Go to Post Because when you build the people and the team, building the robot comes much easier. - Koko Ed [more]
Unread 17-09-2009, 11:41
travis travis is offline
FRC #2091
travis is a glorious beacon of lighttravis is a glorious beacon of lighttravis is a glorious beacon of lighttravis is a glorious beacon of lighttravis is a glorious beacon of light
vermicular engineering
Does anyone have something bad to say about worm gears? Or good actually, good is what I am looking for. I want to experiment with drive shafts this year and worm gears look to be a great way to do it, especially with multiple things running on a common drive shaft (say like 3 wheels).
My thoughts so far:
They can have poor efficiency, but you can do similar reductions with fewer steps (and weight and volume). Maybe one hardened and polished worm on a polished phosphor bronze gear is equally lossy as the 3 stage rolled steel on steel spur gear transmission it replaces. Ideally anyhow, this is the case.
Even in ideal situations, they do generate heat. I'd like to run them "open" which is to say with HD grease rather than in an enclosed oil filled housing. 1800rpm is the maximum Boston Gear lists them at, but that is for all day every day industrial work. The easiest thing to do would be to run them straight from a CIM at closer to 5KRPM. Extrapolating from the BG tables, I am still OK on power ratings, but I don't want to weld them together.
At sufficient pitch angles they cannot be back driven, so you have built in position holding, which saves oodles of complexity.
Motion Industries seems to be the only e-commerce supplier for Boston Gear and have a 6WD suite of worm gears for ~$800; a touch pricey. Anybody have a cheaper supplier, or manufacturer? Mcmaster only has CI gears, which is not ideal, though their 6WD suite would be more like $600.
So who has used worm gears and what nightmares/wonderful dreams have they wrought? Oh, and anybody ever licorice a drive shaft a much lower than expected torque values?
Travis
Unread 17-09-2009, 12:46
Jared Russell's Avatar
Taking a year (mostly) off
Re: vermicular engineering
Hi Travis,
I think you will find the following threads helpful:
http://www.chiefdelphi.com/forums/sh...ight=worm+gear
http://www.chiefdelphi.com/forums/sh...ad.php?t=41482
The general consensus among teams that have tried using worm gears in their drivetrains is that mechanical alignment is of the utmost importance to maximize your (already reduced) efficiency and avoid breaking things. Also, make sure you think long and hard about what materials to use for your worm. Also, be cognizant of the effects of sudden slopping and collisions with robots and field elements on the teeth of your worm.
As far as running your worm at 5000+ RPM, while YMMV, I would doubt that an un-reduced CIM would have the torque to overcome the considerable friction in a worm drive.
Personally, I would reconsider any design using worms in the drive train - there are other (easier) ways to be non-backdriveable besides worm gears.
Hope this helps.
Unread 17-09-2009, 19:58
DonRotolo's Avatar
Back to humble
FRC #0832
As you noted, these are expensive, in my mind their biggest drawback.
These are better suited for manipulator motion than for drivetrains, particularly because there are far better solutions for drivetrains where space is not such an issue. Think robot elbow instead, where they can be great.
That being said, a cheap source of worm gears for experimentation is window lifter motors. No, they are not strong enough for drivetrain or big manipulators, but you get some nice gear sets for cheap that you can play with and learn.
Unread 17-09-2009, 20:19
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Carefully consider the axial/thrust loads on the worm shaft, and what types of supports and bearings will be used.
Unread 18-09-2009, 10:37
Fe_Will's Avatar
Fe_Will Fe_Will is offline
AKA: Will
FRC #0955 (CV Robotics)
Fe_Will has much to be proud ofFe_Will has much to be proud ofFe_Will has much to be proud ofFe_Will has much to be proud ofFe_Will has much to be proud ofFe_Will has much to be proud ofFe_Will has much to be proud ofFe_Will has much to be proud ofFe_Will has much to be proud of
Our 2003 robot was 4 wheel worm drive. It was common knowledge that standing within 3 feet caused you to be covered in grease, almost magically. We had electronics covered in it as well. Definitely the messiest robot to date.
