Re: Anodizing
Even if we could get it done for free, we would never get it done because the robot and parts for the robot aren't done in time to be back from anodizing before ship date...
Re: Anodizing
Try to find a local anodizing company and see if they'll sponsor your team with free parts. Anodizing can be done in your shop, but you'll need a really powerful DC power supply, as in like 20A+ continuous at 12VDC, as well as an assortment of heated chemical baths, including one with sulfuric acid. It's pretty nasty stuff to keep in your shop when you're trying to build a robot.
The one key thing to either anodizing or powder coating parts is that you pretty much need to have everything designed in CAD and completely machined/fabricated ahead of time. When you anodize or powder coat parts, there really should never be a "oh no, these holes don't line up!" or a "gahhh! the roller chain wants to go through this piece of aluminum!" moment. You should know everything ahead of time, and the anodized or powder coated parts should just bolt together. Also, when anodizing, surface finish is important. Any blemishes or scratches or marks in the surface will show through. |
Re: Anodizing
Would this change the thickness on critical tolerance parts so that some things are too tight?
Re: Anodizing
Anodizing parts won't change the thickness, but powder coating will.
Re: Anodizing
We bought a kit last year and tried it out in the off season. Kinda cool, we used a battery charger from the school's auto shop and did some small pieces of aluminum. We got some unequal coloring, so it is important that the etching process is done correctly. We learned that is something we don't want to be bothered with during the build season, a professional shop can do a much better job anyways.
Re: Anodizing
Actually, anodizing does ever so slightly increase the dimension of the part. I couldn't see the effect being anything more than negligible in a FIRST robot though. From what I recall, anodizing adds about 0.0002 inch, whereas powder coating can add up to 0.020" I've never actually measured it.
#7
Re: Anodizing
Re: Anodizing
So its essentially insignificant. I'm looking into this for swerve parts. I guessing that these pieces wouldn't cost very much to anodize and an anodizing service could do this in a short amount of time.
#9
Re: Anodizing
Anodizing small things is easy, frames and such are kind of a pain. My team had our swerve module done in 2 days. Since they were small, we said "next time you do gold, throw this in," and they did. It isn't much of a cost to them if they're doing the color anyway, and if it's small, it's usually pretty easy.
#10
Re: Anodizing
1675 has a local place that offers their services for free. We've done the main lift pieces on the robot one year and parts for awards last year. It all depends on if we have pieces made in time or not, and the year we got the lift done, we just happened to have a blizzard the day it was finished, so not only did we lose the 4 days for anodizing, we lost 2 days for snow! Horrible timing!!
#11
Re: Anodizing
What are the material benefits rather than aesthetics? Does anodizing help with structural strength or durability enough to make a difference for our robots?
#12
Re: Anodizing
Hard anodizing is quite useful for parts that are going to be taking a beating. We had our Geneva drive hard anodized and it held up quite well. Without doing it I'm sure it would have failed mid-season due to galling.
#13
Re: Anodizing
Re: Anodizing
Another thing to note is there are different types of anodizing. Some hard anodizing processes can add a thickness which must certainly be accounted for. |
#15
Re: Anodizing
You just have to know what you will need when. |
| Anodizing - has anyone tried it at home? | sanddrag | Technical Discussion | 5 | 06-02-2006 12:25 |
