Go to Post Work hard. Then work even harder. Work until there is nothing left to work on, then work more. - RoboChair [more]
Unread 07-07-2002, 20:07
Jordan A.'s Avatar
Jordan A. Jordan A. is offline
#0781 (Kinetic Knights)
Jordan A. is an unknown quantity at this point
Send a message via ICQ to Jordan A.
Variable Amperage in DC Circuit. How?
see title, how do you vary the amperage in a DC circuit?
Thanks.
-Jordan
Unread 07-07-2002, 21:17
jon jon is offline
jon has a spectacular aura aboutjon has a spectacular aura aboutjon has a spectacular aura about
I'm not claiming this is at all right, I am by no means an expert in this area... yet... but, it could be right, maybe, if I'm lucky. Someone let me know if it is and i'll be happy.
Knowing that....
I= E/R
I = current (amps)
E = electromotive force (volts)
R = resistance (ohms)
...couldn't some variable resistors do the trick?
Unread 07-07-2002, 21:29
D.J. Fluck
Posts: n/a
Jon basically said it with varying R (resistance) in the ohms law V= IR....
Other info
heavier wires = less resistance = higher current carrying capability. The inverse is true as well, lighter wires = more resistance = less current carrying capability
Ya so that should sum it up
(Thanks to Rich from 93 for the clairification)
Unread 08-07-2002, 08:02
There are many answers to this question. The speed controllers do this very effectively by rapidly turning the supply voltage on and off. The effect is the average current changes. As Ohm's Law is stated above, if the voltage remains constant then adding or subtracting resistance changes the current. If the resistance stays constant, then changing the voltage will change current. Either method can be accomplished with switching (switch resistors in or out, battery cells in or out.) or variable voltage source or resistor. In many of the motors supplied for our use, the resistance of a few feet of wire can be almost equal to the internal resistance of the motor. Whenever the resistance of the wiring equals the internal resistance of the motor, by Ohm's Law only half of the available voltage will be delivered to the motor.
Unread 01-11-2002, 20:26
kmcclary's Avatar
kmcclary kmcclary is offline
Founder 830/1015;Mentor 66/470/1502
FRC #0470 (Alpha Omega Robotics)
Rookie Year: 1994
kmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond repute
Re: Variable Amperage in DC Circuit. How?
Thanks.
-Jordan
Please define your intent. Are you asking:
- "How do I control a load?" (a control question), or
- "How do I increase the maximum amperage capacity of a circuit?" (a wire gauge question)
- Keith
Keith McClary - Organizer/Mentor/Sponsor - Ann Arbor MI area FIRST teams
ACTI - Automation Computer Technologies, Inc. (Sponsoring FIRST teams since 2001!)
MI Robot Club (Trainer) / GO-Tech Maker's Club / RepRap-Michigan) / SEMI CNC Club
"Certifiably Insane": Started FIVE FRC teams & many robot clubs (so far)!
2002: 830 "Rat Pack" | 2003-5;14: 1015;1076 "Pi Hi Samurai" | 2005-6: 1549 "Washtenuts"/"Fire Traxx"
2005-(on): 1502 "Technical Difficulties" | 2006-(on): FIRST Volunteer!
2009-(on): 470 "Alpha Omega" | WAFL | Sponsor & "Floating Engineer" for MI Dist 13 (Washtenaw Cnty)
2011: 3638 "Tigertrons" | 2013-(on): 4395 "ViBots" | 2014-(on) 66 "Grizzlies"
"Home" Teams: 66, 470, 1076, 1502, 4395
Local FIRST alumni at or coming to Ann Arbor (UM/EMU/WCC/Cleary)?
...We Want YOU as a Mentor! Please email me for info!
Support CDF Reputation - If a posting helped, thank 'em with rep points!
"It must be FRC build season when your spouse and children become 'Action Items 8 & 9'..."
120 A circuit breaker tbmantia Electrical 2 05-02-2003 12:30
speed controllers & circuit breakers deuceswild Electrical 2 15-01-2003 14:46
circuit breakers.... archiver 2001 2 23-06-2002 23:58
circuit breaker archiver 2001 2 23-06-2002 23:18
So what's in YOUR Custom Circuit this year? kmcclary Technical Discussion 7 10-04-2002 12:20
