Go to Post This isn't just a robot competition, it's not robots driving robots. It's people driving robots, and teams of people who have put a lot into making the robots work. - Gadget470 [more]
Unread 13-10-2009, 11:46
JohnFogarty's Avatar
AKA: @doctorfogarty
[FTC]: Robot C
Ok so last year i programmed in NXT-G and it was ok i got our team to win SC, but this year we want to do more complicated stuff we want to use Robot C, i know the basics but the Tele Op functions still esacpe me any help??
John Fogarty
Unread 13-10-2009, 19:03
ttldomination's Avatar
Sunny
Re: [FTC]: Robot C
Try this link: http://www.robotc.net/teachingmindstorms/index.html
You'll find the the reserved words page is especially helpful.
Have Fun.
1648: 2013-2014
5283: 2015
Unread 13-10-2009, 21:21
l0jec l0jec is offline
l0jec has a spectacular aura aboutl0jec has a spectacular aura about
Re: [FTC]: Robot C
I assume your question is in regards to using JoystickDriver.c for FTC?
Some more FTC specific ROBOTC links are:
http://www.education.rec.ri.cmu.edu/...botc/index.htm
http://www.education.rec.ri.cmu.edu/...tarted_tetrix/
Unread 02-11-2009, 13:51
blhenze blhenze is offline
Bernie H
FRC #2333 (Sapulpa Chieftain Robotics)
blhenze is an unknown quantity at this point
Re: [FTC]: Robot C
I've had a couple of students attempt to use the RobotC testbed. Everything works great with just the motor. However, when we try to use the servo (Testbed 2) neither the motor or servo work. Any Suggestions?
Unread 02-11-2009, 16:14
vexman2222's Avatar
vexman2222 vexman2222 is offline
AKA: Jakob BRaun
FTC #3385
vexman2222 is an unknown quantity at this point
Re: [FTC]: Robot C
I might be able to answer both of your questions
for a basic 2 motor 2 joystick teleOp drive:
joystick.joy1_y1 = motor[motorD]
joystick.joy1_y2 = motor[motorE]
assuming that you have the motors configured with defult names.
For button control you will use if statements:
if(joystick.joy1_buttons == )
motor[motorD] = 100;
motor[motorE] = 100;
I am still a little rusty from last year these might not work....
Prior Lake robotics is hosting the 2nd annual MN FTC snow drift competition on March 6th
Unread 02-11-2009, 21:12
jamie_1930's Avatar
jamie_1930 jamie_1930 is offline
FRC #2228 (Cougartech)
Team Role: Student
jamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to behold
Re: [FTC]: Robot C
From what we've been doing the condition for your if statements should look like this
if(joy1Btn(1) == 1)
code here
this will make it so execute code when button 1 on joystick 1 is pressed.
Unread 04-11-2009, 11:18
AKA: @doctorfogarty
Re: [FTC]: Robot C
if(joy1Btn(1) == 1)
code here
so basically if a created a little automous program to run when i press a button would it work?
John Fogarty
Unread 06-11-2009, 12:52
grampashades grampashades is offline
FTC #0121
grampashades will become famous soon enough
Re: [FTC]: Robot C
if(joy1Btn(1) == 1)
code here
First you guys want:
motor[motorE] = joystick.joy1_y2;
With C programming you set the thing on the left to the value on the right. The other way around shouldn't work. *Unless Robot C built it into the compiler to accept it both ways.
Also as a note to save you guys a lot of frustration later. I would suggets you put in a "dead zone" that stops you from powering the motors with too little voltage.
if ( ( joystick.joy1_y2 < -10) || ( joystick.joy1_y2 > 10))
else
motor[motorE] = 0;
your motors will thank you.
Second I've found throughout my tetsing that it is much better to program the buttons as such:
if(joy1Btn(1) )
code for what you want to happen here
else
code to make that stop happening
While there is not techinical difference in this case....for whatever reason the software gods seem to prefer it without the "==1"
finally, while techinically yes...you could put autonomous code into the "code here" section but you could also run into some serious problems...unless you keep all of your logic sound. You can easliy start getting in trouble when you try things like this.
Unread 09-11-2009, 10:25
AKA: @doctorfogarty
Re: [FTC]: Robot C
else
motor[motorE] = 0;
if(joy1Btn(1) )
else
That is beastly awsome, i'm going to test this with our robot when i get our 2nd motor controller.
