Go to Post Mind you... if your ball kicker has as much energy stored up as a trackball launcher, you ought to be able to kick balls up into the stands. - dtengineering [more]
Unread 05-10-2009, 15:35
Nadav Zingerman Nadav Zingerman is offline
FRC #2230
Nadav Zingerman is a splendid one to beholdNadav Zingerman is a splendid one to beholdNadav Zingerman is a splendid one to beholdNadav Zingerman is a splendid one to beholdNadav Zingerman is a splendid one to beholdNadav Zingerman is a splendid one to beholdNadav Zingerman is a splendid one to behold
Unclaassified: Information about the 2010 control system
Today Eyal Hershko, mentor of 1577 and 1657 beta test teams, held a lecture introducing new teams and students to the cRIO and LabVIEW. He also briefly demonstrated some elements of the new control system. Here are some highlights:
Hardware:
  • Beta test teams have received the touch-screen version of the classmate, not the clamshell version that will be in the KOP.
  • The Classmate dual boots windows and a FIRST-specific Linux-based OS that will act as the DS (as seen on the screenshot on Bill's Blog).
  • The Classmate can use its own Wi-Fi capabilities or use an external router (Eyal said he has only tested it with a router so far).
  • CAN and custom FPGA are not available at this time.
  • The breakout board used to connect analog and digital inputs to the Classmate is manufactured by Cypress and is programmable itself in C++ (I believe I saw PSoc on the box).
Eyal demonstrated an application of the Cypress card. There is apparently a touch panel on the card. Eyal slid his finger across it, causing a red light on the board to follow his finger. We were not able to see this up close and Eyal said that was all he could show us.
Software:
Eyal also showed screen shots of the new LabVIEW FRC framework. Among them:
  • "Advanced Framework" is now called "Robot Framework"; "Basic Framework" is now called "Experiment Framework".
  • Begin.vi is changed, no longer is there a giant cluster, but rather VIs that receive all the Device references. The VIs have an icon of some kind of memory card, with arrow pointing in and out. I'm guessing the DevRefs are written to some global variable(s).
Speculate away!
p.s: Please take everything here with a grain of salt. Between me making a mistake, Eyal making a mistake and thing changing between the beta and the final system, many of these details may not be accurate.
Unread 05-10-2009, 17:38
DonRotolo's Avatar
Back to humble
FRC #0832
Re: Unclaassified: Information about the 2010 control system
Good post, thank you.
The astute team member will indeed heed the caveats quoted above.
Unread 05-10-2009, 18:42
Eugene Fang's Avatar
Eugene Fang Eugene Fang is offline
The Blue Alliance
Eugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond repute
Thanks for the info!
What's the bootup time on this?
Also, what is the purpose of dual-booting Windows? I read somewhere, I forget where, that beta teams were discouraged from installing programs on the Classmate anyways.
Eugene Fang
2010 Silicon Valley Regional Dean's List Finalist
Various FLL Teams - Student (2000-2006), Mentor (2007-2010)
FRC Team 604 - Student (2007-2010), Mentor/Remote Advisor (2011-2015)
FRC Team 1323 - Mentor/Remote Advisor (2011-2014)
The Blue Alliance | TBA GameDay | TBA Android App
Unread 06-10-2009, 08:20
FRC #2230
I don't know about the boot time, we didn't get to see it in action.
I think there's no particular reason for dual booting Windows, except that not having it is sort of a waste. You already have a laptop, might as well be able to use it as such.
Unread 06-10-2009, 08:55
jtdowney jtdowney is offline
Boiler Up
AKA: John Downey
FRC #4302 (Robophins)
jtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant future
I have talked to teams who have a difficult time getting their school system or whoever to install the programmers software on computers available to the teams. Those teams have to resort to having a team owned laptop to run LabView or Windriver on and not all teams have the capital to fund that. I am hoping that by providing a netbook in the kit that it can lower the barrier for those teams in this unfortunate situation.
John Downey
Lead Robot Inspector - Purdue IndianaFIRST District
Whitney Young Magnet High School/Robophins (FRC 4302) - Mentor (2013-current)
Midwest Regional Planning Committee - Member (2012-current)
Boilermaker Regional Planning Committee - Member (2011-2014)
Robot Inspector (2008-current)
Purdue FIRST Programs - Staff Advisor (2008-2011)
Lafayette-Jefferson High School/Precision Guessworks (FRC 1646) - Mentor (2006-2011)
Unread 06-10-2009, 09:01
I have the impression that it's just two different user accounts, not dual boot to separate operating systems. The "Developer" account has full privileges; the "Driver" account is more limited. Would someone participating in the hardware beta testing like to chime in and clarify this?
Last edited by Alan Anderson : 06-10-2009 at 10:00. Reason: not sure which OS it uses
Unread 06-10-2009, 11:49
FRC #2230
I think they're still not allowed to talk about it. Eyal said he had to obtain specific permission to reveal what he did ahead of time, so that the info could be given to all teams (these summits are not very common in Israel, it would be a shame not to use the opportunity).
