Go to Post I learned... that I need to learn more. - Erin Rapacki [more]
Unread 07-10-2009, 12:34
Adam Y.'s Avatar
Adam Y. Adam Y. is offline
Adam Y.
no team (?????)
Re: Victor running underwater!
Originally Posted by sanddrag View Post
I bet you could run it under DI water without any waterproofing.
Technically, DI water has ions in it. There is a class of purity above that water called reagent grade or nanopure water in which you measure purity in resistance.
Unread 07-10-2009, 15:23
De-ionized water (sometimes referred to as "distilled" by users) is used for cooling water in some high power transmitters. Water flows over high voltage and low voltage parts and current probes are used to determine the conductivity of the water. High voltage power supply trips at a few milliamps are common with poorly maintained equipment. In some cases, designers actually use china pipes to keep the water insulated from sensitive (read 'human') objects just in case some contamination enters the system and causes conduction to skyrocket. The UHF transmitter I worked on in Peoria many years ago had 25,000 volts across the output tubes and the cooling water. As I remember it had both a ceramic filter and a de-ionizer in the circulating water. The collector (plate/anode) was vapor cooled. This means that cold water is just poured onto the structure and cools while turning to steam vapor. The steam is carried off to a heat exchanger where it is turned back into water. Regular maintenance includes scheduled water changes.
Unread 07-10-2009, 18:29
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
I was lucky Al, I got to work on installing satellite ground stations after the cryogenic cooled receivers and water cooled transmitters had run their course....
Unread 08-10-2009, 11:06
PICgnosis's Avatar
PICgnosis PICgnosis is offline
AKA: Karen Suhm
FRC #0842 (Falcon Robotics)
PICgnosis is on a distinguished road
The Victor is sealed in Max GFE A/B epoxy from Polymer Composites, Inc. It has a thermal conductivity of 0.682 W/mK, which is about the same as a thermal grease like Wakefield 120 (0.735 W/mK).
Here's the closest thing I can find to an online datasheet for this product:
http://cgi.cafr.ebay.ca/EPOXY-RESIN-...7 C240%3A1318
It also provides information on their recommended mixing and casting procedures.
Unread 08-10-2009, 21:47
falconmaster's Avatar
falconmaster falconmaster is offline
AKA: Ledge
falconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond repute
Send a message via MSN to falconmaster
Thanks Karen!
Faridodin "Fredi" Lajvardi KD7WKD
Unread 08-10-2009, 21:54
yodameister yodameister is offline
The Mad Chemist
FRC #2791
yodameister has a brilliant futureyodameister has a brilliant futureyodameister has a brilliant futureyodameister has a brilliant futureyodameister has a brilliant futureyodameister has a brilliant futureyodameister has a brilliant futureyodameister has a brilliant futureyodameister has a brilliant futureyodameister has a brilliant futureyodameister has a brilliant future
*sigh* I thought I sounded intelligent...*sigh*
Unread 08-10-2009, 23:10
MrForbes's Avatar
AKA: Jim
That's hard to do in a thread where Al says something
Unread 08-10-2009, 23:30
BitTwiddler's Avatar
BitTwiddler BitTwiddler is offline
electronics/programming mentor
AKA: Mr Tanguay
BitTwiddler is on a distinguished road
A few years back when they made me a manager and the radar guys said they needed some deionized water for the transmitter tube, I had never heard of the stuff. They said to make sure it was reagent grade.
Boy did I have a hard time finding that stuff! Now I know why.
Unread 09-10-2009, 11:11
You are!!!! People like you are my heros.
Unread 09-10-2009, 11:56
Jeff Pahl's Avatar
Jeff Pahl Jeff Pahl is offline
likes to look at shiny things...
FRC #5148 (New Berlin Blitz)
Jeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond repute
Fredi,
At high current, I would be concerned with expansion and contraction coefficients of the material and the electrical components. I think the epoxy can do a great job as a heatsink when exposed to water. What I might suggest is a double dip such that the tabs of the transistors only are embedded in the epoxy while the circuitry remains open. Then encase the assembly as you have shown. This would allow the components on the board to move around with temperature without being broken off as material expands and contracts.
If you find the expansion / contraction to be an issue, another option is to pot the power devices with a layer of a thermally conductive RTV to provide a "cushion" layer between the packages and the epoxy. We use a material from NuSil at work that has a thermal conductivity of 0.81 W/mK to bond high power RF terminations to mounting surfaces. This is for a vacuum application where there is no other way to get the heat out besides conduction. The part number we use is CV-2960. I doubt it is cheap, but you could probably talk to them and get them to sample you enough to coat several units.
Team 5148 - 2014 Wisconsin Regional Rookie All-Stars!!
Mentor: 1379: 2004-2008 / 2530: 2008-2013 / 2861: 2009 / 5148: 2014-??
Lead Robot Inspector: 10,000 Lakes '09 - '11 / Lake Superior '11-'12 / Northern Lights '13, '15 - '16 / Championship '09 - '12, '14 - '15
Attending/Inspecting 2017: TBD, Wisconsin, STL Championship
"Sometimes the questions are complicated and the answers are simple" -Dr. Seuss
Unread 09-10-2009, 15:54
I think it would be to your advantage to reduce the amount of potting material you use, for both cost and thermal reasons. Perhaps place a few inserts in your mold?
As a point of reference, Aluminum is about 250 W/mK and stationary water is about 0.58W/mK.
Unread 14-10-2009, 02:49
Andy A. Andy A. is offline
Getting old
FRC #0095
It's been a few years since I opened up a victor, but I recall that they have an optical isolation on the PWM input from the controller.
Is it safe to assume that thats accomplished with a 'closed' unit, and there are no concerns about getting something opaque in there?
Unread 14-10-2009, 08:07
Andy,
Yes, that is a sealed opto-isolator, one of the 4N series as I remember.
Unread 14-10-2009, 08:10
The optical isolation is accomplished within the confines of a single component on the board. There is no risk of getting something opaque in the way unless they break open that chip.
If you do break a victor open and take a look, it is the tall-ish 4 or 6 pin* device near the connector.
* (I can't remember: Only 4 pins are used, but often these devices are in a 6-er to match the 5-pin devices in the family.)
Unread 14-10-2009, 09:10
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
If you want to go with high current, you will need some sort of heatsink. Probably the easiest is to solder some copper tubes coming off the metal transistor tabs on the Victor that poke out of the compound. Why use a 40A speed controller if you're never going to pull it? I think this is eluding to a new possible design from these guys
GitHub
Underwater Camera? 16MentalTempest 3D Animation and Competition 5 09-01-2009 01:19
Underwater Robotics Questions Greg Marra General Forum 6 11-11-2008 11:39
Underwater Robotics Competition. PhilBot Chit-Chat 1 08-05-2008 10:25
Underwater Effect Tom Bottiglieri 3D Animation and Competition 12 01-02-2005 21:48
Victor 884's not behaving the same as Victor 883's programmer1 Programming 13 10-03-2004 21:51
