Go to Post FIRST may very well be the healthiest drug on the market. - Herodotus [more]
Go Back   Chief Delphi > Technical > National Instruments LabVIEW and Data Acquisition
Unread 30-09-2009, 12:54
ferc ferc is offline
ferc is an unknown quantity at this point
ni CRIO 9074 not booting up ?
Hello there!
We were trying to image regular NI cRIO 9074 with the FRC 2009 cRIO 9074 (last update).When the update process was about to complete by rebooting the cRIO we had an error "reboot error" (error no "56"). Now the cRIO's power led started to blink and does not seem to have connectivity to my PC.
I tried to reboot in safe mode but it doesn't work.
I tried to check the status of the cRIO in MAX but I just got an error 0XBFFF00A7 ( VI_ERROR_MACHINE_NAVAIL)
So kindly help me resolve this problem and reboot the cRIO with latest image.
Thanks and regards,
Murthy
Unread 30-09-2009, 13:43
Re: ni CRIO 9074 not booting up ?
Try connecting a terminal to the cRIO's serial console connector. You might get some useful information from it during its attempt to boot.
Unread 01-10-2009, 01:32
Danny Diaz's Avatar
Danny Diaz Danny Diaz is offline
Smooth Operator
AKA: FrankenMentor
None #0418
Danny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond repute
Send a message via AIM to Danny Diaz
Alan is quite right, connect a serial cable to the cRIO and open up hyperterminal to see if anything useful comes across the line. The blinking hopefully isn't the POWER light, but the status light - there should be a pattern to the blinking, some repeating number of blinks followed by a pause. What is the pattern?
-Danny
Danny Diaz
Former Lead Technical Mentor, FRC 418
cRio not working...? Jack Gillespie Programming 22 13-02-2009 13:07
CRio Not Responding Shadow_Cat NI LabVIEW 7 13-02-2009 08:12
cRIO Not Running Program railerobotics NI LabVIEW 5 18-01-2009 08:48
DS and cRIO Not Maintaining Communications Will_Sica FRC Control System 0 10-01-2009 13:39
CRIO not working with Windriver dpeterson3 C/C++ 7 07-01-2009 20:49
