Go to Post New mentor joins one team and ends up impacting several in the same region. I like that. :) - Travis Hoffman [more]
Unread 19-09-2009, 08:58
Re: Help with basic algorithm on LabVIEW
What I'd do is contact your local sales rep. I don't remember hearing what version of LV you are using, but LV 2009 supports MathScript on the cRIO. So if you can explain your need, I suspect they will be able to help you out.
If they seem unreceptive, let me know in a PM and I'll see if I can find a way.
If 2009 doesn't support it, don't be too afraid of moving from the script to LV. It is often useful to take another pass at your code and think about each step in detail, for translation. You will often find questions for yourself such as, "why didn't I do it this simpler way?", or "I'm not sure why that ever worked!".
And of course it is better to ask yourself those questions than to have someone else ask them in your presentation.
Greg McKaskle
LabVIEW - Need help with Arrays sanddrag NI LabVIEW 2 16-05-2009 21:16
timer help with labview T3H_K3YM45T3R Programming 6 16-02-2009 18:34
Help with LabView daviamp NI LabVIEW 2 03-02-2009 19:55
High CPU Usage in LabVIEW even with Basic Code Elliot Swart Programming 5 28-01-2009 08:44
I Need Help with downloading Basic Stamp Program archiver 1999 2 23-06-2002 21:57
