Go to Post *be there or be triangle, circle, square - PVCpirate [more]
Unread 26-09-2009, 02:37
XXShadowXX's Avatar
XXShadowXX XXShadowXX is offline
They call me Cody.
no team (None currently :\)
XXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud of
Giving Sensors a Pulse
So here is an idea I was working around for a little bit. I sit possible to the when the digital sidecars send power so that one could control so that this could be use as a pulse (this means connecting the ground/earth wire to a sensor slot on another slot) to check for wire errors or sensor operation. Just to make sure if the sensor is connected and has power to give the cRIO the first two steps of troubleshooting.
Is now an engineer thanks to FIRST.
Unread 26-09-2009, 19:52
Re: Giving Sensors a Pulse
What you're describing is unclear. Perhaps you could draw a picture to give a better explanation of your idea.
MAKE A MOTOR PULSE???? jax1488 Programming 7 25-01-2008 14:40
Gear Tooth Pulse Height ?? 354.FIRST Technical Discussion 3 26-02-2007 07:26
Remote Pulse Monitoring System kaveena Programming 1 19-07-2006 10:02
Measuring a Pulse Width MikeDubreuil Programming 22 21-07-2005 10:22
PUlse counting junkyarddawg Technical Discussion 1 31-01-2002 15:33
