Go to Post Only one full day of brainstorming on the hint? Boy are they behind... This thread's been busy for a week! - EricH [more]
Unread 21-09-2009, 13:01
Maxbotix Maxbotix is offline
Junior Member
Maxbotix is just really niceMaxbotix is just really niceMaxbotix is just really niceMaxbotix is just really niceMaxbotix is just really nice
Re: MaxBotix Sonar Sensor - Help please
Needlerp,
The analog voltage output from the MaxSonar product line is best suited for input into a high impedance amplifier or an AD converter. An op-amp, when connected as a non-inverting amplifier will have a high impedance input for the sensor to drive.
Alternatively, if you prefer an inverting amplifier, use 100K in the first stage (i.e. the resistor leading from our sensor to the op-amp) and 500K in the feedback from (the op-amp output to the input) should do the trick just fine.
If you have any further questions, please let me know (or post here and I will check back)
Carl Myhre, Systems Engineer, Carl @ Maxbotix."com" (remove spaces and quotes)
Labview Help: Sonar Sensor Lucario231 NI LabVIEW 4 21-01-2009 19:23
Sonar Sensor help eagleslg Programming 9 05-05-2008 21:14
Maxbotix Ultrasonic Sensor Help... manderson5192 Programming 9 22-02-2008 14:25
Maxbotix Sonar Sensor DonRotolo Electrical 17 04-02-2007 12:27
Help with sonar sensor supertw Electrical 3 24-01-2006 23:41
