Go to Post ...if most of the money comes from sponsors, I have a bit of a problem letting them [the students] charge off a cliff with it. - TimCraig [more]
Unread 08-10-2009, 15:54
ivybotter ivybotter is offline
FTC #3504
ivybotter is an unknown quantity at this point
[FTC]: NXT-G programming
Hi all,
I am a new coach of an FTC team. Our Team has just gone from FLL to FTC we were hoping to use NXTG so that we don't have to learn too many new technologies at once. The only problem as I see it is that I cannot for the life lof me find any information about how the joysticks communicate through the FTC blocks. I have gotten all the ftc blocks inserted and working. I can create a program that runs in autonomous mode using the controller Station. What I cannot do is get a simple motor to turn using the Tele op code from the robotics trainning site. They have great introductions to NXT programming but nothing on the joysticks and packets for FTC teleoperated mode.
thanks
~A
Unread 08-10-2009, 17:30
Michael Coleman's Avatar
Michael Coleman Michael Coleman is offline
Michael Coleman is a glorious beacon of lightMichael Coleman is a glorious beacon of lightMichael Coleman is a glorious beacon of lightMichael Coleman is a glorious beacon of lightMichael Coleman is a glorious beacon of light
Re: [FTC]: NXT-G programming
This video tutorial should help: http://www.education.rec.ri.cmu.edu/...tetraining.wmv
Unread 08-10-2009, 18:14
FTC #3504
Ok so this tutorial (which I have watched numerous time) talks a lot about labview and RobotC but barely touches on NXTG my problem specifically is that I don't know how to get joystick information from the blue tooth to the motors.
Can anyone help with that?
Thanks
~A
Unread 09-10-2009, 11:20
BLAQmx's Avatar
BLAQmx BLAQmx is offline
Software Engineer
no team (National Instruments)
BLAQmx is a glorious beacon of lightBLAQmx is a glorious beacon of lightBLAQmx is a glorious beacon of lightBLAQmx is a glorious beacon of lightBLAQmx is a glorious beacon of lightBLAQmx is a glorious beacon of light
Ivybotter,
The blocks you are describing are only available in the FTC software that shipped with last season's KOP. This season FIRST suggests that teams who used NXT-G in the past to use it for initial testing and prototyping, but they recommend you to move to LabVIEW or RobotC for full competition support.
I highly recommend you and your students spend the time becoming familiar with the fully supported software (for example if the old NXT-G blocks don't play nice with the FCS no one from LEGO or NI is going to fix it ). Since you have used NXT-G in the past LabVIEW will probably be the easiest software to pick up. There are a lot of training resources on the web for LabVIEW including the FIRST Community on www.ni.com/first and http://ftcmastery.com/. If you have any questions regarding using the tools or if you run into issues feel free to post of the forums at www.ni.com/first.
Cheers!
Mark
NI FIRST Community: Where to go for LabVIEW, Wind River, cRIO-FRC, and NXT support.
Unread 10-10-2009, 12:02
Thanks
~A
This topic is covered [briefly] about 20% into the video, before the LabVIEW section. The video shows how to connect the FTC Read Packet block to the FTC Read Controller block. The Read Controller block output sends commands (joystick Y1 & Y2) to the FTC Motor blocks.
I agree with you that the topic is not covered very thoroughly.
[FTC]: How to play sound from NXT gregsanCHEVY121 FIRST Tech Challenge 5 07-04-2009 10:10
[FTC]: NXT Display Code gdo FIRST Tech Challenge 6 05-02-2009 10:16
Programming NXT MINDSTORMS to work with Tetrix motors Droidguy41 Programming 1 04-02-2009 19:37
[FTC]: RobotC and NXT-G (The two programming languages) craig_yates FIRST Tech Challenge 1 30-01-2009 21:47
[FTC]: Bluetooth/NXT issues jbbjjbt FIRST Tech Challenge 5 23-10-2008 16:56
