Go to Post When I was going down that one escalator that led to the field between the buildings and getting my first look at it, I felt like Dorothy walking into Oz. - Dr. Acula [more]
Thread Tools Rating: Thread Rating: 9 votes, 5.00 average. Display Modes
Unread 11-09-2009, 00:09
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: Drill/Mill or Lathe/Mill attachment for small shop area
I would avoid combination machines. From what I've seen, most of them are far superior in quality to individual machines. In my opinion, you would be best with a small drill press, a small mill, and a small lathe, separately. Unless you work in a clothes closet, you should be able to fit it it. The combination machines give you the capability of each, but not anywhere near as well as the individual machines. The combo machines do everything "sort of."
If money is tight, you'd be best with a drill press and lathe first (and even a sander and buffer), and then a mill later on. Also, you need to factor the cost of the tooling, which could easily reach half the cost of the machines (or more) depending on what you're looking to do. As for which machine to buy, they always say to buy the largest you can afford/fit, because there will eventually be some job that will be too large for the machine had you bought the smaller one.
I would also say a good size arbor press is something many FIRST teams can benefit from.
So, how much to spend, and what size shop?
EMC linux + CNC mill + CNC Lathe Leav Technical Discussion 8 09-11-2008 23:08
Digital Caliper as a Digital Readout on Small Mill sanddrag Technical Discussion 9 13-10-2005 22:51
Hot Off The Mill And Ready For Action! archiver 2001 3 24-06-2002 00:53
