Go to Post the entire arena broke into applause when that first robot climbed that first robot ramp. - RoboMom [more]
Unread 25-09-2009, 14:52
Ericgehrken's Avatar
Ericgehrken Ericgehrken is offline
AKA: 3 Teams in 3 Seasons
FRC #0190 (Gompei and the Herd)
Ericgehrken has much to be proud ofEricgehrken has much to be proud ofEricgehrken has much to be proud ofEricgehrken has much to be proud ofEricgehrken has much to be proud ofEricgehrken has much to be proud ofEricgehrken has much to be proud ofEricgehrken has much to be proud ofEricgehrken has much to be proud ofEricgehrken has much to be proud of
Send a message via AIM to Ericgehrken Send a message via Yahoo to Ericgehrken
Survey!#2 Need help with Senior engineering capstone project!
For my PLTW Engineering Design and Development Capstone Design Project I am currently conducting a survey in the area of parking cars in garages.
Please complete the brief survey and either post it as a reply or PM it to me. Thank you!
1. Do you drive a car?
2. Do you park in a garage?
3. How large is your vehicle?
4. Have you ever had any problems parking
in a garage?
5. What kind of problems have you had?
6. What causes those problems?
7. Have you done anything to prevent this from happening?
Team 3125
GHAMAS FIRST Robotics
Team President and Founder
2010-
2010 Suffield Shakedown Winner Thanks 178 and 177
2010 WPI Regional Rookie All Star
2010 WPI Dean's List Finalist
Team 195 Member 2007-2009
2007 CT Regional Winner Thanks to 1124 and 558
2008 FIRST Presidents Circle Winner
2009 Suffield Shakedown Winner thanks to 126 and 1124
Unread 25-09-2009, 15:45
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Re: Survey!#2 Need help with Senior engineering capstone project!
1. Yes
2. I used to
3. Standard 4-door sedan
4. Yes
5. Allowing room on both sides of both vehicles in the two car portion of a 3 car garage
6. Partially caused by items in the garage, but primarily by the size of a 2 car garage stall and the space needed to open a car door and exit the vehicle. there is a lot of wasted space between the 2 car stall and single car stall in a 3 car garage with the doors split 2-1.
7. I parked at an angle, using more of the space between the two car stall and the single car stall.
Unread 25-09-2009, 15:52
James Tonthat James Tonthat is offline
FRC #0148 (Robowranglers)
James Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond repute
1. Yes, VW Rabbit
2. Yes
3. Subcompact hatchback
4. Yes
5. Small parking spot next to a concrete pillar
6. The concrete pillar to the left of my spot
7. Park diagonally in my spot at (10-15 degree angle)
There are two pillars that are spaced in a way that is barely enough space for two cars.
You might want to do a Google Form (Under Google Docs to make gathering your data a bit easier, it compiles the info into a spreadsheet.)
James Tonthat
Mechanical Engineer, RackSolutions, a subsidiary of Innovation First International
Lead Engineer - Texas Torque - 2009-2014
Mentor - Robowranglers - 2015-
Unread 25-09-2009, 15:55
BrendanB BrendanB is offline
AKA: Brendan Browne
FRC #1058 (PVC Pirates)
1. Yes
2. Yes
3. 15 passenger van (it is such a beast to drive)
4. Yes, but it depends on the garage we try to park it in.
5. Mainly height. 7.5' clearance is just a little bit too small so we have to go for 8.0'. Oddly enough length wise we don't have problems with space.
6. Engineers making a cut off and requiring vehicles of my size find another place to park
7. We make sure that it is above 7.5' clearance after scraping part of the paint off the roof when a valet told us wrong.
Don't know if that helps you at all. Good luck on your project!
1058 PVC Pirates 2016 - xxxx
Unread 25-09-2009, 16:00
ATannahill ATannahill is offline
AKA: Alex Tannahill
1. Yes (why else answer?)
2.Rarely, only when my parents are out of town or having their car taken care of.
3. Compact
4. No
5. n/a
6. n/a
7. n/a
- Arizona North
Unread 25-09-2009, 20:11
DonRotolo's Avatar
Back to humble
FRC #0832
Yes
Yes
Full-size sedan
No but my wife has
She has hit mirrors against the garage door frame
Difficulties with depth perception? Not sure. (and want to stay married)
Besides yelling? No.
Unread 25-09-2009, 20:13
Molten's Avatar
Molten Molten is offline
AKA: Jason
FRC #1766 (Temper Metal)
Yes
Not regularly
Plymouth Neon (smallish car)
in a garage?
Yes
I have a hard time watching both side mirrors and the front at the same time. Also, I sometimes would park...get out...and find that I wasn't up far enough. All this to get out and move forward more.
Lack of ability to see where I'm at in respect to the garage door properly. Also, the little bump I have to climb to get into the garage only allows me to enter with a certain amount of control over speed.
I usually just park outside. Nothing really technical, but it works. I have seen others use a suspended tennis ball technique to tell when they are in. I'm just too lazy to install such a thing. And I still would have to deal with mirrors.
