Go to Post We had an over all losing record this year. When I look at kid's faces, they don't give a rip about that. I see excitement about the next event and talking about improvements for next year. Winning is nice, but that is not the reason I do what I do. - wilsonmw04 [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
Unread 15-10-2009, 09:19
smcmahon's Avatar
smcmahon smcmahon is offline
The Architect
AKA: Sean McMahon
FRC #2656 (QUASICS)
smcmahon is an unknown quantity at this point
Question mating 2009 rover wheels and sprockets
Good morning. 2656 is trying to repair our Lunacy robot for an upcoming event. We had some issues with the bolts that mate the Rover Wheels and sprockets together.
According to this PDF, the wheels and sprockets both utilize a #10 mounting hole. Needing more of these machine nuts and bolts, I went to The Home Depot last night. I bought a few bags of #10 x 32 2" machine screws (with nuts).
http://usfirst.org/uploadedFiles/200...%20Rev%20B.pdf
I'm currently trying to fit these through the #10 mounting hole in the Rover Wheel. However, it just doesn't fit. It's right on the verge of fitting. If I take a screwdriver and turn, it starts to thread the inside of the hole... and strip the flat head of the screw... (wish I found phillips head instead)
Are these actually #10 holes? Is 10x32 the right size? Should I have to "thread" the holes as I put the machine screws in there?
I have another, very similar machine screw that's slightly smaller. Perhaps #9 (if that exists). It fits 99% great, with about 1% of wiggle room. What did everyone else use?
Unread 15-10-2009, 09:24
REVving up for a new season
FRC #2848 (All-sparks)
Re: mating 2009 rover wheels and sprockets
to use #10 screws in the rover wheels you need to tap the holes. To use a through bolt with no wheel modification you need a #8 bolt. Either way is generally acceptable. Most of the sprockets from andymark are bored with #10 so that is the way I believe most teams went.
Greg Needel│www.robogreg.com
Co-founder REV Robotics LLC www.REVrobotics.com
2014 FRC World Champions with 254, 469, & 74
Unread 15-10-2009, 10:25
President, AndyMark, Inc.
FRC #3940 (CyberTooth)
The holes in the 2007, 2008, and 2009 FIRST Wheels (aka: Rover Wheels) have a diameter of 0.17". The intention of this diameter is to use the hole as a pilot hole for a #10-32 or #10-24 or M5x0.8 screw. Some teams drilled out this hole to 0.20" and used a long #10 screw and a nut. While this is a secure way to fasten the sprocket, it is not needed.
As Greg correctly points out, you can tap the hole for a #10 screw. Alternatively, you can simply drive a #10 screw into the hole, even without tapping the hole. If you use a cordless driver, the heat of the screw cutting through the polycarbonate will actually melt the polycarbonate a bit, right around the screw end, and act as a very secure locking method. So... you don't have to use a tap to thread the hole.
Some FRC teams used "thread cutting" or "thread forming" screws. We have found a good one, that has a 5/16" hex head for easy driving, and we offer it here on the AndyMark site. This screw requires no tapping of the hole and it is very easy to drive.
Sincerely,
Andy Baker
Unread 15-10-2009, 10:56
smcmahon's Avatar
The Architect
AKA: Sean McMahon
FRC #2656 (QUASICS)
Wow! Thanks Greg and Andy. CD always gets me the answers I need, in crazy-short amounts of time. I was trying to twist the #10 screws in by hand, mainly because I couldn't come up with the DeWalt... I guess using the power tool will be much more efficient.
Worst case scenario, we'll hit up Lowe's after school today and get some #9 instead. Thank you so much gentlemen. That's exactly the information I was looking for.
Unread 15-10-2009, 11:12
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
I don't think you're going to find a #9. Greg probably meant #8. (Here's a chart.)
Do you know how well those particular screws perform with repeated insertions? Do you get a self-locking effect as well?
Unread 15-10-2009, 11:33
Yea I meant #8 that's what I get for posting on CD during 6am conference calls.
Unread 15-10-2009, 13:39
We have done life testing with only 3 screws holding the sprocket in place. This works well. As for insertion and re-insertion, I am pretty sure that these will work well. If they don't work as well, then I suggest using 6 screws.
Andy
Unread 15-10-2009, 15:23
AdamHeard's Avatar
Lead Mentor
We had a set of wheels that we hubbed/dehubbed a good 5+ times last year. Only issue was the screws backing out over time (the heads were rubbing on the bumper) and we had to retighten them. I don't think they got looser overtime, if anything they got tighter and retightening them was very difficult.
Unread 15-10-2009, 18:05
Jon Jack's Avatar
Jon Jack Jon Jack is offline
VEX Robotics
no team (No Team)
Jon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond repute
Send a message via AIM to Jon Jack
Andy
The wheels on our practice robot only had three screws holding the hub in place. That set of wheels saw between 32-40 hours of run time this season (compared to the average competition bot which gets about an hour and a half a season).
We had zero problems with just three screws.
Team 1538 / The Holy Cows, 2005-2016
Unread 15-10-2009, 21:11
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
As a general note, McMaster Carr has a great selection of good-quality screws, at pretty fair prices. You're much better off figuring out what you need and ordering from there, than trying to piece it together with the garbage sold at Home Depot.
Unread 15-10-2009, 22:51
ChuckDickerson's Avatar
ChuckDickerson ChuckDickerson is offline
FRC #0456 (Siege Robotics)
In addition teams may want to check out their local Fastenal store. Fastenal stores are everywhere and carry just about every type of nut and bolt imaginable along with just about everything else you could ever need in an industrial hardware type store. They can be a bit expensive if you pay what they are asking, however, over the years our team has developed a nice relationship with our local Fastenal store and they give us a large (at or close to their cost or sometimes even free) nuts and bolts and even materials including aluminum extrusions. We consider Fastenal to be a valuable team sponsor and for their generosity we, of course, are happy to plaster their name and logo on everything we have like our team shirts and the robot. I agree with sanddrag, skip the cheapo low quality nuts and bolts at Home Depot and go for the higher quality and better selection at places like McMaster Carr and Fastenal.
Unread 16-10-2009, 10:01
smcmahon's Avatar
The Architect
AKA: Sean McMahon
FRC #2656 (QUASICS)
http://lib.store.yahoo.net/lib/yhst-.../AM09WNick.mp4
I watched the above video, which I found in a similar thread from January. I guess having this problem in mid-October is kinda funny...
I did end up just buying the #8 hardware since I couldn't find the DeWalt (turns out it's at a mentor's house). We'll keep all of this in mind though, for future mating of wheels, sprockets, and spacers.
Thanks everyone!
Unread 16-10-2009, 15:56
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
Enco is also a great source for fasteners, and depending on the type, can be a lot cheaper than McMaster.
Art Dutra IV
世上无难事,只怕有心人.
Mounting Sprockets to the Rover Wheels Ice Berg Technical Discussion 22 20-01-2009 00:38
Encoders and Rover Wheels EncodersRUS Programming 14 12-01-2009 12:34
Sprockets and wheels don't match up Astarties Technical Discussion 1 03-01-2009 17:58
Different sprockets on front and back wheels neoshaakti Technical Discussion 10 31-01-2008 17:52
[OCCRA]: question about IFI wheels and sprockets Russ C OCCRA Q&A 1 30-09-2006 14:13
