Go to Post I wouldn't recommend using steel because it will eat up your weight budget pretty quickly. - Scott Morgan [more]
Unread 13-10-2009, 11:21
af4ex af4ex is offline
AKA: John
FTC #2841 (Conspicuous Ninja)
af4ex is an unknown quantity at this point
Need Bluetooth help
I'm the software mentor for Team 2841 in Melbourne Fla. This is our second year. We can connect via BlueTooth using last year's RobotC, but when we loaded the new version 1.93, we started getting 'Bluetooth could not be opened error'. We can still see the Brick ID in the reachable window, but now get this error when we click on the Select via BT button.
We're following the BT guidelines in the Help page. Are there some extra steps or actions required for Version 1.93?
Thanks,
John Day
Mentor Team #4851
John Day
Mentor for Team #2841
West Shore Jr/Sr HS
Melbourne, Florida
Unread 14-10-2009, 09:13
charrisTTI charrisTTI is offline
Ramblin' Wreck
AKA: Charles Harris
FRC #0623
charrisTTI has a spectacular aura aboutcharrisTTI has a spectacular aura about
Send a message via AIM to charrisTTI
Re: Need Bluetooth help
Did you update the firmware on the NXT? Version included with my RobotC V1.93 is 7.83.
FRC 623 2003,2004,2005,2006,2007,2008, 2009, 2010, 2011
FRC 1900 2007
FVC 60 and 193 2006
FVC 3271 2007
FTC 226 and 369 2008, 2009, 2010, 2011
FTC 3806 2010
Unread 19-10-2009, 22:01
AKA: John
[Sorry for the delay in answering] Yes, we uploaded the new 7.83 firmware which came with RobotC.
Will try using a different laptop.
Thanks,
John/AF4EX
John Day
West Shore Jr/Sr HS
Melbourne, Florida
Unread 24-10-2009, 21:35
AKA: John
Tried to connect using two other computers, the BlueTooth logon and PassKey enabling seems to OK with no problem but RobotC reports: "No 'NXT' bricks could be found" and the connection doesn't work (even though Windows still shows the "Passkey Enabled" status for connection. Deleting the connections and starting over doesn't help.
We had no problem using RobotC 1.4 with this same equipment (Bluetooth and brick), so we're suspecting a RobotC bug in version 1.93? Has anyone else had this problem?
Thanks,
John Day
West Shore Jr/Sr HS
Melbourne, Florida
Unread 25-10-2009, 19:39
g_less1902 g_less1902 is offline
g_less1902 is an unknown quantity at this point
What OS are you using? Are you using a computer with builtin Bluetooth,
or the dongle provided with the kit?
Did you do a bluetooth reset on the NXT?
Here are a couple of links for debug from last year.
http://www.usfirst.org/uploadedFiles...oting%20V4.pdf
and
http://www.usfirst.org/uploadedFiles...Reset_BT-1.pdf
Eric Grajales
FTC Coach
Exploding Bacon Team 1902
Help! Can't send files to NXT Brick via bluetooth Raptorace22 National Instruments LabVIEW and Data Acquisition 0 24-11-2008 16:39
need help assembling parts in inventor .. (was: help) jhallel Inventor 5 22-02-2007 01:46
hey need some help with writing a code please help me here magical hands Programming 9 01-01-2004 21:46
