Go to Post P.S. we are a rookie team.P.P.S. we really don't know what we are doing - Carter12s [more]
Unread 14-10-2009, 20:54
DonRotolo's Avatar
Back to humble
FRC #0832
Re: Tracking a radio signal
To receive the signal, use an omnidirectional "ground plane" antenna. Very inexpensive and small.
The DDF signal varies too much to decode data from it, generally speaking. There are ways around it, but not easy ways.
Yes, you may in fact receive signals from more than one transmitter, but your flying algorithm will not simply pick up 'one' signal and fly at it, instead you'll fly past it and note where it was, then turn and fly at it. Or, said another way, you need to find the right one before you can steer towards it.
Try this on a regular map. At one spot, you get the target at a bearing of 110 degrees. At another spot, you get the target at a bearing of 150 degrees. You turn 90 degrees and get the target at a bearing of 120 degrees (all measured relative to the aircraft) again. Draw lines to infinity from those locations, where they cross is the target. Now go there.
Again, this isn't a trivial problem to solve, but I still think it is within your budget and reach. Before committing to air, I'd first learn how to find the transmitter on the ground. By breaking this problem into manageable pieces, what you learn on foot will be easier to use int the air.
Change two color tracking vi from tracking pink AND green to orange OR grape balls star_lancer Programming 5 14-02-2009 20:58
VEX Radio Range & Loss of Radio Fail Safe? Chris_Elston Programming 14 03-09-2008 09:13
Ham Radio and Radio at FIRST bcieslak General Forum 41 06-04-2007 10:41
Camera locked in "tracking", but not tracking geeknerd99 Programming 1 18-02-2007 22:47
need 2003 radio/help with old radio MaxM Technical Discussion 2 04-01-2004 15:31
