Go to Post OMG, yet another blatant attempt by FIRST at being open and transparent! What is this place coming to?? :p - DonRotolo [more]
Go Back   Chief Delphi > ChiefDelphi.com Website > CD Forum Support
Unread 06-10-2009, 13:06
ziki123 ziki123 is offline
ziki123 is an unknown quantity at this point
Question Kit of Parts Conversion Help
Can someone please help me convert a couple parts from the inventor kit of parts? I need them converted from 2009 to 2008.
thank you
Unread 06-10-2009, 13:48
Re: Kit of Parts Conversion Help
Help part one: A better place to ask would probably be in the Inventor subforum, located at http://www.chiefdelphi.com/forums/forumdisplay.php?f=57 due to exposure and expertise hanging out there.
Help part two: You'd have to convert it to a different file type, then open that with Inventor 2008. My memory is fuzzy, but iges or step would probably work. As you've probably discovered, Inventor 2008 (or previous) doesn't exactly like Inventor 2009 files, and this holds true on up the line. So you go to a "neutral" file type and then to Inventor [insert version here] or Solidworks [insert version here] or another CAD program of your choice.
Unread 10-10-2009, 20:33
mplanchard mplanchard is offline
Marie Planchard, SolidWorks
mplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond repute
thank you
Hi Ziki,
Go to www.3DContentCentral.com. Search for 2009kop, FRC
You will find most of the parts from the kit. Select the 3D Cad format, such as Inventor and then select the year, such as 2008.
Regards,
Marie
Kit of Parts T3_1565 General Forum 14 19-12-2008 09:33
Kit of Parts Andrew Y. Inventor 18 22-01-2008 15:51
Analog to Digital Conversion Help Der Rowan Programming 4 23-01-2006 00:17
Virtual Kit of parts help! edomus General Forum 7 18-01-2004 10:51
Parts dropped from the 2003 Kit of Parts? D.J. Fluck Rumor Mill 38 03-01-2003 19:29
