Go to Post Easy, we use Magic. Your team wasn't given that in the kit? - Michael Hill [more]
Thread Tools Rating: Thread Rating: 10 votes, 5.00 average. Display Modes
  #76   Spotlight this post!
Unread 23-09-2009, 15:26
Chris is me's Avatar
AKA: Pinecone
Re: [FTC]: FVC (Vex) VS. FTC (Tetrix)
Originally Posted by Mike Soukup View Post
So we can expect this season's FTC competitions to be smooth and relatively free of delays? The 2 hour delay at the beginning of the Chicago event, the 10+ minute match cycle, and the insistence by the FIRST staff (Ken & James) at the event that the field & controls problems were the teams' fault turned me off of FTC forever. FIRST replaced a solid product with a half-baked solution before it was ready and the teams suffered because of that decision.
To be completely fair, I experienced similar headaches with FTC (Vex) in 2008 in Atlanta. Repeated interference happened for Thursday matches (at one point, the drive team turned off the controllers and held them autonomous style, and the robot continued to drive), that was repeatedly blamed on our antenna placement, later discovered to be a field fault.
The point of the above isn't to complain about the past or anything, but "issues with the control system" is a fairly common robotics problem. It's not pleasant (and at the time, I was very, very upset, as I'd just spent a month raising the money to compete at the event), but it's sadly not unusual, in my experience. Whether or not this is something one SHOULD expect from events... probably not...
  #77   Spotlight this post!
Unread 23-09-2009, 16:13
Software Engineer
VRC #0111 (Wildstang)
Rookie Year: 1995
Veering off-topic a bit here, but... the symptom of your robot driving on its own when it's supposed to be in driver mode cannot be a field fault. It's physically impossible with the VEX equipment. The cause in nearly every case of this was that the VEX microcontroller reset because either too much current was being drawn from the motors (improper gearing, etc) or a software bug in the team's code.
In a nutshell, if someone told you it was a "field fault" when your robot drove on its own, they were wrong. I saw a lot of FTC(Vex) teams that would insist that "something was wrong with the field" only to find a bug in their code after someone helped them look through it.
I've been to a lot of VEX events (FTC(Vex) and VRC), and I've never seen anything remotely as bad as what happened in FTC Chicago last year. And, I've heard many reports that the Chicago experience was common at other events too. That's the basis of Mike's point.
  #78   Spotlight this post!
Unread 23-09-2009, 17:09
AKA: Pinecone
I don't remember the specifics, but I believe it was something to do with the field's enabling and disabling of tethered controllers, and radio interference from the other Vex field. The motor use was fairly standard and the code issues did not happen at the previous event. Anyhow, this is a bit of a digression.
I do know from what I've heard at FTC events from friends and peers still participating in it, the field problems were worse than anything I'd seen.
  #79   Spotlight this post!
Unread 24-09-2009, 09:41
BLAQmx's Avatar
BLAQmx BLAQmx is offline
Software Engineer
no team (National Instruments)
BLAQmx is a glorious beacon of lightBLAQmx is a glorious beacon of lightBLAQmx is a glorious beacon of lightBLAQmx is a glorious beacon of lightBLAQmx is a glorious beacon of lightBLAQmx is a glorious beacon of light
That is certainly the goal. Part of this is purely technical; addressing connectivity issues and making the system more robust (an example of this is improved LabVIEW templates that remove all of the Bluetooth lag). Part of this is ease of use. Hopefully these two things (among others) will make competitions move more smoothly. The one thing we cannot account for is user error. Because all computer based systems are inherently complicated it is not a trivial task to train the volunteers who run competitions and matches. This being said our volunteers are not the problem (I <3 FIRST volunteers and staff), but rather the solution will be the developers ability to make the system simple, elegant, and most importantly: well documented.
On a note of documentation I am going to stress (again) how essential it is to read the FTC Getting Started Manual. We have made a considerable investment in documentation this year (Help files and the Getting Started Manual). While the Getting Started Manual is mostly geared towards LabVIEW development it contains a lot of good information that any team can put to use.
NI FIRST Community: Where to go for LabVIEW, Wind River, cRIO-FRC, and NXT support.
  #80   Spotlight this post!
Unread 24-09-2009, 12:39
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
I'm pretty sure that since FIRST is broken down into regional organizations, each region was responsible for its own FMS and setup. Our regional director was in communications with teams asking for feedback on comms issues and even setup a scrimmage with the actual FMS software a couple weeks before the VA competition. At the DE, MD, and VA competitions our teams attended, there were temporary hiccups. Yet those were simple matters of restarting the FMS laptop and/or swapping field within the division. Having 2 fields for each division made everything very smooth, yet I suspect that such a setup is a regional and not a national decision. At all 3 competitions, we were out of there by 7pm, which isn't bad considering that the previous year (FTC/VEX) it was 9pm.
A 2 hour delay due to FMS comms tells me that someone needs to light a fire and get someone motivated to test things ahead of time. Along the same lines, I wouldn't expect FIRST to ignore the complaints teams had from last year, and I would expect improvements all around.
GitHub
[FTC]: Use of VEX in Tetrix ttldomination FIRST Tech Challenge 7 11-01-2009 17:42
[FTC]: FTC Tetrix Extra Parts Team 288 FIRST Tech Challenge 2 22-10-2008 18:30
[FTC]: Rookie Team Needs Help With Tetrix FTC Kit! rjustice4 FIRST Tech Challenge 8 05-10-2008 09:44
[FTC]: Hey FTC teams, Vex and a chance to be on MTV? Rich Kressly FIRST Tech Challenge 1 12-09-2007 13:35
[FTC]: What could replace Vex in FTC? Billfred FIRST Tech Challenge 15 16-08-2007 10:16