LAWL I installed Windows 7 on our robotics laptop and all the software still works because it was compatible with Vista.
John Fogarty
Unread 10-11-2009, 09:36
Re: [FTC]: Robot C
That is generally good advice, but I'm going to go ahead and share some extra insight. Remember that the joystick analog sticks have a range of -127 to 128, but your DC motors only have a range of -100 to 100. While you can directly pass the analog stick value to the motor & ROBOTC will not error, you are losing about 20% of the actual range of the analog stick which will not give you the good fine-grained control your robot is capable of.
The basic solution is to apply a linear scale such as: motor_output = joystick_input / max_joystick_value * max_motor_value.
However, we can do even better if we use a parabolic curve so that we have fine control at low speeds for a larger portion of the analog stick's range and then ramp up the scaling for the extremities of the analog stick's range. Below is a function which will do just that (as well as apply a deadzone):
//scaling function
int scaleForMotor(int joyVal) {
  //constants
  const int DEADZONE = 5;
  const int MAX_MOTOR_VAL = 100;
  const float MAX_JOY_VAL = 127.0;
  //check for deadzone
  if(abs(joyVal) < DEADZONE) {
    return 0;
  //calculate scaled value
  int sign = joyVal / abs(joyVal); // 1 or -1
  float ratio = ((joyVal * joyVal) / (MAX_JOY_VAL * MAX_JOY_VAL));
  int scaledVal = (sign * MAX_MOTOR_VAL) * ratio;
  return scaledVal;
I have no issues sharing this to help other teams get going, but please attempt to understand what it is doing if you choose to copy it into your code. Feel free to adjust the constants to set your own deadzone or max motor output.
Just place the function in your code above the main task and call it like below:
//scales input from joystick 1 left analog stick's y-axis
motor[someMotor] = scaleForMotor(joystick.joy1_y1);
//scales input from joystick 1 right analog stick's y-axis
motor[someOtherMotor] = scaleForMotor(joystick.joy1_y2);
Best of luck,
l0jec
Unread 10-11-2009, 10:39
AKA: @doctorfogarty
Re: [FTC]: Robot C
//scaling function
  //constants
    return 0;
  return scaledVal;
Best of luck,
l0jec
That also looks very good, i understand what you were saying with the Parabolic Curve. THANK YOU!!!
John Fogarty
Unread 10-11-2009, 10:41
BernieH BernieH is offline
FTC #3677
BernieH is an unknown quantity at this point
Re: [FTC]: Robot C
Our Team is new to FTC and RobotC. We are trying to build programs that will allow us to use the joysticks with our robot. Would anyone be willing to share a complete program (rather than program segments that don't explain where the code goes) that would allow joystick 1 to control motorD and Joystick 2 to control motorE?
You can email me off line at bhenze@sapulpaps.org
Thanks
Unread 10-11-2009, 10:50
AKA: @doctorfogarty
Re: [FTC]: Robot C
here you go
Make sure your RobotC is set to NXT and TETRIX mode and also go to motor and sensors setup and configure you motors to how you have them set up.
#include "joystickdriver.c"
task main ()
getJoystickSettings(joystick);
motor[motorD] = joystick.joy1_y1;
John Fogarty
Unread 10-11-2009, 12:34
Re: [FTC]: Robot C
task main ()
while(true){
Don't forget to loop!
Unread 10-11-2009, 20:21
alphadog0309's Avatar
alphadog0309 alphadog0309 is offline
AKA: Karan Hiremath
FTC #0110 (MFS Foxes)
alphadog0309 will become famous soon enoughalphadog0309 will become famous soon enough
Re: [FTC]: Robot C
i dont know why but i was told and ive seen it done only this way in robotc but it think its supposed to be
if(joy1Btn(1) !=0)
action
don't know why i just do it like that...
[FTC]: Power Surge Robot Nitro-Guy FIRST Tech Challenge 7 21-05-2009 10:30
[FTC]: FTC Futures Forum at FTC World Championship gdo FIRST Tech Challenge 0 08-04-2009 18:46
[FTC]: FTC]: FTC Champ Tournament - Ontario (Scoring Breakdown) Mr. Lim FIRST Tech Challenge 2 03-03-2008 11:54
pic: FTC #3 robot design Techno-Turkey Extra Discussion 5 06-02-2008 08:07
[FTC]: [FTC]: Ontario Provincial FTC Start/End Times cbhl FIRST Tech Challenge 8 16-12-2007 13:37
