Go to Post Oh no, do I see a new reality TV show coming? "Dancing with the FIRST Stars"??? :ahh: - KathieK [more]
Unread 08-10-2009, 21:54
yodameister yodameister is offline
The Mad Chemist
FRC #2791
yodameister has a brilliant futureyodameister has a brilliant futureyodameister has a brilliant futureyodameister has a brilliant futureyodameister has a brilliant futureyodameister has a brilliant futureyodameister has a brilliant futureyodameister has a brilliant futureyodameister has a brilliant futureyodameister has a brilliant futureyodameister has a brilliant future
Re: Victor running underwater!
De-ionized water (sometimes referred to as "distilled" by users) is used for cooling water in some high power transmitters. Water flows over high voltage and low voltage parts and current probes are used to determine the conductivity of the water. High voltage power supply trips at a few milliamps are common with poorly maintained equipment. In some cases, designers actually use china pipes to keep the water insulated from sensitive (read 'human') objects just in case some contamination enters the system and causes conduction to skyrocket. The UHF transmitter I worked on in Peoria many years ago had 25,000 volts across the output tubes and the cooling water. As I remember it had both a ceramic filter and a de-ionizer in the circulating water. The collector (plate/anode) was vapor cooled. This means that cold water is just poured onto the structure and cools while turning to steam vapor. The steam is carried off to a heat exchanger where it is turned back into water. Regular maintenance includes scheduled water changes.
*sigh* I thought I sounded intelligent...*sigh*
Underwater Camera? 16MentalTempest 3D Animation and Competition 5 09-01-2009 01:19
Underwater Robotics Questions Greg Marra General Forum 6 11-11-2008 11:39
Underwater Robotics Competition. PhilBot Chit-Chat 1 08-05-2008 10:25
Underwater Effect Tom Bottiglieri 3D Animation and Competition 12 01-02-2005 21:48
Victor 884's not behaving the same as Victor 883's programmer1 Programming 13 10-03-2004 21:51
