Go to Post Actually, I forsee two [buttons]: Fire and "Thats the opponents target, you dumb robot" - devicenull [more]
Unread 13-10-2009, 10:22
Joining the 900 Meme Team
FRC #0079
Re: pic: Prototype FLL Table
Ease of removal, I think. The problem is that you have to line it up right for teams because there will always be some team that is using distance from the wall on a fairly precise movement, and if your field is set up wrong (i.e., the black border line being under the wall instead of next to it), it'll throw them off and they complain.
Psst... My point on the mats still stands... Volcanic Panic and before didn't use mats...
Bah! That is true, Volcanic Panic didn't use mats. This will teach me to interchange mats and fields. (No it won't) I must say that I preferred the old wooden fields, probably cost more to make but they were certainly gorgeous. I would kind of like to see one of them (painted) placed on one of these tables.
I guess that removal makes sense, easier way might be to just have a corner that you cut to make it easier to remove. Lining up is a HUGE issue for teams and field setup issues shouldn't be a factor.
pic: Why I work the FLL table NorviewsVeteran Extra Discussion 13 25-03-2009 17:37
pic: welding table Bruceb Extra Discussion 8 23-03-2009 17:49
Team 241's Turret Prototype ontop of the Harvester Prototype Dantvman27 Robot Showcase 39 08-02-2009 22:53
pic: 964's programming table synth3tk Extra Discussion 18 14-12-2007 08:39
pic: AZ Table Game CD47-Bot Extra Discussion 13 15-03-2007 07:34