Unread 06-10-2009, 13:22
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
#1. Beta test teams are allowed to talk about it RIGHT NOW. I'm surprised (and rather disappointed) that more Beta teams aren't communicating.
http://forums.usfirst.org/forumdisplay.php?f=23
Scroll down to find the 2010 Section.
Our team inquired early on with FIRST regarding what we're allowed to discuss because of the NDA, and received an email stating that we could reveal info to other teams. Below is some of the text:
Section 0.4.2 says that section provides the written consent referred
to in the Disclosure Agreement
Code you or your team creates using the new software not only can be shared,
but must be – this is one of the stated required tasks of beta teams (Section
0.3 of Chapter 0)
Teams were expected to start monitoring and responding to questions as
they are able on the FIRST public forum by 9/28 (Section 0.4.3). So,
post away.
And yes, answer questions on function, and post screenshots.
#2 The Classmate is runnig XP with two accounts. In fact, the dashboard / driverstation software is NOT specific to the classmate and will function on any laptop with XP. We have downloaded the software and are testing it on an XP machine along with the new Labview code, and it is truly outstanding. It's approximately 90 megs in size, and installs in about 15 seconds.
Initially I questioned the use of the classmate, but with the added functionality and troubleshooting capability (real time video at the driver station anyone?), I'm actually convinced this is a positive change.
We will try to answer questions posted to the First Robotics Labview forums as we can - however our biggest limitation is time, so there is only so many things we can actually try out.
Nadav - thanks for posting this. I think the #2 responsibility of every Beta team is clear communication to the community, right behind making sure everything works the way it should =).
Unread 06-10-2009, 19:38
The Blue Alliance
So is the Driverstation software a dual-boot Linux thing or is it a piece of code that's run on Windows? Or both?
Eugene Fang
Unread 06-10-2009, 19:46
Tom Line's Avatar
It is simply a Windows XP box with 2 accounts - one which is limited to run only the Dashboard and the Driverstation, and another that is an Admin.
Unread 06-10-2009, 20:08
Windows is used in many test and manufacturing line computers, and it is often useful to "hide" the windows features and use the computer in what is referred to as kiosk mode. It runs on the Windows OS, but doesn't run the Windows Explorer, so the task bar, start menu, and most of the other Windows UI is stripped away. It is a lighter, more industrial use of the Windows OS. You'll even find test equipment such as oscilloscopes from Agilent and Tektronix that have Windows running on them.
This is analogous to running linux, but choosing to run a very minimal X window manager.
Other beta-related questions will likely get answered quicker if posted to the first forums, beta section.
Greg McKaskle
Unread 06-10-2009, 20:47
jmanela's Avatar
jmanela jmanela is offline
+1 is BIGGER than -1
AKA: Joshua Manela
FRC #2586 (Fondy Fire)
jmanela is a splendid one to beholdjmanela is a splendid one to beholdjmanela is a splendid one to beholdjmanela is a splendid one to beholdjmanela is a splendid one to beholdjmanela is a splendid one to beholdjmanela is a splendid one to behold
Do you have some sort of a powerpoint, or word document that outlined your presentation? Do you have a screen shot or something of the LabView code because I am teaching LabView to my team I don't want to teach them last year's code.
Thanks in advance
||2009|| Entrepeneurship Award, QF - Traverse City | Rookie All Star, QF - Detroit | Highest Rookie Seed, Rookie All Star, QF - Michigan State Championship | Finalist - MARC ||2010|| Engineering Inspiration, Website Award, SF- Kettering | Judges Award, Website Award, SF - Detroit | Website Award, Winner, Michigan State Champ //Thank you 469 and 1918!! | Finalist - MARC ||2011|| Engineering Inspiration, Website - Kettering | Entrepreneurship, Website, Finalist - Waterford | Website - MSC
Unread 07-10-2009, 07:29
martin417's Avatar
Opinionated old goat
AKA: Martin Wilson
...We have downloaded the software and are testing it on an XP machine along with the new Labview code, and it is truly outstanding. It's approximately 90 megs in size, and installs in about 15 seconds.
So is the DS software available for any team to download and try? If so, can you post a link?
Former Mentor Team 1771
Former mentor Team 4509
Unread 07-10-2009, 08:01
Tom Line's Avatar
At this time it is only available to beta teams.
Unread 07-10-2009, 15:32
Zorkinian Zorkinian is offline
AKA: John Gilbert
FRC #0488 (Xbot)
Zorkinian is on a distinguished road
The Beta teams are free to share a lot of information about the beta system, but we're supposed to withhold the actual bits of something (documentation, code, programs) until the end of the beta/when FIRST tells us to. This is mostly a version control issue - what if we shared some code or documents on ChiefDelphi, but those libraries became deprecated or the document referred to things that no longer exist? Teams searching for help might find those out-of-date items, and troubleshooting the issues that come from that would not be pleasant.
2010 Control System Beta Testers Posted Jared Russell Control System 3 04-09-2009 16:40
Bills Blog: A few more details on control system and 2010 beta test Joe Ross FRC Control System 3 13-08-2009 13:52
Should FIRST Release the 2009 Control System beta Libraries and information? Elliot Swart General Forum 24 01-10-2008 07:12
What do you wish you knew about the new control system? Joe Ross Control System 2 09-01-2004 21:47