"It is the mark of an educated mind to be able to entertain a thought without accepting it." -Aristotle
Unread 21-09-2009, 12:46
Rob Stehlik's Avatar
Rob Stehlik Rob Stehlik is offline
FRC #0610 (Coyotes)
Rob Stehlik is a glorious beacon of lightRob Stehlik is a glorious beacon of lightRob Stehlik is a glorious beacon of lightRob Stehlik is a glorious beacon of lightRob Stehlik is a glorious beacon of light
We used worm gears in our robot last year with great success. We didn't experience a single failure in our drive system. Although, I suspect the low friction surface in last years game made it very easy on the drives
The gears we used were a bit unusual as far as worm gears go, since the worm had 6 starts. This meant that the reduction was fairly low (5:1 I think), and the gears were back drivable. We obtained the gears by taking apart a pair of industrial gearhead motors that came from a surplus shop. We got several sets of gears for quite a low cost.
As others have mentioned, precisely aligning the gears is key. We machined a housing for the worm with bearings supporting the shaft on both ends. Then a shaft coupler connected to the CIM motor above. The coupler makes things less compact than directly mounting the worm to the motor, but it allows for misalignment, and prevents axial loads from being transferred to the motor bearings. It also simplifies changing the motor.
For lubrication we used grease, and the gears were enclosed with a housing we built. A small hole at the top of the housing allowed re-greasing with a syringe.
Anyway, I have attached a couple pictures of our design. If anyone is interested, I can send Inventor files.
Rob
ID:	8094  Click image for larger version
Unread 21-09-2009, 14:11
In general teams have found that the thrust loads and gear alignment during run and direction change are formidable problems to overcome. In products that use them, the case/enclosure is substantial in order to hold everything in alignment. I just had part of one open a few minutes ago from our satellite dish azimuth drive. The right angle worm reduction weighs almost as much as the 3/4 hp motor and is fully lubed. All it is used for is to couple to a lead screw that is driving the dish.
Unread 22-09-2009, 17:41
FRC #2091
All insightful points, well taken.
Many people bring up worm gear efficiency as a problem. I looked deep into the roymech (great online reference by the way) page on gear efficiency and for single start 14.5° worms at 5krpm the efficiency is 89% -- pretty fair actually. Efficiency scales as v^-0.25 so you do worse while accelerating.
There was a lot said about reacting axial loads. Does anyone have experience using an E style retainer clip for this purpose? My friends over at Machinery's told me that an ANSI standard 1/2" shaft E clip will resist 600lbs of static load. I know you have to react that eventually, but I have something sinister in mind.
Several folks said they broke teeth. This indicates to me that worms are not necessarily inherently crummy (though one is suggested to use bronze, not steel gears), but perhaps the gut instincts that work fine for spur gear sizing need a fudge factor to be applicable to worm designs.
The final concern was alignment, on which I am going to just have to bite the bullet.
An alternative at this point would be a largish single stage spur gear reduction -- I just discovered Boston Gear's 5T(!) stem pinions -- followed by a smallish reduction and right angle transition using helical gears. Helical gears, being a somewhat special case of worm gears, should have a lot of the same challenges. Anyone have something good/bad to say about errr Crickian engineering?
Travis
Unread 22-09-2009, 18:31
E-clips would probably work fine for this. Snap rings would probably work better. Your best bet would be to have a structural/geometry constraint such as shoulders on the shaft. flanged or tapered bearings, etc to avoid using a clip at all.
In supporting the axial load, the concern in addition to the support/constraint is the bearing. It can be done (has been thousands of times over, but it's just more work than the traditional spur gear setup. Typical single row radial bearings are really only intended for no more than about 25% of their radial rating applied in the axial direction. Angular contact bearings are fantastic, but can be expensive. Some teams get by by using bronze thrust washers/bushings and grease. Tapered roller bearings (similar to automotive wheel bearings, but smaller) could be another option.
Engineer Survey: Engineering Vs Engineering Technology D.J. Fluck General Forum 16 27-06-2012 09:16
Re-Engineering Engineering @ Olin JohnBoucher College & University Education 0 30-09-2007 11:41
Full Service Engineering Job Opportunities-DuPont Field Engineering Program Mr MOE Career 0 24-05-2007 14:30
Another Question on Engineering vs Engineering Tech archiver 2000 0 24-06-2002 00:10
Engineering vs. Engineering Technology archiver 2000 4 24-06-2002 00:07
