Go to Post Never leave future engineers alone, especially with something like gravity. - Alex Pelan [more]
Unread 12-10-2009, 17:38
Re: Pneumatics Code
You'll lose the same amount of pressure each time, down to 60 psi, so that part's consistent.
Restoring the pressure is a function of how much pressure is already in the system. The compressor takes longer the more it has to work against higher pressure. So, for example, pumping 5psi back into a system already at 110 psi will take longer than pumping 5 psi into a system at 60 psi.
What you're suggesting will probably work for your purposes though. You don't have to be too exact. You can probably go with the time you measure when the overall system is down to 90 psi and you'd be fine. Then you could still check the pressure sensor for "1" and keep the compressor running as long as it doesn't turn back to "0".
Unread 12-10-2009, 17:52
nighterfighter nighterfighter is offline
1771 Alum, 1771 Mentor
AKA: Matt B
FRC #1771 (1771)
nighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant future
Re: Pneumatics Code
Cool, I wasn't too far off!
Looks like I have some system-of-equations to write tomorrow!
Problems integrating CMUCAM code and IFI Default Code Windward Programming 2 06-02-2007 16:48
problems using gyro/adc code with camera default code tanstaafl Programming 7 22-01-2006 23:09
Pneumatics-Code [and piston output length] reilly Programming 5 13-02-2005 11:42
Pneumatics-Code [and piston output length] reilly Technical Discussion 0 10-02-2005 12:21
Team THRUST - Kevin's Code and Camera Code Combine Chris_Elston Programming 3 31-01-2005 22:28
