Go to Post I saw a big opening in the bees section and asked if we could sit for this match and was told we were welcome to sit there. Your team made space for about 15 of my team members that came with me. - Debbie [more]
Unread 13-10-2009, 15:20
James Dowd's Avatar
James Dowd James Dowd is offline
A Michigan Man
FRC #1739 (Chicago Knights)
James Dowd will become famous soon enoughJames Dowd will become famous soon enough
Send a message via AIM to James Dowd
[FTC]: Bluetooth Problem with LabView/FTC Controller Station
Has anyone experienced any problems trying to get the LabView FTC Controller Station to connect to the NXT Brick via Bluetooth? We have been able to run our bot with a tether, but are having problems with the Bluetooth Connection.
When we search for the Brick, the controller station finds it, but then when it tries to connect, the brick asks for a passkey, and when we enter the passkey, the controller station then says "Failed to Connect to NXT"....
Is there a way within the controller station to change security settings to not need the passkey or determine what the passkey is (if for some reason it is not what we think it is)?
We have been able to connect the NXT to the Laptop we're using by using the same bluetooth dongle, it is only within the Controller Station that we're having this problem....
Any suggestions?
Thanks in advance for any assistance!!
James Dowd
FRC Team 1739 Mentor, FTC Team 329 Coach
Former Team 830 Mentor and Coach
Former Member of Team 573
2009 Wisconsin Regional Engineering Inspiration Award, Midwest Regional Engineering Inspiration Award
2007 Waterloo Regional Xerox Creativity Award
2006 Waterloo Regional Autodesk Visualization Award
2003 West Michigan Regional Engineering Inspiration Award, Buckeye Regional Xerox Creativity Award
2001 Curie Division Finalist, Great Lakes Regional Finalist, West Michigan Regional Rookie All-Star Award
Unread 13-10-2009, 16:02
aklego aklego is offline
FTC #3595 (Schrödinger's Hat)
aklego is just really niceaklego is just really niceaklego is just really niceaklego is just really nice
Re: [FTC]: Bluetooth Problem with LabView/FTC Controller Station
We had this exact problem. We are using a Mac (OS X 10.6) and this is our fix that, so far, seems to do the trick:
1. Quit the controller station
2. Open Bluetooth preferences.
3. Delete your device from the list.
4. Close Bluetooth preferences.
5. Relaunch the controller station and scan for nxt's.
6. When you see your NXT highlight it in the list and the put a check in the "remember this device" box. (this seems to the the important part)
7. Hit the "select" button
8. Proceed as normal.
This has done the trick for us and I'd be curious to know if it helps anyone else.
Unread 13-10-2009, 16:58
BLAQmx's Avatar
BLAQmx BLAQmx is offline
Software Engineer
no team (National Instruments)
BLAQmx is a glorious beacon of lightBLAQmx is a glorious beacon of lightBLAQmx is a glorious beacon of lightBLAQmx is a glorious beacon of lightBLAQmx is a glorious beacon of lightBLAQmx is a glorious beacon of light
So you have been able to connect to the brick via Bluetooth in LabVIEW but not in the FTC Controller Station?
Assuming you are using XP or Vista - delete the entry for your NXT in the Bluetooth manager for the OS (this is similar to what aklego described for Mac OS X), and try to connect again to the NXT with the Controller Station.
There is also troubleshooting information for Bluetooth and other FTC related items in the back of the FTC Getting Started Manual. Its worthwhile to check out if you haven't already.
Cheers,
Mark
NI FIRST Community: Where to go for LabVIEW, Wind River, cRIO-FRC, and NXT support.
Unread 14-10-2009, 07:38
ssi ssi is offline
AKA: David Spangler
FTC #2843 (Under the Son)
ssi will become famous soon enough
We had a similar problem with one laptop when we were at a demo over the summer. Our Vista laptop had no problems, but an XP laptop would not work (even with a brick that had worked in the past). Apparently the XP laptop had automatic updates enabled and one of the updates affected the Bluetooth. To correct the problem I had to go to services in administrative tools and change the logon for the Bluetooth Support Service to a Local System Account. I found this solution after an Internet search related to being unable to connect to Bluetooth devices.
The laptop was "connected" to the brick but was unable to use the virtual serial port associated with the NXT.
Let us know if any of these solutions work.
Unread 14-10-2009, 08:22
wilsonmw04's Avatar
Coach
FRC #1086 (Blue Cheese)
We had a similar problem. It seems that we could not connect to the brick with Labview and the control station running at the same time. Logging out of labview solved the problem.
Unread 14-10-2009, 09:49
BLAQmx's Avatar
Software Engineer
This is actually expected (albeit annoying) behavior.
Unread 14-10-2009, 10:12
LVMastery LVMastery is offline
LabVIEW Educator and Mentor
AKA: Ben Zimmer
FRC #0843 (Wildcats)
LVMastery has much to be proud ofLVMastery has much to be proud ofLVMastery has much to be proud ofLVMastery has much to be proud ofLVMastery has much to be proud ofLVMastery has much to be proud ofLVMastery has much to be proud ofLVMastery has much to be proud of
Can I ask you to confirm exactly which software you are referring to? Is it the one with the two pictures of joysticks which ships with LabVIEW, or the FMS, or are you one of the beta testers of the new FCS?
Thanks,
Ben
Ben Zimmer
Enable Education
www.EnableEducation.com
www.FRCMastery.com
email: ben@enabletc.com
Phone/Fax: (905) 864-1858
Toll Free: (877) 872-4619
Unread 14-10-2009, 11:16
James Dowd's Avatar
A Michigan Man
Ben, if you're asking me, we are using the one with the two pictures of joysticks that ships with Labview.
Thank you to everyone for your advice, I've passed it along to my team and will let you know if we get it up and running today!
James Dowd
Unread 27-10-2009, 10:40
James Dowd's Avatar
A Michigan Man
I just wanted to drop you guys a note and thank you for the help. By working with the bluetooth dongle, the NXT Brick and the controller station software on a different version of Windows, we were able to narrow this problem down to an operating system problem. We have someone checking into the updates (or lack thereof) on our team laptop, so this problem should be resolved when those updates are sorted out.
I haven't been there for a few meetings due to other commitments, so this is second hand information. If people are interested I can unearth the specifics and post them...
Thanks again for the advice everyone!
James Dowd
[FTC]: Problem with Code or Problem with Bluetooth? VeedotJaydot FIRST Tech Challenge 3 27-01-2009 18:22
[FTC]: Problem with two controller setup in Labview wilsonmw04 FIRST Tech Challenge 2 11-11-2008 19:58
[FTC]: First problem with FTC and LabView.....? PhilBot FIRST Tech Challenge 5 07-11-2008 10:36
[FTC]: FTC Controller Station Connectivity (Bluetooth and USB) Issue jbbjjbt FIRST Tech Challenge 6 05-11-2008 11:49
[FTC]: FTC Servo-Motor Problem with Labview dnhansen FIRST Tech Challenge 1 26-10-2008 00:43
