADing up the robot must be a really bad idea.
Here we go again. Technically you are right, though. LabVIEW is a tool that is used to write G code. G is the language, even though most people call it by the product's name.
If you have learned LabVIEW well enough to criticize it, give it a shot. Explain why it isn't a programming language. While you are at it, explain what a programming language is.
On the vision tracking topic, has anyone started comparing the approaches and determining the key elements that led to success? I did a number of presentations in Atlanta, and I have my list of things.
Greg McKaskle
  #36   Spotlight this post!
Unread 07-09-2009, 09:57
Chris is me's Avatar
AKA: Pinecone
I believe he was being facetious with that comment about LabView's status as a programming language, he probably doesn't prefer it though.
I doubt camera tracking autonomouses failed based on anything other than varied lighting conditions and lack of incentive to do so; 70 / 494 were the only teams I saw do it, though if I recall correctly 2056 tracked. If points were worth double in auto or something then I bet you'd see more teams do it instead of loading in autonomous, but loading paid off way more.
  #37   Spotlight this post!
Unread 07-09-2009, 11:36
Nick Lawrence's Avatar
Nick Lawrence Nick Lawrence is offline
Commander Canada
FRC #3940 (CyberTooth, AndyMark)
Nick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond repute
We worked all year on our vision system, and it worked pretty well. We did not use it during auto. We had a piezo buzzer attached to our operator's gamepad, which would sound whenever we were relatively close to a trailer we could score on, during Teleop. We also had a button on our pad that, if held, would automatically dump balls, if I had driven into a correct trailer and was locked on to it.
At nationals, it worked about 80% of the time, when it was sunny out.
-Nick
Alumnus of 1503 Spartonics
Founding Mentor of 5406 Celt-X
Mechanical Design Mentor of 3940 CyberTooth
Emceeing events since 2013 - come say hi!
Success doesn't always equate to match wins. It's about the wins off the field.
  #38   Spotlight this post!
Unread 07-09-2009, 12:16
Something pretty cool we tried along with 1771 was adding on an IR blocking lens onto the camera. The camera values came out much clearer and tracking did work a little better. With calibration, 1771 had some better luck, we did not, but still chose to load in auto. The lenses were from some special military grade goggles (I totally forget what they actually were) donated by 1771's sponsor.
  #39   Spotlight this post!
Unread 07-09-2009, 12:19
NickE's Avatar
NickE NickE is offline
_
192 had an operational camera tracking autonomous at the Silicon Valley Regional, but they weren't at the Championship.
  #40   Spotlight this post!
Unread 07-09-2009, 13:38
AKA: Pinecone
One thing my team wanted to try was putting a polarized lens over the camera. A 1732 mentor suggested it to us in Wisconsin, but shortly thereafter we gave up on the camera (before we could get one and try it).
  #41   Spotlight this post!
Unread 07-09-2009, 14:03
Commander Canada
I know that a couple teams put a fish-eye lens over the camera, due to the rather limited field of view. It seemed to work pretty well for them.
-Nick
  #42   Spotlight this post!
Unread 08-09-2009, 04:09
rwood359 rwood359 is offline
AKA: Randy
FRC #0359 (Hawaiian Kids)
rwood359 is a name known to allrwood359 is a name known to allrwood359 is a name known to allrwood359 is a name known to allrwood359 is a name known to allrwood359 is a name known to all
This shows how awesome 192's autonomous was at the Hawaii Regional.
They start in the top right corner steer toward the center, make a major course correction and score (just off camera).
http://www.thebluealliance.net/tbatv/match/2009hi_qf1m1
  #43   Spotlight this post!
Unread 08-09-2009, 05:50
gallo26's Avatar
gallo26 gallo26 is offline
Team 79 Alumni
AKA: Bryan Gallo
FRC #0079 (Team KRUNCH)
gallo26 is a name known to allgallo26 is a name known to allgallo26 is a name known to allgallo26 is a name known to allgallo26 is a name known to allgallo26 is a name known to all
Send a message via AIM to gallo26
Team 79 used the camera (like posted in the beginning) but it never really worked properly. Then we had a match at the North Star Regional in Minnesota.... and once it tracked a trailer... it drove itself the whole match. I couldn't even drive it... quite funny to watch our robot skynet us, even tho it didnt make a score.
Team 79 Alumni '11- Present
Team 79 Driver '09, '10
Team 79 Senior CAD Designer '09, '10
Team 79 President '09
Team 79 Electrical Sub Team Leader '08, '09
  #44   Spotlight this post!
Unread 08-09-2009, 08:38
I never tried an additional IR filter. The lens from the mfgr has one built in. Do you have any before and after images, or values?
As for the polarizer, they are useful when the light is polarized, otherwise they are equivalent to a neutral density filter (a gray piece of glass). The atmosphere polarizes the sunlight to some degree, so polarizing outdoors is pretty effective for blocking glare more than other light. Indoor lighting is not polarized.
The wide angle lens helps with seeing more of the field without panning the camera. I saw some put lenses in front of the camera, others replaced the lens. If you replace it, beware to get an IR filter.
Anything else?
Greg McKaskle
  #45   Spotlight this post!
Unread 08-09-2009, 13:32
martin417's Avatar
Opinionated old goat
AKA: Martin Wilson
The filter we used was actually a lens from a pair of laser safety goggles. We use IR lasers at work, and have safety goggles to prevent eye injury. What we found is that the incandescent lighting that First uses at events is very heavily weighted towards the IR end of the spectrum, so filtering out a bunch of the IR helped leave bandwidth for the colors we wanted to detect.
In addition, we used a fisheye lens to give us a wider field of view.
Former Mentor Team 1771
Former mentor Team 4509
how many people have had failing jaguars bluebird Motors 127 04-03-2010 23:28
How many teams had router problems? darkember Technical Discussion 8 31-01-2009 21:22
How many teams are using the Camera? Matt Goulart Electrical 3 30-01-2005 09:29
how many of u actually used the stacker if u had one? HolyMasamune General Forum 21 14-04-2003 13:12
How many robots on the bar in one match? archiver 2000 14 23-06-2002 22:39
