Re: Pneumatics Code
Okay, thanks a lot!
The only reason I had it test the pressure in my code, was because I wouldn't want it to fire if it only had like 60 PSI. ![]() As far as my solenoid firing, would that work? My thought was that it would switch the valves on the FESTO Solenoid for a second, allowing air to shoot out. |
| Problems integrating CMUCAM code and IFI Default Code | Windward | Programming | 2 | 06-02-2007 16:48 |
| problems using gyro/adc code with camera default code | tanstaafl | Programming | 7 | 22-01-2006 23:09 |
| Pneumatics-Code [and piston output length] | reilly | Programming | 5 | 13-02-2005 11:42 |
| Pneumatics-Code [and piston output length] | reilly | Technical Discussion | 0 | 10-02-2005 12:21 |
| Team THRUST - Kevin's Code and Camera Code Combine | Chris_Elston | Programming | 3 | 31-01-2005 22:28 |
