Go to Post I guess my only option is to either stop picking on Dave or come up with an even better picture! Now, which one do you think I'll choose? - MissInformation [more]
Unread 10-10-2009, 21:14
Mike's Avatar
Mike Mike is offline
has common ground with Matt Krass
AKA: Mike Sorrenti
FRC #0237 (Sie-H2O-Bots (See-Hoe-Bots) [T.R.I.B.E.])
Mike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond repute
Re: Tracking a radio signal
Originally Posted by Don Rotolo View Post
Drop the "robotics"
The Ramsey kit is the size of a textbook (plus antennas), you need a radio receiver for the frequency of interest (you pick the size) and a power source (ditto). I could fit it all into a Cheerios box (but the antennas would poke out) with room for breakfast.
3 or 10 over a square mile as PoC is doable, but scalability will frustrate you even at the hundreds level. The only way around that is a fixed (land-based) antenna network, which doesn't sound practical here. (A friend's company does exactly this, providing equipment location within a hospital. Handy if you need that <equipment name> NOW to save a life)
Research Spread Spectrum, Alan's comment is absolutely valid and when you get past the PoC stage allows for scalability.
(Here's a thought experiment for you: Imagine instead that each device chirped an audio tone, and your 'antenna' was a microphone. How many chirpers before you can't tell one from another? Repeat with chirpers on any of 500 random frequencies (=spread spectrum). Now how many?)
By the way, the Ramsey kit is just an "antenna", you can easily connect up a spread spectrum receiver to it as well.
Proof of concept is all I need for now.
So using this DDF kit I will be able to point, within 22 degrees, towards the beacon with the strongest signal strength? How would I go about decoding the signal then, another directional antenna pointed in the approximate heading? What happens if there happens to be two or three beacons there? I feel like the DDF guiding the directional antenna doesn't provide enough resolution in case there are two beacons in that heading. Can I use the DDF kit to both find the direction of the radio and decode anything incoming?
Thanks
Mike
Change two color tracking vi from tracking pink AND green to orange OR grape balls star_lancer Programming 5 14-02-2009 20:58
VEX Radio Range & Loss of Radio Fail Safe? Chris_Elston Programming 14 03-09-2008 09:13
Ham Radio and Radio at FIRST bcieslak General Forum 41 06-04-2007 10:41
Camera locked in "tracking", but not tracking geeknerd99 Programming 1 18-02-2007 22:47
need 2003 radio/help with old radio MaxM Technical Discussion 2 04-01-2004 15:31