"Curiosity. Not good for cats, great for scientists."- Numb3rs
"They can break your cookie, but... you'll always have your fortune."-T.W. Turtle, Cats Don't Dance
"Tell my tale to those who ask. Tell it truly - the ill deeds along with the good, and let me be judged accordingly. The rest... is silence."-Dinobot, Beast Wars
"Though the first step is the hardest and the last step ends the quest, the long steps in between are certainly the best."
–Gruffi Gummi, Disney's Adventures of the Gummi Bears
Unread 26-09-2009, 20:49
1. Yes
2. No
3. Sub-compact
4. Yes
5. Too large a car in too small a space.
In and out of the car too often on trips in rapid succession to bother opening and closing the garage doors.
Garage overtaken by robot storage, home construction material, and unused college dorm loft beds.
6. Having children and the process of their growing up
7. Stopped parking in the garage. I purchased a smaller car too, but only occasionally put the car back in the garage nowadays. Sent the children off to college.
Unread 26-09-2009, 22:00
gallo26's Avatar
gallo26 gallo26 is offline
Team 79 Alumni
AKA: Bryan Gallo
FRC #0079 (Team KRUNCH)
gallo26 is a name known to allgallo26 is a name known to allgallo26 is a name known to allgallo26 is a name known to allgallo26 is a name known to allgallo26 is a name known to all
Send a message via AIM to gallo26
1. Yes
2. nope
3. Pretty large. '08 Toyota Tacoma double cab
4. YES
5. Not enough room anywhere. at least in a parking garage you can find some spaces with no cars around. but in my home garage... not possible
6. Way too much stuff. my garage has been found as a very nice storage facility
7. Yes, I've tried cleaning it. but after a while... well.. it becomes a hassle to park in there since its STILL too small.... so I stopped parking in it.
Team 79 Alumni '11- Present
Team 79 Driver '09, '10
Team 79 Senior CAD Designer '09, '10
Team 79 President '09
Team 79 Electrical Sub Team Leader '08, '09
Unread 27-09-2009, 11:32
Ted Weisse's Avatar
Ted Weisse Ted Weisse is offline
AKA: xMentor/Inspector/Referee
Ted Weisse is a glorious beacon of lightTed Weisse is a glorious beacon of lightTed Weisse is a glorious beacon of lightTed Weisse is a glorious beacon of lightTed Weisse is a glorious beacon of light
Thumbs up Re: Survey!#2 Need help with Senior engineering capstone project!
1. Do you drive a car? YES
2. Do you park in a garage? If it is not full of other stuff.
3. How large is your vehicle? small pick-up truck GMC
in a garage? Yes
5. What kind of problems have you had? Much to much junk in the garage to fit the cars
6. What causes those problems? Me, pack rat...
7. Have you done anything to prevent this from happening? Yes, sell stuff at yard sales.
If I am not for myself, who will be for me?
If I am not for others, what am I?
And if not now, when?
-Rabbi Hillel
Jewish scholar & theologian (30 BC - 9 AD)
Unread 28-09-2009, 09:50
EricLeifermann's Avatar
EricLeifermann EricLeifermann is online now
That was a short break
FRC #2826 (Wave Robotics)
in a garage?
Yes
No, but i park in a parking lot(for my apt building only)
No, but i do have problems with people who don't live in my building, parking in our lot!
n/a
n/a
Yell at people who park in our lot that don't live there....
2012-2016 Wave Robotics Team 2826
Unread 28-09-2009, 11:16
Joining the 900 Meme Team
FRC #0079
in a garage?
Yes
Yes
07 CTS
Yes
Poor depth perception, I got a little of the door paint on the front of the car
Bad genes?
Open the door from further back, not try to put the car away when Im tired
Just so you have a little more data I will give you the other two cars I drive too
Yes
Yes
08 Aura
No
NA
NA
NA
Yes
Yes
06 Lucerne
No (My dad has, his depth perception caused him to hit the frame with the front of the car)
N/A
N/A
N/A
Unread 28-09-2009, 21:45
EncodersRUS's Avatar
EncodersRUS EncodersRUS is offline
Zombie repelant in human shape!
AKA: Tom Hewson
FRC #2550 (OCPRO)
EncodersRUS is an unknown quantity at this point
Send a message via Yahoo to EncodersRUS
1. Yes
2. No
3. Pretty large, older Tahoe
4. Yes, Several
5. Fitting and being alert enough to fit
6. A momentary lapse of reason (and bad depth perception)
7. Be more alert, get a new prescription.
The ultimate fight:
LabVIEW Programming versus people who think rationally...
LabVIEW Junkie and 2011 OCPRO Mentor
Survey! Help with Capstone Engineering Project Ericgehrken General Forum 19 28-09-2009 00:49
Senior Project Please help Jreed129 Chit-Chat 10 24-03-2009 08:18
Senior Project Help IraJason General Forum 15 09-04-2007 19:36
Senior Project 05: Mini competition to help fundraise for local rookie teams Alex Cormier Fundraising 0 07-10-2004 15:58
Need Help with FIRST Games Survey! Steve Shade General Forum 4 19-04-2003 20:32
