Go to Post Not sure if its fair to call this or not yet. Back a group of dedicated teenagers far enough into a corner, and they're gonna find a way out. - Racer26 [more]
Unread 01-10-2009, 16:04
James Dowd's Avatar
James Dowd James Dowd is offline
A Michigan Man
FRC #1739 (Chicago Knights)
James Dowd will become famous soon enoughJames Dowd will become famous soon enough
Send a message via AIM to James Dowd
Re: [FTC]: Motor Rules?!?!?!?!
Originally Posted by NalaTI View Post
You will, however, use battery so fast you won't believe it (if you do so...)
The other limitation to realize is that you can only have 4 controllers of any arrangement. (e.g. 1 servo controller and 3 motor controller, or 2&2, or 0&4, or...)
So if you need 8 separately operating motors, you won't be able to have any servos (unless you count the 3 LEGO motors as servos).
Very true, a good point that I should have included, thanks for the comments!
James Dowd
FRC Team 1739 Mentor, FTC Team 329 Coach
Former Team 830 Mentor and Coach
Former Member of Team 573
2009 Wisconsin Regional Engineering Inspiration Award, Midwest Regional Engineering Inspiration Award
2007 Waterloo Regional Xerox Creativity Award
2006 Waterloo Regional Autodesk Visualization Award
2003 West Michigan Regional Engineering Inspiration Award, Buckeye Regional Xerox Creativity Award
2001 Curie Division Finalist, Great Lakes Regional Finalist, West Michigan Regional Rookie All-Star Award
Unread 03-10-2009, 09:48
FTC G-FORCE's Avatar
FTC G-FORCE FTC G-FORCE is offline
Accelerating into the Future
AKA: Derrick Maust
FTC #2818 (G-FORCE!)
Team Role: Driver
FTC G-FORCE has a spectacular aura aboutFTC G-FORCE has a spectacular aura about
im not 100% positive that this is right but i think we can have 26 motors in all. thats including servos. so i think we can have 8 12vs 3 lego 12servos and i think 3 hi technic = 26 i know where not going to use that menny motors.
G-FORCE Providing over 1500 hours of inspiration.
Maryland winning alliance and think award
Ohio winning alliance
website gforce2818.org
Unread 03-10-2009, 10:20
NalaTI NalaTI is offline
AKA: Alan
FTC #2848 (Techno Guards)
NalaTI is just really niceNalaTI is just really niceNalaTI is just really niceNalaTI is just really nice
Assuming that you double the motors and servos on controllers as needed... then you can have 23 motors:
8 Tetrix 12V Drive Motors
12 Tetrix Servos
3 Lego Motors
23 (Total)
There's no mention of a HiTechnic motor in the rules that I'm aware of.
Unread 03-10-2009, 11:29
ttldomination's Avatar
Sunny
First off, FTC G-FORCE, Happy Birthday.
Secondly, NalaTI is correct but remember you can only have 4 motor controllers, so at any one given point, the absolute MAX would be
4 12V Motors
12 Servos
3 LEGO Motors
19 Servos/Motors
But don't think in terms of max, think in terms of functionality. If you need the 8 12V motors, then use those and don't use any servos.
1648: 2013-2014
5283: 2015
Unread 03-10-2009, 20:29
AKA: Alan
4 12V Motors
12 Servos
3 LEGO Motors
19 Servos/Motors
Actually, you can double motors on the same controller, same with servos. Initially last year, they only gave us one motor controller and we had 4 motors - you could electrically connect 4 motors (2 per channel) to each of the controllers. You can only put one encoder into each channel, but you CAN have two motors.
So, strictly from a controller standpoint, you could actually have any of the following maximums
4 Motor Controllers (MC): 16 Motors + 3 LEGO = 19
4 Servo Controllers (SC): 48 Servos + 3 LEGO = 51
3 MC + 1 SC: 12 Motors + 12 Servos + 3 LEGO = 27
2 MC + 2 SC: 8 Motors + 24 Servos + 3 LEGO = 35
1 MC + 3 SC: 4 Motors + 36 Servos + 3 LEGO = 43
Since the rules limit you to 8 motors and 12 servos, and since practicality says that you won't double most of the motors, you could technically end up with:
2 Motor Controllers: 4 motors
1 Motor Controller: 4 motors (doubled)
1 Servo Controller: 12 servos (all doubled)
3 LEGO motors
Thus giving you the stated limit with still the possibility of some control.
All that aside... to re-iterate ttldomination's point "Don't think in terms of quantity, think in terms of quality." Use the right units for the right application and you'll have the best robot.
[FTC]: [FTC]: Motor Problems fqzeng FIRST Tech Challenge 3 16-02-2009 19:12
[FTC]: Rhode Rage (FTC 121) is in need of a motor encoder wire Rick FIRST Tech Challenge 2 02-02-2009 01:56
[FTC]: Random Error with FTC motor control Xaphiinia FIRST Tech Challenge 2 01-12-2008 15:39
[FTC]: FTC Servo-Motor Problem with Labview dnhansen FIRST Tech Challenge 1 26-10-2008 00:43
[FTC]: [FTC] Motor Controller problems michael714 FIRST Tech Challenge 4 14-10-2008 00:33
