Go to Post When you open of CD and you see your very own quote up top, and can't decide if it's a really awesome or "Well...this is awkward..." moment - CalTran [more]
  #31   Spotlight this post!
Unread 11-10-2009, 01:32
Joining the 900 Meme Team
FRC #0079
Re: Motors - another concept for FRC
Originally Posted by Collin Fultz View Post
Not to take a side on the FP vs. CIM debate, but an FP + AM Planetary to get it around the same output speed as the CIM is actually about 1 lb less than a CIM. We looked into this as a weight savings option for 2009, but found the weight in other areas. Just want to pepper some facts into our daily discussion.
2337 did just that this year. I will try to convince someone from that team to post the experience.
  #32   Spotlight this post!
Unread 11-10-2009, 07:28
Billfred's Avatar
Billfred Billfred is offline
2815 did the same thing this year for their drivetrain. Not so much for weight savings as the fact that all four CIMs were tied up in our conveyor and shooter drum system. No issues all season (nor in its several off-season demos) driving on a slick floor, though we did keep cans of compressed air in the pits. I don't think we'd do it like this in a carpet game, but it worked great for the task at hand.
  #33   Spotlight this post!
Unread 11-10-2009, 14:47
colin340 colin340 is offline
human
AKA: Colin Nobles
FRC #0148
colin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond repute
Send a message via AIM to colin340
I would be a little hesitant about it, but I can imagine using multiple FPs instead of a CIM for higher up manipulators that still need some power. A better application is probably for multiple smaller manipulators, where the weight of CIMs would be killer.
i'd take the great weight for if just to get the Reliability of a CIM
fp's are vented, have really bad bushings, and spin at 15,000rpm it's not a good combo for what we do to them
61 77 77 20 77 69 74 74 6c 65 20 62 61 62 79 20 63 6f 6e 64 6f 72 20 69 73 20 72 65 61 64 69 6e 67 20 43 44
  #34   Spotlight this post!
Unread 12-10-2009, 14:21
Richard Wallace's Avatar
I live for the details.
FRC #3620 (Average Joes)
Sorry for dragging this up again -- I want to (try to) clarify what I said in an earlier post, using some data.
Originally Posted by Richard View Post
Richard's first rule of motor selection: you pay for torque.
The 12 Volt CIM and FP motors available from AndyMark have different parameters, consistent with their different sizes, weights, and costs:
CIM: 2.22 N-m stall torque, 115 Ampere stall current, 1280 g mass, $28 price
FP: 0.45 N-m stall torque, 70 Ampere stall current, 272 g mass, $13 price
To get about the same torque that is available from a CIM, others have pointed out that the FP can be combined with a 3.67:1 gearbox that has 409 g mass and $98 price.
Rated voltage (V), stall torque (ST), and stall current (SC) can be conveniently combined to give a figure-of-merit that is often called the 'motor constant' and is defined by:
kM = ST / sqrt (V*SC), which has units of torque over the square root of power.
When we use Newton-meter as the torque unit, kM is expressed in Newton-meter per root Watt. Its physical significance lies in the following simple expression for Joule (i.e., I^2 * R) losses in the motor for a given torque:
Pj = (torque / kM)^2
As an example, let's calculate Joule losses in the CIM and FP motors when each is used to drive 35 lbf traction load on a 6" diameter wheel through a 12.75:1 Toughbox. (Note that this loading, while extreme, has very likely been seen in many FRC situations over the past few competition seasons. Maybe not so often in 2009, when traction on the playing surface was limited.)
The specified load corresponds to 105 lbf-in torque at the wheel, and to 8.2 lbf-in torque at the Toughbox input. (Note: for simplicity I am neglecting mechanical losses in gearboxes; this would make conclusions regarding absolute rates of motor heating somewhat optimistic, but will not impact conclusions regarding relative rates of motor heating.)
So in this example the CIM torque is 0.931 Newton-meter (42% of its stall torque) and the FP torque is 0.931 / 3.67 = 0.254 Newton-meter (56% of its stall torque).
Now let's calculate kM for each motor:
CIM: kM = 2.22 / sqrt(12*115) = 0.0598 Newton-meter per root Watt
FP: kM = 0.45 / sqrt(12*70) = 0.0155 Newton-meter per root Watt
From these figures we calculate the Joule losses in each motor at their respective torque loads:
CIM: Pj = (0.931 / 0.0598)^2 = 242 Watt
FP: Pj = (0.254 / 0.0155)^2 = 267 Watt
These losses will cause the motors to heat up. How fast will the each motor's temperature rise? This brings us to Richard's second rule:
Richard's second rule: choose a motor that can take the heat.
Rate of temperature rise is roughly proportional to the ratio of the motor's power losses to its mass. (Note the proportionality will not be the same for motors made of dissimilar materials; however, relatively conventional motors like the ones used in this example are made mostly of steel and copper, so the approximation is valid.) The loss-to-mass ratios in this example are:
CIM: 242 / 1.28 = 189 Watt/kg
FP: 267 / 0.272 = 979 Watt/kg
So the FP will exhibit about 979/189 = 5.17 times the rate of temperature rise. Put another way, if the CIM can take a 35 lbf wheel traction load for 30 seconds before overheating, then the FP can take the same load for about 6 seconds.
Richard Wallace
since 2003
pic: FRC-34 2009 Frame Concept (Front View) Ed Sparks Extra Discussion 4 01-06-2009 18:09
Modifying motors for 2009 FRC motors Ramiro_T General Forum 2 22-03-2009 01:33
pic: FRC-34 2009 Frame Concept (Bottom View) Ed Sparks Extra Discussion 1 09-03-2009 12:11
pic: FRC-34 2009 Frame Concept (Rear View) Ed Sparks Extra Discussion 2 09-03-2009 11:00
pic: FRC 1771 Concept Drivetrain sdcantrell56 Extra Discussion 7 09-11-2008 14:42
