Go to Post We can relate anything back to water, and by anything, I literally mean ANYTHING. Surfing around on Chief Delphi has proven that to me. - karomata [more]
Unread 06-10-2009, 00:12
Team1710's Avatar
Team1710 Team1710 is offline
FRC #1710
Team1710 is an unknown quantity at this point
Cim Reduction Swerve
I was wondering how much reduction should be applied to cim motors in a swerve application. We are thinking about using two cim motors per side, so that the swerve can switch to tank and swerve. Both the toughbox from AM and the Banebots P80 planetary look promising. What kind of reduction should be applied to a coax-swerve in a carpet setting. Within the module, we have a ratio of 1:2.75 so we get 2.75 turns out of the wheel for every turn of the top shaft. I guess it finally does come down to the type of the game, whether we need to push people around or we need complete speed, but what would be a good ratio for an off season project?
Unread 06-10-2009, 00:25
Jared Russell's Avatar
Taking a year (mostly) off
Re: Cim Reduction Swerve
First question: How large are your wheels?
Second question: Well, how fast do you want to go? For demo purposes lower speeds offer better controllability (and therefore safety) and battery life (less current draw under normal loads).
Unread 06-10-2009, 00:32
Team1710's Avatar
FRC #1710
We are using the 4" Performance Wheels from AM. I guess we would like to keep the speed open ended. Are the Banebot's P80s like the GEM 500s where you can add additional stages?
Here is a picture to help explain:
Unread 06-10-2009, 07:48
No, you can't stack P80s (the input shaft is 8mm while the output is 1/2" keyed). But you shouldn't need to anyway. If you run from the Toughbox (12.75:1) to your swerve module without any sprocket reduction, you are looking at about a 4.6:1 reduction (12.75/2.75). That's a little fast, giving you about 15fps top speed. If you use the driving sprocket on top of the module to reduce by another 2:1, you're in a good single speed ballpark (~7.5 fps). You can further tweak the ratio by playing with the exact sprocket ratio - something that is much quicker to change than your gearbox reduction.
Also, standard swerve disclaimer: you might want to think about ways to support your modules closer to the bottom. The side loads you get on the wheel when pushing or turning at high speeds, coupled with the effective moment arm created by the height of your module, can put a lot of torque on the joint with the chassis.
pic: Simple single reduction duel CIM gearbox Lowfategg Extra Discussion 11 05-10-2009 22:47
pic: FRC-34 2009 Swerve Module w/CIM (Front View) Ed Sparks Extra Discussion 10 05-05-2009 07:13
Gearbox/reduction for CIM,RS550,RS540 uid60001 Technical Discussion 8 03-04-2009 22:01
CIM Reduction? excel2474 Technical Discussion 8 22-03-2009 23:08
your thoughts on the FP CIM/2.5 CIM motor drive setup versus 2 2.5 CIM motors waialua359 Motors 11 14-12-2007 04:29
