Go to Post I am not even out of high school, and my foot is already in the door of my dream job. And FIRST got me there. - half geek [more]
Unread 13-09-2009, 13:33
Tanner's Avatar
Tanner Tanner is offline
FRC #1261 (Roblions)
Tanner is a splendid one to beholdTanner is a splendid one to beholdTanner is a splendid one to beholdTanner is a splendid one to beholdTanner is a splendid one to beholdTanner is a splendid one to behold
Driver Station Analog Port Sampling Rate
Hi all,
Does anyone know what is the maximum sampling rate for the analog ports on the driver station?
Cheers
-Tanner
Unread 13-09-2009, 14:21
Re: Driver Station Analog Port Sampling Rate
Originally Posted by Tanner View Post
Hi all,
Cheers
-Tanner
Although the hardware supports a higher sampling rate, the analog ports on the 2009 Driver Station have an effective sampling rate of 50Hz.
Unread 13-09-2009, 19:53
Tanner's Avatar
Eh. That stinks. Drat.
Time to rethink things.
Thanks
-Tanner
Unread 13-09-2009, 20:36
What are you looking to do? Maybe we can come up with an alternate solution.
Unread 14-09-2009, 18:29
Tanner's Avatar
I'm just looking to analyze the frequency/amplitude of a waveform (somewhere from 500hz to 1500hz). Exact use is a secret, but that's all we really are "researching" at this moment.
I was thinking a Arduino would be sufficient, but I'm no electrical guy nor have I ever played with micro-controllers (trust me - I soldered once with our electrical guy, it confirmed we both should stay in our current job positions).
Though the Aruino community say it might not be the best way to do it on that platform (see here).
-Tanner
Unread 15-09-2009, 11:58
That sounds like a perfect use for LabVIEW with the cRIO. You can sample far faster then you need with the analog input module we are provided. LabVIEW has a vast array of filters and display mechanisms that should make the analysis easy.
Unread 15-09-2009, 16:40
Tanner's Avatar
Our idea prevents such a device being mounted on the robot, and has to be on the user control end.
Though we do have two cRIO's, but I thinking have a whole 'nother cRIO just to analyze a frequency/amplitude is overkill for user control.
-Tanner
Wiring an Analog Sensor to Drivers Station DavidB Electrical 2 22-02-2009 13:35
Serial port for analog sensors channan Electrical 3 10-02-2009 17:35
LabVIEW - Analog inputs from driver station lag? RedOctober45 NI LabVIEW 1 30-01-2009 10:39
ETH 1 Port on Driver Station Will_Sica NI LabVIEW 10 12-01-2009 18:10
Help wiring potentiometer-to-Analog port kylehager Electrical 4 17-01-2008 17:28
