Re: [FTC]: NXT-G programming
Ivybotter,
The blocks you are describing are only available in the FTC software that shipped with last season's KOP. This season FIRST suggests that teams who used NXT-G in the past to use it for initial testing and prototyping, but they recommend you to move to LabVIEW or RobotC for full competition support. I highly recommend you and your students spend the time becoming familiar with the fully supported software (for example if the old NXT-G blocks don't play nice with the FCS no one from LEGO or NI is going to fix it ). Since you have used NXT-G in the past LabVIEW will probably be the easiest software to pick up. There are a lot of training resources on the web for LabVIEW including the FIRST Community on www.ni.com/first and http://ftcmastery.com/. If you have any questions regarding using the tools or if you run into issues feel free to post of the forums at www.ni.com/first.Cheers! Mark Last edited by BLAQmx : 09-10-2009 at 11:26. |
| [FTC]: How to play sound from NXT | gregsanCHEVY121 | FIRST Tech Challenge | 5 | 07-04-2009 10:10 |
| [FTC]: NXT Display Code | gdo | FIRST Tech Challenge | 6 | 05-02-2009 10:16 |
| Programming NXT MINDSTORMS to work with Tetrix motors | Droidguy41 | Programming | 1 | 04-02-2009 19:37 |
| [FTC]: RobotC and NXT-G (The two programming languages) | craig_yates | FIRST Tech Challenge | 1 | 30-01-2009 21:47 |
| [FTC]: Bluetooth/NXT issues | jbbjjbt | FIRST Tech Challenge | 5 | 23-10-2008 16:56 |
