Go to Post I can't help but notice during the building sequence, there were a whole lot of student hands working on that robot. Just sayin'. - Taylor [more]
Unread 26-09-2009, 21:49
Ice Berg's Avatar
Ice Berg Ice Berg is offline
Seth Berg
AKA: Seth Berg
FRC #0694 (Stuy Pulse)
Ice Berg is a splendid one to beholdIce Berg is a splendid one to beholdIce Berg is a splendid one to beholdIce Berg is a splendid one to beholdIce Berg is a splendid one to beholdIce Berg is a splendid one to beholdIce Berg is a splendid one to beholdIce Berg is a splendid one to behold
Send a message via AIM to Ice Berg
Autodesk - .stp file to .iam
So I wanted an autodesk assembly file of the AM shifter, and I found this thread:
http://www.chiefdelphi.com/forums/sh...ter+autode sk
I would have posted there, but it's closed.
So, here's the problem. I followed the instructions, and I opened the .stp file, and it worked. As the old post said, nothing was constrained, but I grounded everything and saved it as a .iam file. This all worked fine, but when I placed the AM Shifter assembly into another assembly, after i constrained it down, Autodesk froze. I did this two more times and the same thing happened. I've had autodesk 2009 freeze a couple of times over the year that I've had it, but never 3 times in a row, so I guessing it has something to do with the converted .stp file. Anyone have this problem? Any ideas?
Thanks,
-Seth
Mens et Manus
Unread 26-09-2009, 21:56
gallo26's Avatar
gallo26 gallo26 is offline
Team 79 Alumni
AKA: Bryan Gallo
FRC #0079 (Team KRUNCH)
gallo26 is a name known to allgallo26 is a name known to allgallo26 is a name known to allgallo26 is a name known to allgallo26 is a name known to allgallo26 is a name known to all
Send a message via AIM to gallo26
Re: Autodesk - .stp file to .iam
Wow, thats very odd indeed...
When you say you did this 2 more times... does that mean placing it into an assembly? or does that mean re-downloading that from AM and converting it from a STEP file?
I'd try that last one... and if that doesn't work try rebooting your pc. Sometimes that will fix the issue between autodesk and windows.
Team 79 Alumni '11- Present
Team 79 Driver '09, '10
Team 79 Senior CAD Designer '09, '10
Team 79 President '09
Team 79 Electrical Sub Team Leader '08, '09
Unread 26-09-2009, 22:34
Ice Berg's Avatar
Seth Berg
AKA: Seth Berg
Rebooted, re-downloaded the files and it happened two more times.
This is very annoying...
Mens et Manus
Unread 26-09-2009, 22:37
gallo26's Avatar
Team 79 Alumni
AKA: Bryan Gallo
Wow that really stinks dude...
Try this CAD Site. my bud RC put this together with help of a ton of other people. This has the files for inventor.. constrained and everything. It has everything you'd need I'm sure.
http://team1323.com/cad/index.html
Unread 27-09-2009, 13:15
Ice Berg's Avatar
Seth Berg
AKA: Seth Berg
Thanks alot, I should get around to uploading some files there.
Mens et Manus
Autodesk Inventor Design Competition: File naming pmax Inventor 2 08-01-2009 12:04
IGES and STP file modification TomBW CAD 3 31-01-2008 15:11
How to use the data obtain in one C file to another C file? tommy_chai Programming 8 11-01-2008 02:17
Help! making an inventor file into an autodesk file kjhobin Inventor 5 19-03-2006 23:04
Autodesk Inventor -> 3ds Max (File Format) Adrian Wong Inventor 1 22-01-2002 23:06
