Go to Post Kickoff features the joys of discovery. Ship date features the fear of utter failure. - Koko Ed [more]
Unread 30-09-2009, 16:52
Back @ it again with the white vans
AKA: Brandon Liatys
FRC #2180 (Zero Gravity)
2008 Solenoid wireing
Were making a demo using the 2008 control system and can't figure out how to hook the solenoid up to the spikes. Can anyone help?
Unread 30-09-2009, 17:57
gallo26's Avatar
gallo26 gallo26 is offline
Team 79 Alumni
AKA: Bryan Gallo
FRC #0079 (Team KRUNCH)
gallo26 is a name known to allgallo26 is a name known to allgallo26 is a name known to allgallo26 is a name known to allgallo26 is a name known to allgallo26 is a name known to all
Send a message via AIM to gallo26
Re: 2008 Solenoid wireing
Of course!!
It's actually really simple. Assuming that it's a double solenoid, there's 2 ways to do it. I prefer the way i'll explain below. Much easier.
You wire the two ground wires from each side of the solenoid together and run that to the ground on the breaker panel. Then the two red wires from each side of the solenoid can be run to the two plugs on the spike. Because it's a dual relay, you can switch between one or the other side of the solenoid.
The other way is wire the red and black of one side together, but on the black, you solder in a diode, that way you don't have to run the ground to the breaker panel. It'll work exactly the same. My team has done it both ways. Of course i prefer the first one.
If you have any other questions CD is here. You can PM me if you need a diagram for anything like that
Bryan Gallo
Team 79 Alumni '11- Present
Team 79 Driver '09, '10
Team 79 Senior CAD Designer '09, '10
Team 79 President '09
Team 79 Electrical Sub Team Leader '08, '09
Unread 30-09-2009, 20:50
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
If it's a Festo valve, here are the instructions. (It could be either of the two wiring configurations; if one doesn't work, just try the other.)
Distrubtion Block to Fuse Panle/Block Wireing ERAUeagle68 Electrical 3 13-02-2008 11:49
Air Compressor Wireing question Bochek General Forum 7 11-01-2007 21:34
[OCCRA]: wireing problems iheartpi OCCRA Q&A 1 20-09-2005 19:29
7.2v nicad battery wireing? hotcheese Electrical 2 16-02-2005 15:25
kit bot wireing sirbleedsalot Electrical 5 27-01-2005 17:59
